MMorris
Firewall Rule to allow device without port knocking?
Thu Mar 21, 2013 2:29 am
I have a firewall setup with port knocking but would like to be able to allow specific devices to connect without doing a port knock. I was hopping to do a firewall rule based on src mac but everone gets the same src mac address so that wont work!
Any advice on if this is possible? I assume everyone is getting the same src mac from a downstream router at my isp?
Thanks!
jandafields
Re: Firewall Rule to allow device without port knocking?
Tue Mar 26, 2013 5:21 am
Thanks!
MAC addresses are NOT sent from users on the internet to your router, as you have found out.
You could use IP addresses, if the devices on the Internet has a STATIC IP address... or a RANGE of IP addresses.
Other than IP address and port knocking, there is nothing to initially identify a device out there on the internet.
Users browsing this forum: No registered users and 135 guests
