normis
RouterOS v6rc12
Wed Mar 27, 2013 1:15 pm
What's new in 6.0rc12 (2013-Mar-26 17:18):
*) ospf - add use-dn option;
*) ospf - fix route-tag handling;
*) fixed layer7 matcher - it is case insensitive now;
*) remote logging - added iso8601 time format support;
*) bgp - change MED propagation logic, now discarded when sending route with
non-empty AS_PATH to an external peer;
*) fixed occasional nand corruption on CCR;
*) ipsec - added ipv4 mode-cfg support for responder;
*) ipsec - fixed some issues with removal of dynamic policies;
*) email - renamed parameter tls to start-tls for send command;
*) wireless - update required when using small width channel RB2011 RB9xx
caveat: update remote end/s before updating AP as both side are required to use new/same version for a link
*) ipsec - generate-policy now can have port-strict value which will use port from peer's proposal
when generating policy or port-override which will always generate policy for any port;
*) ipsec - responder side now uses initiator exchange type for peer config selection;
*) lcd - changed All interface stat screen (bar graphs) to show total bandwidth usage, combine rx/tx together;
*) lcd - removed "all-interface-mode" option;
*) lcd - changed "Interfaces" screen to show interface usage similiar to All interface stat screen;
*) lcd - improved Interfaces -> * -> Info screen, added more wireless information;
*) lcd - added Registration Table screen for wireless interfaces under
Interfaces -> 'wireless interface' -> Registration Table;
*) fixed occasional kernel crashes on CCR;
*) fixed other than only-hardware-queue interface queues on CCR;
*) lte - devices with vendor/product id pair 0x0f3d/0x68AA now uses directip inferface;
*) dhcp client v4 - option add-default-route now supports special-classless value;
*) significantly increased simple queue performance on multi core systems (up to 9x on CCR1036 with at least 32 top level simple queues)
*) ip arp - new property published;
*) web proxy - added new option max-cache-object-size,
upper limit of max-client-connections and max-server-connections is now calculated from system RAM;
*) ospf - fixed inconsistency in external ECMP route calculation;
*) certificates - CA keys are no more cached, every CA operations now requires a valid CA passphrase.
use set-ca-passphrase for scep server to cache CA key in encrypted form;
*) ppp - made MPPE encryption work on tilera (bug introduced in 6.0rc10);
*) tool fetch - https support with optional certificate verification;
*) sstp server - removed test mode which allowed running server without certificate;
*) trafficgen - add support for ipv6 header;
*) wireless - added support for small channels on SXT lite;
http://www.mikrotik.com/download
"System package -> Upgrade" is also live now!
danielvc
Re: RouterOS v6rc12
Wed Mar 27, 2013 2:56 pm
Morning,
After upgrade one x86 system with v6rc12 it creates a file named um-before-migration.tar with 2 files inside: logsql.umb and mainsql.umb. Just delete it?
normis
Re: RouterOS v6rc12
Wed Mar 27, 2013 2:58 pm
Morning,
If you don't need these backup files, just delete. They are User Manager database backups
Pezhman
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:03 pm
Hello
IP>>HotSpot>>Active Users>> Users Tx Rate , is not active on this Version.
It was not active on RC11 also.
Any suggestion ?
Regards
normis
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:04 pm
Hello
Any suggestion ?
Regards
Do you use Bridge ?
Pezhman
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:10 pm
No !
Pezhman
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:15 pm
No !
In fact it shows zero for all active Hotspot users Tx Rate
majkel
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:46 pm
On rc12 (build from 26/Mar ~17) on RB2011 there is a problem with Graphing of interfaces..
When I reboot router the statistics of interfaces is deleting..
THe CPU, HDD, Memory its ok..
