lousx
Give to local device public ip address (without nat)
Wed Apr 10, 2013 9:22 am
Have LAN address: 192.168.0.0/16
We have AS and the address pool: xxx.234.147.0/24
Configured bgp.
Configured dst-nat.
Everything works.
But there is one problem. We need to give the local device IP Address from xxx.234.147.0/24. for example xxx.234.147.12
How to set it up?
Sorry for my English.
lousx
Re: Give to local device public ip address (without nat)
Wed Apr 10, 2013 2:04 pm
Help me please!
lousx
Thu Apr 11, 2013 11:07 am
Heeeeeeeeeeeeelp!
nickshore
Thu Apr 11, 2013 11:34 am
Do you have another IP range for the WAN connection ? a /30 from your ISP ?
You can put an IP from the /24 block onto the LAN eg xxx.234.147.1/24
Then you can disable your NAT rule.
Then local devices can have an address in xxx.234.147.0/24 and use xxx.234.147.1/24 as their gateway.
Hope that helps
Nick.
Nick Shore MTCNA MTCWE MTCRE MTCINE MTCTCE
LinITX.com - MultiThread Consultants
Get your MikroTik RBs and Training: http://linitx.com/brand/mikrotik
Official UK MikroTik Distributor
IRC chan: #routerboard on irc.z.je (IPv4 and IPv6)
lousx
Fri Apr 12, 2013 8:21 am
Thank you.
But I want to use NAT and at the same time give the public ip to one device
vadyalex
Fri Apr 12, 2013 10:45 am
I suggest you to set the NAT and port-forward necessary port to target machine.
Cheers.
lousx
Mon Apr 15, 2013 9:34 am
I need to have a working station was only a public ip address.
Thanks.
rjickity
Mon Apr 15, 2013 12:25 pm
Take a subnet out of your range, create a vlan(assuming you are using a switch) address the vlan and then add your hosts to that vlan with an address in the subnet you made and a gateway of your router address you put on the vlan interface. A standard '3 leg perimeter' firewall type setup
Sent from my GT-I9100 using Tapatalk 2
Users browsing this forum: No registered users and 97 guests
