MUM Europe 2020
gottin
bridge interfaces
Mon Mar 06, 2006 1:07 am
Hi guys. I have a problem setting up bridge interfaces in MT.
I'll start with explaining the topology:
____________________ _____
| s w i t c h | ----- | LAN |-----[ PC ] 192.168.1.1
| eth0
MT1=(wir ~ ~ ~ ~ wir)=MT2
192.168.1.2
My idea and goal is to bridge eth0 and "wir" interfaces of MT1 so it is a transparent device and as a result to have direct connection between PC and MT2. However, if I bridge eth0 and wir interfaces of MT1 - the switch and a small part of the LAN stops to function untill I "unbridge" the interfaces and reboot the switch. (Both wireless cards of the MTs are atheros)
10x in advance for any help and ideas where the problem is.
mag
Re: bridge interfaces
Mon Mar 06, 2006 9:43 am
"stops to function" is not very descriptive.
The radio on MT1 must not be in station mode for use in a bridge (its stated somewhere in the wireless manual)
It might be better using EoIP between the eth-interfaces of the MTs (or WDS) for a transparent bridge in your scenario.
sten
Forum Veteran
Forum Veteran
Mon Mar 06, 2006 1:17 pm
| eth0
192.168.1.2
You are effectivly creating a loop and the switch detects this.
Move along. Nothing to see here.
mag
Mon Mar 06, 2006 1:25 pm
@sten: where did you see a loop? i can't, sorry. sounds like one, though.
if a switch with STP is in use, it should close only the looping-port and show this as well.
sten
Forum Veteran
Forum Veteran
Mon Mar 06, 2006 2:09 pm
Not all switches follow 802.1D specification. Others employ dirty tricks or just undefined behaviour.
Users browsing this forum: DSK, erlinden, Ixam, j4c4k, MSN [Bot], Sob and 103 guests
