jdejansb
MT on ESXi as a gateway ?!
Thu Mar 07, 2013 3:17 am
Is it smart to "place" a gateway Mikrotik (around 200 users, mostly wifi, alltogether 50Mbps peek) as a virtual device in ESXi server? I did some test; with several queues, filter rules and few mangles, and around 160Mbps traffic CPU(s) go up to 50-60% ...
Does anyone have some more experience with this?!?
If this is a bad idea, what do you suggest I should migrate to: rb1200 or rb1100AH (both are more than enough for my needs) - it works fine with 450G for now (at under 40% cpu)...
aacable
Re: MT on ESXi as a gateway ?!
Thu Mar 07, 2013 5:47 am
I have deployed Mikrotik+SQUID+Radius Server in one box at various cable.network and so far I am pleased with the results. If you use some modern hardware with dual processors with multiple cores , gigabit connectivity, and with raid supported storage, you will be fine for virtualizing multiple OS in one box. For example most common systems I have used are IBM xseries with dual processors with 4/8 cores p/p.
Last virtualization I have done was on Intel base server board with single quad core processor with 16 GB RAM and dedicated each hdd for each OS and it worked fine.
_____________
Regard's
Syed Jahanzaib
Web: http://aacable.wordpress.com
Email: aacable [at] hotmail.com
tomaskir
Trainer
Trainer
Thu Mar 07, 2013 1:46 pm
We have about 10 ROS VMs running on ESXi 5.0 on multiple servers in multiple places around our network. Each terminates all of a single customer's VLANs. IPv4 and IPv6, OSPF and firewall. Passing about 10-20mbit with spikes up to 100mbit. Our main proxy is also a ROS VM, with a 160gb SSD passed to the VM.
Havent had any problems yet, they are all currently at 200+ days uptime.
However, we still keep our edge router and ACs on RouterBoards (using 1100AH and 1100AHx2)
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
jdejansb
Thu Mar 14, 2013 8:02 pm
Thanks for the prompt answer.
We have several linux servers (email, web hosting, dns, backup database and radius, ...) at one ESXi 4.1 server working perfectly; also, one Windows XP, for accessing the inner network... Everything works great, but I was not sure how would a RouterOS installation behave in such "mess" ;)
thanks again!!!
jdejansb
Thu Mar 14, 2013 8:07 pm
10x!!
It's nice to know that configurations like these work great. I'll start looking for new hardware since our current ESXi machine is some old(er) 4core AMD ....
Users browsing this forum: No registered users and 37 guests