A`m testing on 1036 the last build and there is everything ok..
second bug RB 2011
Lcd is not working (touchscreen too)
normis
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:47 pm
works on our RB2011, maybe some coincidence. try "/lcd set enabled=no" and then back to "yes". also try recalibrate command. Did you reboot?
majkel
Re: RouterOS v6rc12
Wed Mar 27, 2013 3:53 pm
Yes I try everything.. on rc11 works fine.. on rc 12 build from 20 mar works fine too)
And what about the graphics?
normis
Re: RouterOS v6rc12
Wed Mar 27, 2013 4:09 pm
can you send your supout.rif file to support@mikrotik.com ? make sure you are running the rc12 release from our webpage, not from the test link.
kgninfos
Re: RouterOS v6rc12
Wed Mar 27, 2013 6:17 pm
Hello
Any suggestion ?
Regards
is the issue resolved as i got the same issue on rc 11
http://forum.mikrotik.com/viewtopic.php?f=1&t=71064
cheeze
Re: RouterOS v6rc12
Wed Mar 27, 2013 7:20 pm
Normis/MRZ/Mikrotik crew. I don't know how often this is said but I'm thankful to see that yalls are working your butts off to make this a better product. While I think that there's a lot of frustration that can be seen and is expressed, I still think it's a great product and I plan on buying more of it in the future (money permitting as always). So as always, thank you :)
Diamond
Re: RouterOS v6rc12
Wed Mar 27, 2013 7:47 pm
My RB951G reboots ever 20-30 s after upgrade from 6.0rc11 to 6.0rc12. No winbox connect
normis
Re: RouterOS v6rc12
Wed Mar 27, 2013 8:29 pm
Did you check for any supout.rif files?
payday
Re: RouterOS v6rc12
Wed Mar 27, 2013 8:41 pm
In v6rc12 it is not possible to assign LCD to LEDs:
This was possible and was working fine in v6rc9:
Device: RB2011UAS-2HnD-IN
Diamond
Re: RouterOS v6rc12
Wed Mar 27, 2013 9:45 pm
Device has been "netinstalled". All files destroyed :(
payday
Re: RouterOS v6rc12
Wed Mar 27, 2013 11:00 pm
Another micro-bug:
In WebFig, clicking [Hide Menu] always loads Quick Set.
rafaeltdk
Re: RouterOS v6rc12
Thu Mar 28, 2013 1:28 am
because quues not updating this rate avg rx and tx, online? very slow.
normis
Re: RouterOS v6rc12
Thu Mar 28, 2013 8:45 am
It was a bug and was fixed. Obviously, the LCD is not a LED.
normis
Re: RouterOS v6rc12
Thu Mar 28, 2013 8:46 am
Thanks a lot for the support, we appreciate it.
normis
Re: RouterOS v6rc12
Thu Mar 28, 2013 10:07 am
Another micro-bug:
It is not a bug, it was meant to do that. it basically switches to user friendly quickset mode, and hides the complicated settings menu
camlost
Re: RouterOS v6rc12
Thu Mar 28, 2013 1:16 pm
Looks like new rc12 pppoe-server answers faster to pppoe clients.
engineertote
Re: RouterOS v6rc12
Thu Mar 28, 2013 3:20 pm
with PPP srerver , more than 400 active user the ping to DNS be non-stable even from inside the router .
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
MrYan
Re: RouterOS v6rc12
Thu Mar 28, 2013 5:06 pm
I seem to be having issues with bridge interfaces and dynamic link local IPv6 addresses. They are generated but the interface shows as '(unknown)' in /ipv6 address print. This has the knock on effect of disabling IPv6 RA messages and so my client devices are not getting IPv6 addresses automatically.
I thought at fist is was because I'd set admin-mac on the bridge to be a physical interface MAC address but I changed it to a Locally Assigned Address and that also caused issues (02:00:00:00:00:01). I've now changed it to something more random and it's working at present but I'm not sure if it's fixed or I've just been lucky whilst rebooting.
