MUM Europe 2020
bkus
OVPN disregards subnet masks?
Fri Mar 08, 2013 8:02 am
I setup an OVPN client/server TAP connection. The server is set like so:
/ppp profile
add bridge=bridge-local local-address=ovpn-pool name=ovpn remote-address=ovpn-pool use-encryption=required
add name=ovpn-pool ranges=10.2.2.0/28
Notice the /28!
But when I dial the client in, I get this for an address:
[admin@ClientRouter] > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 1 D 10.2.2.4/24        10.2.2.0        ovpn-out1
Notice the /24!
Is this a bug? I would expect the /28 to be preserved when it's being re-assigned to clients. On the server side, the situation is better:
[admin@SiteRouter] > /ip address print
 3 D 10.2.2.0/32        10.2.2.4        ovpn-bart
And just to verify that this local address on the client does indeed make a /24 entry in the routing table:
[admin@ClientRouter] > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
 1 ADC  10.2.2.0/24        10.2.2.4        test                      0
Help?
bkus
Re: OVPN disregards subnet masks?
Tue Mar 12, 2013 6:18 pm
Looks like I didn't look in the right place to set the netmask:
[admin@SiteRouter] /ppp> /interface ovpn-server server print
                     enabled: yes
                        port: 1194
                        mode: ethernet
                     netmask: 24
                 mac-address: FE:91:A7:C9:AF:3F
                     max-mtu: 1500
           keepalive-timeout: 60
             default-profile: default
                 certificate: none
  require-client-certificate: yes
                        auth: sha1
                      cipher: aes256
Users browsing this forum: septads and 32 guests
