eugenevdm
How do you see active PPP users using SNMP
Tue Mar 07, 2006 1:19 am
I would like some tips on how to see a list of active users using SNMP and a Linux PC. Can anyone help me? What command do I use and what is the MIB I should examine using this command?
The Snowball Effect
Superior Internet Solutions
meister
Sun Mar 12, 2006 2:41 am
You could get a list of the oid's from
/interface print oid
The problem you will have is getting the oids since they change dynamically.
eugenevdm
Sun Mar 12, 2006 11:07 am
The book mentions:
CISCO-AAA-SESSION-MIB
Note that this MIB is supported only when ppp package is installed. It reports both ppp and hotspot active users
enterprises.cisco.ciscoMgmt.ciscoAAASessionMIB.casnMIBObjects.casnActive.casnActiveTableEntries
enterprises.cisco.ciscoMgmt.ciscoAAASessionMIB.casnMIBObjects.casnActive.casnActiveTable.casnActiveEntry.casnSessionId
enterprises.cisco.ciscoMgmt.ciscoAAASessionMIB.casnMIBObjects.casnActive.casnActiveTable.casnActiveEntry.casnUserId
enterprises.cisco.ciscoMgmt.ciscoAAASessionMIB.casnMIBObjects.casnActive.casnActiveTable.casnActiveEntry.casnIpAddr
But I cannot get it working in Linux. Does someone has a simple way of checking this using Linux? Using 'snmpwalk' maybe?
fivenetwork
Mon Mar 13, 2006 2:16 pm
I too wanted to do this.
I am stuck at the following step.
Using Getif and the second last option MBrowser I obtained this entry
' enterprises.9.9.150.1.1.1.0 ' and on selecting this entry (amongst the many such obtained) i got this OID as the associated one
.1.3.6.1.4.1.9.9.150.1.1.1.0
I added this entry using the "Add to Graph" button on this page. Now on the last option Graph page, i am getting a graph listing the number of users connected in 5 sec intervals.
Now if someone can convert this info into some more meaningful graph and also with a history........
Users browsing this forum: alidamji, Bing [Bot], Jotne, pe1chl, topbanana and 65 guests
