MUM Europe 2020
desty
Can do MASQUERADE but not SNAT
Tue Mar 07, 2006 1:04 am
I got problem...
I just install mikrotik @ my pc, 2 NIC, Public and Local. I got multiple Public IP on it and single Local IP. I want to share internet connection with my client, and locate different public ip fo each client.
the problem is.. i cant do SNAT but if I use MASQUERADE its working fine...
So wheres the problem is? I use mikrotik 2.8.26.
Thanks a lot.
[/b]
andrewluck
Forum Veteran
Forum Veteran
Tue Mar 07, 2006 9:46 am
You need to post some more information.
Regards
Andrew
desty
Tue Mar 07, 2006 2:45 pm
Regards
Andrew
Hum its like this...
i got mutiply ip ex. 64.65.66.210-64.65.66.222/28 on ether1
gateway 64.65.66.209
and i got local ip ex.192.168.0.1/32 on ether2
on my pcrouter with mikrotik...
my local ip connected to switch with another pc client ex. 192.168.0.2/32 192.168.0.3/32 and more...
i want to share internet connection to my local client, but because i had multiple public ip i want to specify which local ip go throught which ip public, like
192.168.0.2/32 to 64.65.66.211
192.168.0.3/32 to 64.65.66.212
like that,
so i use command like :
add src-address=192.168.0.2/32 out-interface=ether1 action=nat to-src-address=64.65.66.211
looks fine, but it wont work, my client cant connect to the internet.
but if i change action to MASQUERADE it working.
So where is the problem, somebody help me please...
Thank you so much.
Best Regards.
andrewluck
Forum Veteran
Forum Veteran
Tue Mar 07, 2006 8:34 pm
My src-nat rule for my LAN:
chain=srcnat out-interface=Internet src-address=192.168.1.0/24 action=src-nat to-addresses=x.x.x.x to-ports=0-65535
I'm natting for a class C but it works the same for a single IP address as well. Looks like you're missing the 'to-ports' bit.
Do you have connection tracking turned on?
Regards
Andrew
djape
Tue Mar 07, 2006 9:06 pm
add chain=srcnat out-interface=PublicInterface src-address=192.168.0.2/32 action=src-nat to-addresses=64.65.66.211 to-ports=0-65535
I have noticed by your post that you use version 2.8.x
Check if it's latest 2.8, I mean is it stable...
I hope you didn't post your real addresses :D
If yes, my advice is not to do that anymore.
Cheers..
I drink like a pirate and smoke like a hippie...
changeip
Tue Mar 07, 2006 9:10 pm
I think 2.8.26 and .27 we're the most stable in that version so he should be good. It's hard to try to support 2.8.x anymore because so many people have moved on : )
jarosoup
Long time Member
Long time Member
Tue Mar 07, 2006 10:34 pm
We have had some issues in the past with version 2.8.26 when the firewall is being used. This version is fine for bridges (or ap-bridges) but have stability issues with nat and firewall. Upgrade to 2.8.28 and see if this helps. 2.8.28 has been stable for us with NAT. We'll probably continue to use 2.8.28 until they fix some firewall issues in 2.9 :cry:
desty
Wed Mar 08, 2006 3:35 pm
Regards
Andrew
Hmmm...i just try to insert ports but its not working too... connection tracking turned on :(
Btw... of course its not my real ip :)
Another suggestion? i really need this :( my network over traffic...
andrewluck
Forum Veteran
Forum Veteran
Wed Mar 08, 2006 8:30 pm
From the manual:
masquerade is a special form of source NAT without need to specify to-addresses - outgoing interface address is used automatically
Check the syntax of your source nat rule as what I gave you was for 2.9. I can't remember as far back as 2.8. Especially, check that you're specifying the type of nat that you require.
Regards
Andrew
Users browsing this forum: Bing [Bot] and 44 guests