Diamond
Re: RouterOS v6rc12
Thu Mar 28, 2013 6:00 pm
After installing Dude package, RB951G began rebooting again. I don't know, dude caused reboots or not, but the fact is the fact - second fail on day. Return rc11. rc11 flying normal
biasottocarvalho
Re: RouterOS v6rc12
Thu Mar 28, 2013 6:12 pm
Please need the RouterOS v6.11rc to CCR, after updating to V6.12rc'm having problems with limited customers Queues.
biasottocarvalho
Re: RouterOS v6rc12
Thu Mar 28, 2013 6:23 pm
I updated my CCR1016-12g for the v6.12rc RouterOS Queues stopped working properly after 10 hours of use the queues frees banda for customers in RouterOS v6.11rc not happened, please need version v6.11rc someone could provide me.
thankful,
Thiago Biasotto
krakenant
Re: RouterOS v6rc12
Thu Mar 28, 2013 7:24 pm
No !
If you are doing per user queues, you will notice that those don't work either.
I submitted this bug weeks ago along with another bug and apparently this one got overlooked.
biasottocarvalho
Re: RouterOS v6rc12
Thu Mar 28, 2013 9:44 pm
Someone please RouterOS v6.11rc has to offer.
Last edited by biasottocarvalho on Thu Mar 28, 2013 10:21 pm, edited 1 time in total.
honzam
Re: RouterOS v6rc12
Thu Mar 28, 2013 10:05 pm
email: thiagobiasotto@hotmail.com
Please don´t quote full changelog
RC11 http://download2.mikrotik.com/routeros/ ... .0rc11.npk
LAN, FTTx, Wireless. ISP operator
biasottocarvalho
Re: RouterOS v6rc12
Thu Mar 28, 2013 10:19 pm
Thank you!
payday
Re: RouterOS v6rc12
Thu Mar 28, 2013 11:17 pm
This "bug" was useful :). Can you put back this bug? :)
This is the only way to turn on the LCD backlight, by software, to it's previous state (showing Stats).
Excuse me if I am bothering you (I know it is not important feature of RouterOS) but it was useful when it turned on to Stats automaticaly, without touching it. Maybe you can add other command to switch view to Stats? Now it is possible to choose which interface is shown but user still have to touch it to show Stats (after /lcd set enabled=yes).
payday
Re: RouterOS v6rc12
Thu Mar 28, 2013 11:41 pm
Another micro-bug:
Then why button [Quick Set] does not hide the menu? :)
There is separate button [Quick Set] that switches to quickset mode. By clicking [Hide Menu] user expects that it will just hide the menu and not switch to quickset mode.
macgaiver
Re: RouterOS v6rc12
Fri Mar 29, 2013 9:45 am
Here is rc13:
http://www.mikrotik.com/download/share/ ... .0rc13.npk
http://www.mikrotik.com/download/share/ ... .0rc13.zip
For me it fixed issue that only happens when you disable or delete some simple queues - some (not all) other simple queues also stops working.
So i imagine that if you have dynamic simple queues you must have this problem.
If your simple queues are static and you do not plan to change them - you are fine.
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
infused
Re: RouterOS v6rc12
Sun Mar 31, 2013 9:07 am
So simple queues are/are not working in rc13? I have 34 day uptime on rc11, not going to change for awhile. Everythings humming along.
mdraca
Re: RouterOS v6rc12
Mon Apr 01, 2013 12:39 am
RB2011UAS-2HnD, RoS 6.0rc12
Wlan, TX power, card rates doesn't change current tx power.
Generation of hotspot pages does not work (only folders are created), also deleting everything from files and doing "Reset HTML" generates "copy failed(6)" error.
mdraca
Re: RouterOS v6rc12
Mon Apr 01, 2013 12:45 am
Drag file from desktop to winbox, after that open same file on PC and edit it, unable to save file because it has been locked by winbox. If this was intentional please remove this feature, editing hotspot html is a pain if you need to close winbox after every edit.
