MUM Europe 2020
shareisall
IPSec VPN between Routeros and Juniper, but get some errors
Sun Apr 07, 2013 7:30 am
The Errors shown in the image below:
Please help! What are the errors mean?
RouterOs v6rc12.
Juniper netscreen 500
joshaven
Re: IPSec VPN between Routeros and Juniper, but get some err
Mon Apr 08, 2013 2:04 am
IPSec can be a trick and its even worse when going between vendors. I would set it up between two mikrotiks first and get it working. Then try changing it to connect to the juniper. I know this is hardly help. I try to avoide IPSec unless needed.
Joshaven Potter
Consulting and Business Services Available http://joshaven.com
mistiq
Mon Apr 08, 2013 10:02 am
I have same problem between two mikrotik devices after upgrade to 6.0rc12
K.i.s.S.
joshaven
Mon Apr 08, 2013 2:34 pm
Give it a try with 5.24. I don't have any IPSec tunnels with 6 yet so I can only assume that it should work fine. My first thought is that you have probably isolated the issue a bit more. If you need me to look over your config screen shot the pages and email them to joshaven(at)dmcibb.net. I use skitch which is a free screen shot tool that allows me to easily redact private info.
Joshaven Potter
Users browsing this forum: Egert143, pe1chl and 164 guests
