ytuxedo002
VRRP but with two seperate circuits
Mon Mar 18, 2013 9:06 pm
I'm setting up two 450G's for a client right now and have them successfully setup using VRRP. Each MT has it's own separate ISP circuit.
My questions is how can I get it to failover if one of the two internet circuits go down and not necessarily the Mikrotiks going down?
Let me know if I explained correctly or not.
Regards
nmaton
Re: VRRP but with two seperate circuits
Mon Mar 18, 2013 10:26 pm
You can make a script that monotors if your isp gateway is reachable and if not disable the vrrp interface untill the gateway is reachable again.
Nicolas Maton
nicolasmaton@gmail.com
CCNA/ CCDA
MTCNA / MTCTCE
Available for Mikrotik Consulting
ytuxedo002
Mon Mar 18, 2013 11:15 pm
Thanks for the response. that's what i was thinking but i didn't know where to start.
nmaton
Mon Mar 18, 2013 11:27 pm
First go to your vrrp interface and add a comment to it :
you can go to tools netwatch
press the + sign
as host put in your gateway public ip address .. or you can even use some sort of public reachable ip (google dns 8.8.8.8 ? )
and on the down tab put something like
:log info "gateway not reachable putting down vrrp"
/interface vrrp set [find comment="commentyouputabove"] disabled=yes
on the up tap you can put the reverse
:log info "gateway reachable putting up vrrp"
/interface vrrp set [find comment="commentyouputabove"] disabled=no
Nicolas Maton
CCNA/ CCDA
MTCNA / MTCTCE
ytuxedo002
Tue Mar 19, 2013 12:12 am
press the + sign
I can work with this. Thank you. I'll let you know the outcome.
Users browsing this forum: Google [Bot] and 131 guests