Arcticfox
Re: RouterOS v6rc12
Mon Apr 01, 2013 9:52 am
This kind of problem I've met on CCR with ROSv6rc12:
1. After making l2tp tunnel, and setting it up, I've found an impossibility to remove that tunnel.
2. Also CCR loses it's PPP profiles and it makes impossible to deactivate tunnel directly (by setting it's status to disable).
Then I go by 3 ways:
3. When I tryed to resetup tunnel profile, I've got a hanging webfig/cli to timeout:
[admin@MikroTik] > ppp profile add name="beeline-l2tp" change-tcp-mss=yes
action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
4. When I tryed to disable l2tp-client, I've got a next situation:
4.a It hangs at: [admin@MikroTik] > interface l2tp-client print
4.b After pressing Ctrl+C it prints:
0 R name="l2tp-beeline" max-mtu=1460 max-mru=1500 mrru=disabled
connect-to=195.14.38.42 user="user" password="password"
profile=(unknown) add-default-route=yes dial-on-demand=no allow=chap
4.c After direct trying to disable l2tp client directly:
[admin@MikroTik] > interface l2tp-client disable 0
Trying to reboot CCR causes:
[admin@MikroTik] > sys reboot
Reboot, yes? [y/N]:
y
system will reboot shortly
After 2 minutes: LCD prints "rebooting..."
After more 3 minutes, still "rebooting...".
10 minutes past: still "rebooting..."
I thing something wrong with l2tp module on CCR. Could you debug it? Or write me any workaround for a time to fix it?
On ROSv6rc11 I've met next bug:
after deleting NAT rule router fall in "kernel panic!" and reboots.
dorijan
Re: RouterOS v6rc12
Tue Apr 02, 2013 2:39 am
I have some bugs to report too...
6.0rc12(and maybe earlier versions too)
Users behind hotspot, but in IP bindings, type bypassed
access to some ip addressed are just forbidden, example:
C:\Users\User>ping www.facebook.com
Pinging star.c10r.facebook.com [31.13.81.23] with 32 bytes of data:
Reply from 10.168.157.18: Destination host unreachable.
Ping statistics for 31.13.81.23:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
but on mikrotik, it works ok:
[admin@mt-xxx] > ping 31.13.81.23
HOST SIZE TTL TIME STATUS
31.13.81.23 56 243 33ms
31.13.81.23 56 243 32ms
sent=3 received=3 packet-loss=0% min-rtt=32ms avg-rtt=32ms max-rtt=33ms
but if I reboot this mikrotik where hotspot is, everything will fork ok for 1-2 days...
maybe I have to do some tweaking to connection tracking?
also, I have in my firewall filters before hotspot:
1 chain=forward action=accept connection-state=related
2 chain=forward action=accept connection-state=established
4 ;;; invalid
chain=forward action=drop connection-state=invalid
indiaswara
Re: RouterOS v6rc12
Tue Apr 02, 2013 6:18 am
rc12 still have a bugs for atheros AR9287 Wireless Network Adapter rev.1
rpengineering
Re: RouterOS v6rc12
Tue Apr 02, 2013 3:55 pm
Dear All,
Excuse me for the new post with the same topic, but i've no answare.
I've problem also with rc12 on RB433ah with OSPF and MPLS configured, when the router boot and OSFP goes running the RB reboot with kernel failure.
i've tested it with different routerboards and the problem is the same.
BR
normis
Re: RouterOS v6rc12
Tue Apr 02, 2013 3:58 pm
please clarify what you mean exactly?
FiShYmAn
Re: RouterOS v6rc12
Tue Apr 02, 2013 10:24 pm
After upgrading to RC12 on my CCR I have had issues where one of the ethernet ports (ether11) just keeps turning off and then a few mins later turning back on, that specific port is configured as our up link port and is dialing BGP, etc over it - I have now rolled back to RC11 to see if it improves, I didn't see the issue on other other ports so perhaps it is related to the fact that it is locked at 100mbit full duplex instead of being auto or 1000mbit? The device plugged into that port is a Allied Telesys media Converter from our fibre supplier and must be locked to 100mbit to work properly.
