MUM Europe 2020
rini
15KM LINK PTP which antena+radio do you recommend
Thu Apr 04, 2013 4:37 pm
hello I Want to create a link to transmit 80/80 Mbps of data. but i dont know which antenna to choose.
the problem is that in the first tower i have problems with 5Ghz band becouse there are 100 other antennas there and i have a lot of interfernce.
i tried with RF elements antenna 32dbi grid with pair of Metal 5SHPn in bridge mode
maximal throughtput is about 50/40 mbps
any idea ?
hipro5
Re: 15KM LINK PTP which antena+radio do you recommend
Thu Apr 04, 2013 10:39 pm
You get 40/50Mbps MAX in UDP testing or in TCP testing method?
At what Mbps are you locked at and what is your signal, Tx/Rx CCQ?
honzam
Thu Apr 04, 2013 10:49 pm
You can try MIMO http://en.jirous.com/antenna-5ghz/jrc-29ex_mimo
and rb711GA or rb911G
LAN, FTTx, Wireless. ISP operator
Caci99
Thu Apr 04, 2013 10:53 pm
I second honzam, pretty impressed until now with Jirous antennas.
-Toni-
Don't crash the ambulance, whatever you do
Users browsing this forum: rogerking1 and 102 guests
