mdraca
Central hotspot
Mon Apr 01, 2013 12:18 am
Hi, I'm trying to move all of my hotspots to one that will work centrally, that will leave current hotspots almost as dumb devices and central mikrotik will perform everything (landing page, radius auth, shaping). I know that can be accomplished using EOIP tunnels and that works great, problem is that I don't want to supply internet only from central location but every point should have its own internet connection (image).
Is this possible and if it is how?
Thanks.
samir494
Re: Central hotspot
Mon Apr 01, 2013 7:20 am
Mistry Samir
Unique and Different
India
9920670022
Give me more Karma
mdraca
Re: Central hotspot
Tue Apr 02, 2013 8:39 pm
Thanks for the link but that is not what I asked for, I want to disconnect users connecting to radio by using hotspot that is running on central router.
hidagar
Re: Central hotspot
Thu Oct 03, 2013 11:27 pm
Hi, I want to do the same, did you find the solution?
TonyJr
Re: Central hotspot
Fri Oct 04, 2013 4:41 am
Setup each hotspot as if individual hotspot devices.
Make one the 'master' and install userman
Configure as per wiki article for userman with remote hosts.
Then configure remote hosts to use 'master' for radius.
So all have own routes to internet, but authenticate users from central userman/ 'server'
In the wiki, some perfect example configurations. I am using them myself :)
Tony
Sent from my BlackBerry 9900 using Tapatalk
kraker
Re: Central hotspot
Mon Oct 14, 2013 11:51 am
you should follow attached file .Everything is inside the docs.Read this carefully..
best regards...
Users browsing this forum: Bing [Bot] and 71 guests