Model: CCR1036-12G-4S
Edit: I am now also seeing this on ether6 even after the downgrade to RC11, ether6 has a cache server plugged into it, it is set to auto and negotiates a 1000mbit rate, this must be related to a throughput issue as these are my 2 primary ports, we often hit 100mbit download from our fibre on ether port 11 and a lot of this is routed to ether port 6 for caching.
rgunawans
Re: RouterOS v6rc12
Wed Apr 03, 2013 5:35 am
I just upgrade x86 DOM to 6rc12, here the list that didn't work in v6rc12
1. there's no P2P setting in Simple Queue (5.21 exists)
below is for v6rc12
2. Simple queue didn't work properly, every time change the setting, I have to DISABLE ALL simple queue, and ENABLE ALL, and it's work again. this never happen in 5.21
indiaswara
Re: RouterOS v6rc12
Wed Apr 03, 2013 6:55 am
hi normis
thanks for your respond
when ap-bridge mode is enabled, the access point shortly cant reached and not visible by client, and the router must be rebooted again to ap-bridge is back.
normis
Re: RouterOS v6rc12
Wed Apr 03, 2013 9:08 am
below is for v6rc12
p2p marking has to be done in mangle. then use packet mark to make new queue. this is new functionality of queues in v6
rgunawans
Re: RouterOS v6rc12
Wed Apr 03, 2013 9:12 am
below is for v6rc12
Thanks..
what about my problem no 2? I have to disable all simple queue and enable again to make active / run
normis
Re: RouterOS v6rc12
Wed Apr 03, 2013 9:16 am
we are investigating a queues related issue similar to yours. if you want, you can try v6rc13 where this issue is fixed. let us know if it helps:
rgunawans
Re: RouterOS v6rc12
Wed Apr 03, 2013 9:18 am
Thanks for your response, I'll try today and let you know
DirectX9
Re: RouterOS v6rc12
Wed Apr 03, 2013 12:05 pm
Still have problems with upload speed (real speed is about 100Mbit - through RB1100AHx2) - CCR 1036-12-4 WAN-Ethernet, LAN-SFP(Cisco WDM 1Gbit) maximum 30Mbit.
Download speed and routing works good.
And what is about 100Mbit Sfp modules to work with RB2011 and CCR?
P.S 03.04.2013 at 13:40 UTC+4 - have been tested CCR1036-12-4 with WAN ETHERNET and LAN ETNERNET (already not SFP) -results good. CCR hreally has a problem with fiber transport. Please correct if possible.
Also please add hardware or software support tothis SFP:
GIGALINK
GL-10T/R (1Gbps) GL-09T/R (100Mbps) - both are SINGLEMODE WDM 1310/1550
P.S On RC5 that's modules worked fine.
DirectX9
vasilaos
Re: RouterOS v6rc12
Wed Apr 03, 2013 12:38 pm
Hello
Any suggestion ?
Regards
Do you use Bridge ?
I had this problem in v6rc11. i was waiting for this fix. It seem has not been fixed
http://forum.mikrotik.com/viewtopic.php?f=2&t=70207
kirill
Re: RouterOS v6rc12
Wed Apr 03, 2013 4:47 pm
Can't add new 'ip firewall filters rule' with webfig in 6.0rc12 or 6.0rc13.
After OK or Apply pressing - switch to login page with ERROR: Internal Server Error
cma1kep
Re: RouterOS v6rc12
Wed Apr 03, 2013 9:05 pm
After updating CCR1036 to rc12:
I have got an issue, the following script became not working
:foreach i in=[/interface pppoe-server find] do={:if ([:len [/ip firewall address-list find address=[/ip address get value=network number=[/ip address find interface=[/interface pppoe-server  get $i name] ]] ]] = 0) do={ [/interface pppoe-server remove $i] };}
but script was working since Ros 5.24 to 6.0x, also each part of script work perfectly (like :put [/interface pppoe-server get 1 name];
:put [/ip address find interface=<test>] and etc..)
