AnaG
Link Public IP to Local IP's
Fri Mar 03, 2006 3:41 am
I have 32 public IP I want to link same public to local 3-4 IP's like this
This is 1 of my 32 public IP's
/ip address add address=10.20.0.101/32 interface=Public
/ip firewall nat add chain=dstnat dst-address=10.20.0.101 action=dst-nat \
to-addresses=192.168.0.41
/ip firewall nat add chain=srcnat src-address=192.168.0.41 action=src-nat \
to-addresses=10.20.0.101
Ok now I'd like to link same public IP 10.20.0.101 to local ip's 192.168.0.42
and 192.168.0.43
what shold I do
Thx
macgaiver
Fri Mar 03, 2006 8:27 am
It is much more simplier
place 1 public IP to the Public interface (like 10.20.0.101/24 i quess /32 is incorrect)
place 1 private IP to the Local interface (like 192.168.0.254/24)
/ ip firewall nat add chain=srcnat out-interface=Public action=masquerade
Add to your PCs gateway: 192.168.0.254
And you need to specify gateway for your router to (it will be 10.20.0.<something>)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
macgaiver
Fri Mar 03, 2006 8:30 am
AnaG
Fri Mar 17, 2006 2:23 pm
Ok I yesterday I recive Public ip's and by
http://www.mikrotik.com/docs/ros/2.9/ip/nat
I did it
but I have anader problem
when I enable web proxy when I do http://www.whatismyip.com/
it gives IP of router not IP assinged to client
i m not a expert there is something with nat rule if some one had same problem and resolved it pls past me the key for using webproxy with public ip's
Thx
sergejs
Fri Mar 17, 2006 2:33 pm
Router IP address will be shown, when you are using proxy (router as a proxy).
fatonk
Fri Mar 17, 2006 3:44 pm
Do you need to connect from Public network (Internet) to these local IPs ?
AnaG
Sat Mar 18, 2006 5:08 am
Yes i did this but when I enable web proxy Router IP address will be shown, you are right sergejs about (router as a proxy) is there a any way to fix this
sergejs
Sat Mar 18, 2006 8:29 pm
I suppose, one way access public networks without proxy.
Users browsing this forum: cndas and 132 guests
