oook
Ospf distance in 2.9
Wed Mar 01, 2006 12:30 am
Hi I just tried to configure redistribution from ospf to BGP.
It looks like 2.9 hasn't configured ospf distance correctly. It may be 110 and I see nothing (means 0). Same situation in static and connected routes. eBGP writes "20" there.
So I can't redistribute BGP to ospf (because my router preferes ospf routes instead of BGP).
In 2.8 the distance on ospf routes looks fine.
May I missed anything in configuration? Or another bug in 2.9 line?
airnet
Thu Mar 02, 2006 2:03 pm
You need to use inbound filters with routing-test package eg:
/routing filter chain=ospf-in set-distance=110
/ routing ospf area set backbone area-id=0.0.0.0 authentication=none prefix-list-import=ospf-in prefix-list-export="" disabled=no
BEWARE - the last (at least 2) versions of routing-test (up to 2.9.14 so far) are very broken. wait until about 2.9.73 and it might be closer to stable.
oook
Thu Mar 02, 2006 6:26 pm
where to get 2.9.10 routing-test? :idea:
found it :-)
oook
Thu Mar 02, 2006 6:41 pm
I've installed 2.9.10 routing-test and ospf stopped to work (same configuration).
I've disabled routing-test and waiting for new version of OS.
oook
Fri Mar 10, 2006 12:14 am
Just now upgraded to 2.9.16 and ospf routes are still not marked by default. I'm not so brave to load routing-test this version. Can anybody fix the problem? It must be definitelly one line in the code.
Eugene
Forum Veteran
Forum Veteran
Fri Mar 10, 2006 8:07 pm
Routing-test in the 2.9.16 is known to work.
Eugene
Tout individu a droit à la vie, à la liberté et à la sûreté de sa personne.
oook
Sun Mar 12, 2006 10:43 pm
Eugene
I've found it and testing. Distance is set, but it seems like there is still no redistribution to my ospf process ... Have to look more deeply into routing tables in my area ...
Users browsing this forum: 0012nish, asm0922, matsam, msatter, Sinan and 180 guests