Any suggestions?
dominiaz
Re: RouterOS v6rc12
Wed Apr 03, 2013 10:43 pm
Does tx dropped frames on vlan has been fixed on rc13?
I have BGP x86 on 6.0rc12 (build 13.03.2013), after 14 days uptime i can see 18 000 tx dropped packets. Everything was fine on 5.24.
normis
Re: RouterOS v6rc12
Thu Apr 04, 2013 10:11 am
please clarify, where do you see dropped packets exactly? can you show the output ?
bbj
Re: RouterOS v6rc12
Thu Apr 04, 2013 12:43 pm
my rb 411u( and rb230 and sxt did the exact same thing... if you are fast enough and login very quickly, goto / system watchdog and disable the watchdog... you'll see a log entry that has some thing to the effect of" rebooted by watchdog event" ps i dd my upgrade via the dude beta3.. ps running dude in wine is a very dirty solution.this might motivate me to wite a few php scriptsto handle the upgrading that dude handles for me
normis
Re: RouterOS v6rc12
Thu Apr 04, 2013 12:47 pm
For any RB951G which are rebooting, please try this new firmware:
http://www.mikrotik.com/download/share/ ... _05_7a.fwf
(upload the file, then run "/system routerboard upgrade" command)
DirectX9
Re: RouterOS v6rc12
Thu Apr 04, 2013 6:13 pm
Hello Normis
May be for some other devices RB711UA, Groove2,Metal2,SXT2, RB2011, RB751G, RB751U you have most recent firmware than 3.02 we have now???
May be it helps RC12 work more stability on this devices?
DirectX9
natanielklug
Re: RouterOS v6rc12
Thu Apr 04, 2013 10:31 pm
Hello all,
We experienced problems while disabling PPPoE Servers on RB1100AHx2 running v6.0-rc12. I am attaching a autosupout.rif from the episode.
After that we downgraded it to v6.0-rc11 but now we have a bunch os stalled admin connections and the CPU load, because of console usage, is going too high.
How can I kick a stalled winbox connection? Reboot?
dominiaz
Re: RouterOS v6rc12
Thu Apr 04, 2013 10:54 pm
Do you want supout file or something else?
slech
Long time Member
Long time Member
Re: RouterOS v6rc12
Fri Apr 05, 2013 1:31 pm
Step 1
[admin@RB951G-2HnD] > system routerboard print
       routerboard: yes
             model: 951G-2HnD
  current-firmware: 3.04
  upgrade-firmware: 3.05
Step 2
[admin@RB951G-2HnD] > system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
firmware upgraded successfully, please reboot for changes to take effect!
Step 3
[admin@RB951G-2HnD] > system reboot
Reboot, yes? [y/N]:
y
Step 4
       routerboard: yes
             model: 951G-2HnD
  current-firmware: 3.05
But this doesn't work via Winbox. After reboot still 3.04
kirill
Re: RouterOS v6rc12
Fri Apr 05, 2013 3:12 pm
Does somebody have same problem?
tamahome
Re: RouterOS v6rc12
Fri Apr 05, 2013 3:23 pm
I'm testing the rc13 in x86 and the connection-bytes still doesn't work. Is this normal?
Blog.tamax.com.ar
Foro.tamax.com.ar
normis
Re: RouterOS v6rc12
Fri Apr 05, 2013 3:29 pm
please elaborate, where exactly are you seeing this issue? did you report it to support?
tamahome
Re: RouterOS v6rc12
Fri Apr 05, 2013 3:53 pm
it appears to work only upside down.
I'm using connection-bytes to mark heavy download traffic (tcp 80).
