TychoX
VLANs over Bonding interfaces?
Tue Feb 26, 2013 12:38 am
ive tried to configure VLANs over bonding interfaces but so far without success.
Lets say if i have 2 VLANs, "VL_Pivate" and "VL_Pubic", and on router A i have bonding interface "bonding_to_B" and on router B i have bonding interface "bonding_to_A".
I configure the VLANs on the bonding interfaces:
Router A:
/interface vlan add name=VL_Private interface=bonding_to_B vlan-id=10
Router B:
/interface vlan add name=VL_Private interface=bonding_to_A vlan-id=10
Now i create one bridge on A and B named "BR_Private" and add interfaces AND the VLANs like this
Router A:
/interface bridge port add bridge=BR_Private interface=ether1
/interface bridge port add bridge=BR_Private interface=VL_Private
/ip address=192.168.23.1/24 disabled=no interface=BR_Private
Router B:
/ip address=192.168.23.2/24 disabled=no interface=BR_Private
With this setup i cant get a connection from router A to B. If i remove the VLANs from the bridge and instead connect the bonding interfaces directly into the bridges it DOES WORK. I. e. i can ping the other side from both routers.
Anyone has an idea whats wrong? Cant i do VLANs over Bonding interfaces or do i have to choose a different approac?
thx,
// Tycho
nmaton
Re: VLANs over Bonding interfaces?
Tue Apr 02, 2013 6:28 pm
You dont need a bridge for vlans on bonding interfaces.
you create your bonding interface first and put in the slaves your ethernet interfaces youd like to use:
eg:
/interface bonding
add arp=enabled arp-interval=100ms arp-ip-targets="" disabled=no down-delay=500ms lacp-rate=30secs \
link-monitoring=mii-type1 mii-interval=100ms mode=802.3ad mtu=1500 name=BondedTRUNK primary=none slaves=\
ether1,ether2,ether3,ether4 transmit-hash-policy=layer-2 up-delay=500ms
Afterwards you configure your vlans on the bonding trunk.
eg:
/interface vlan
add arp=enabled disabled=no interface=BondedTRUNK mtu=1500 name="vlan57" \
use-service-tag=no vlan-id=57
that's it no more no less.
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
OnixJonix
Thu Oct 02, 2014 4:51 pm
But if i have more than one Bounding interface where i need to run same Vlans? Can i then add both boundings to bridge? Or what? Thanks!
marcol
Sat Mar 26, 2016 4:01 pm
I have the same problem. I want to build a bridge over one bonding-interface (802.3ad to CISCO SF300 with tagged VLANs) and one ethernet-port (tagged VLANs HP ProCurve) to have a L2 connection.
For L3 inter vlan routing, my VLANs have the bridge as interface.
But it does not work! Bonding slaves: Link goes up and down....
The same bonding-interface without the bridge with directly attachet VLANs and e.g. one different VLAN on the ethernet-port is working (only L3 connection).
But I want the same VLANs on the bonding-interface and ethernet-port (L2 and L3 connection)?
I use RB3011 with RouterOS 6.35rc42.
emuell
Fri Aug 12, 2016 2:46 pm
Hi marcol ,
i have the same situation - do you found a solution for this till now ?
Thx!
Users browsing this forum: MSN [Bot] and 109 guests
