gerhard
Slow NAT transfer speeds
Sun Mar 24, 2013 10:45 pm
When I go over a NATed port, my transfers don't exceed 20Mbit/s. If I rsync from inside the network, I hit 60-70Mbit no problem, but from outside (port 11235 gets forwarded to 192.168.88.10:22 internally), I can't get past 20Mbit.
/ip firewall nat print
2   chain=dstnat action=dst-nat to-addresses=192.168.88.10 to-ports=22 protocol=tcp dst-port=11235
What can possibly be imposing this limit?
I'm on RB2011UAS with RouterOS 5.24.
normis
Re: Slow NAT transfer speeds
Mon Mar 25, 2013 11:45 am
Which ports are you using on the RB2011 ?
gerhard
Mon Mar 25, 2013 12:03 pm
For NAT you mean?
This is the current situation:
remote-host -> rb2011:11235 -> 192.168.88.10:22
rsync --verbose --progress --human-readable -e 'ssh -p 11235' 100MB gerhard@rb2011:/tmp/
100MB
     104.86M 100%    2.01MB/s    0:00:49 (xfer#1, to-check=0/1)
sent 104.87M bytes  received 31 bytes  2.08M bytes/sec
total size is 104.86M  speedup is 1.00
192.168.88.10 <-> remote-host
rsync --verbose --progress --human-readable remote-host:/tmp/100MB .
100MB
     104.86M 100%    7.17MB/s    0:00:13 (xfer#1, to-check=0/1)
sent 30 bytes  received 104.87M bytes  5.99M bytes/sec
normis
Mon Mar 25, 2013 12:21 pm
no, I mean physically which ethernet ports on the device ?
gerhard
Mon Mar 25, 2013 12:31 pm
ETH1 - internet
ETH2 - wireless AP
ETH3 - fileserver (192.168.88.10)
ETH4 - fileserver backup
ETH5 - desktop
ETH6 - 3G hotspot
normis
Mon Mar 25, 2013 12:39 pm
Single TCP can't be so high because of nature of TCP. Try running multiple TCP connections at the same time, you will see that the total speed will be higher.
gerhard
Mon Mar 25, 2013 2:49 pm
OK, so when I parallelize, it takes 7 connections to saturate my upstream:
104.86M 100%    1.76MB/s    0:00:56 (xfer#1, to-check=0/1)
104.86M 100%    1.75MB/s    0:00:57 (xfer#1, to-check=0/1)
104.86M 100%    1.72MB/s    0:00:58 (xfer#1, to-check=0/1)
104.86M 100%    1.71MB/s    0:00:58 (xfer#1, to-check=0/1)
104.86M 100%    1.69MB/s    0:00:59 (xfer#1, to-check=0/1)
104.86M 100%    1.65MB/s    0:01:00 (xfer#1, to-check=0/1)
734.02M 100%    11.99MB/s   0:00:58
There still must be a limit in the router for single TCP connections when going through the NAT, otherwise there wouldn't be a 3.5x difference vs going direct.
Oh well, at least I have an acceptable solution. Cheers!
Users browsing this forum: Baidu [Spider], Easpeak, eworm, Google [Bot], gotsprings and 94 guests