5 ;;; http_more100Mb
chain=prerouting action=mark-connection
new-connection-mark=http_more100M_conn passthrough=yes protocol=tcp
dst-port=80 connection-bytes=102400000-0
6 chain=prerouting action=mark-packet new-packet-mark=http_more100Mb
passthrough=no connection-mark=http_more100M_conn
7 ;;; http_100Mb
new-connection-mark=http_100Mb_conn passthrough=yes protocol=tcp
dst-port=80 connection-bytes=10240000-102400000
8 chain=prerouting action=mark-packet new-packet-mark=http_100Mb
passthrough=no connection-mark=http_100Mb_conn
9 ;;; http_to10M
chain=prerouting action=mark-connection new-connection-mark=http_10Mb_conn
passthrough=yes protocol=tcp dst-port=80 connection-bytes=1024000-10240000
10 chain=prerouting action=mark-packet new-packet-mark=http_10Mb passthrough=n>
11 ;;; http_1Mb
chain=prerouting action=mark-connection new-connection-mark=http_1Mb_conn
passthrough=yes protocol=tcp dst-port=80 connection-bytes=0-1024000
12 chain=prerouting action=mark-packet new-packet-mark=http_1Mb passthrough=no
If I orden them first the 1mb, then the 10mb, then the 100mb and then the more than 100mb. All the packets get caught in the first mangle. I don't know if this is normal but before, the packets which weight more than 1Mb passtrough to the mangle below. Now instead, all fall in the first http mangle and don't get pass.
Blog.tamax.com.ar
Foro.tamax.com.ar
normis
Re: RouterOS v6rc12
Fri Apr 05, 2013 3:57 pm
7 ;;; http_100Mb
9 ;;; http_to10M
11 ;;; http_1Mb
Please write to support, so this is officially checked by our experts.
tamahome
Re: RouterOS v6rc12
Fri Apr 05, 2013 4:02 pm
Ok, will do.
Blog.tamax.com.ar
Foro.tamax.com.ar
normis
Re: RouterOS v6rc12
I see it, thanks!
Felicitus
Re: RouterOS v6rc12
Fri Apr 05, 2013 5:11 pm
Got my 951G-2HnD yesterday, upgraded to 6r12 today.
When doing a frequency scan, the device resets itself. Log entry:
system,error,critical router was rebooted without proper shutdown by watchdog timer
elmer
Re: RouterOS v6rc12
Sun Apr 07, 2013 2:27 am
Upgrade firmware from menu System -> Routerboard -> Upgrade :)
Restore to factory defaults, then set up router again...
dominiaz
Re: RouterOS v6rc12
Mon Apr 08, 2013 8:42 am
Many people have the same tx errors on vlans and don`t want to use v6 anymore. Are you gonna to fix it soon?
jonescosmos
Re: RouterOS v6rc12
Sat Apr 13, 2013 3:31 pm
No !
This bug continues to happen in 6.0rc13. It is not fixed yet. ;)
jonescosmos
Re: RouterOS v6rc12
Tue Apr 16, 2013 12:20 pm
I noticed that the TX Rate and the Byte Out columns are not displaying any activity
jonescosmos
Re: RouterOS v6rc12
Tue Apr 16, 2013 12:22 pm
osvaldotcf
Re: RouterOS v6rc12
Sun Apr 28, 2013 4:21 am
+1
Yes, i put several backup and when i restore ... no tx rate on hotspot!
osvaldotcf
Re: RouterOS v6rc12
Sun Apr 28, 2013 4:23 am
Hello
Any suggestion ?
Regards
Do you use Bridge ?
+1 no tx rate
Diamond
Re: RouterOS v6rc12
Sun Jun 09, 2013 10:28 am
Good day!
I wrote above about router rebooting on rc12. So.
I have installed Dude4.0beta3 package on the device (rc11). Updating to rc12 brought to reboots. Router worked on rc11 before today.
Today I tried to upgrade to ROS6.0 release and the router began reboots again :D Next, router has netinstalled again for ROS6.0 - and all stayed ok! After this Dude4.0beta3 has installed and all work!
These all say that the dude package brought to reboots after upgrading a release, or the updating process goes wrongly=).
Users browsing this forum: Bing [Bot], Google [Bot], randomwalk and 148 guests
