MUM Europe 2020
WirelessRudy
ROS sntp client update
Thu Apr 11, 2013 11:34 am
When is MT considering to improve their time stamp update.
It is so counterproductive if the time is only updated when you log into the rb the first time after a reboot.
How can you know what happened when?
Some routers are forced to reboot by watchdog, some are done so by a power cycle of the client. Only later I log in but than I can't see when actually happened what.....
Why can't ros not made to update the time the moment it reboots?
Show your appreciation of this post by giving me Karma! Thanks.
Rudy R. Puister
WISP operator based on MT routerboard & ROS.
ditonet
Forum Veteran
Forum Veteran
Re: ROS sntp client update
Thu Apr 11, 2013 12:13 pm
I've never noticed problem described by you.
Add logging for NTP
ros code
/system logging add action=memory disabled=no prefix="" topics=ntp,!packet
restart router, wait 20 minutes, then log-in and check NTP logs.
HTH,
Grzegorz | MTCNA, MTCRE, MTCSE | konsultacje MikroTik Warszawa
It is a book about a Spanish guy called Manual. You should read it. - Dilbert
Users browsing this forum: No registered users and 40 guests
