MUM Europe 2020
FOV
VPN DOWN - After Upgrade
Tue Mar 07, 2006 1:03 pm
Hi Guys, I was on 2.9.5 a VPN vs Hotbrick.
After Upgrade, 2.9.13 the VPN was down.
Any changes on deamon?
my config:
[fvazquez@Nodo Pilar] ip ipsec policy> pri
Flags: X - disabled, D - dynamic, I - invalid
0 X src-address=192.168.0.0/24:any dst-address=192.168.1.0/24:any protocol=all action=encrypt level=require
ipsec-protocols=esp tunnel=yes sa-src-address=209.99.227.12 sa-dst-address=201.216.201.177 proposal=Hotbrick
manual-sa=none dont-fragment=clear
[fvazquez@Nodo Pilar] ip ipsec peer> pri
Flags: X - disabled
0 address=201.216.201.177/32:500 secret="abentus" generate-policy=no exchange-mode=main send-initial-contact=yes
proposal-check=obey hash-algorithm=md5 enc-algorithm=des dh-group=modp768 lifetime=1d lifebytes=0
[fvazquez@Nodo Pilar] ip ipsec proposal> pri
Flags: X - disabled
0 name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024
1 name="Hotbrick" auth-algorithms=md5 enc-algorithms=des lifetime=3m lifebytes=0 pfs-group=modp768
Any ideas?
mag
Tue Mar 07, 2006 2:29 pm
any entries in the log?
(why not update to 2.9.14?)
btw. 3 minute key-lifetime is very short.
FOV
Wed Mar 08, 2006 11:46 pm
Could be, but, till now, with the RB 520 is not available
The problem was, that the VPN was working OK till the upgrade.
I didn´t find the answer
Rgs,
Fernando
FOV
Thu Mar 09, 2006 12:28 am
Sorry, I forgot message on log
Remote Unknown after finalizing Phase 1
Fernando
andrewluck
Forum Veteran
Forum Veteran
Thu Mar 09, 2006 8:40 pm
Why is this policy showing disabled?
Regards
Andrew
FOV
Thu Mar 09, 2006 11:33 pm
Thx for your time, just in order to reduce the log.
On this moment is enabled, and the log file is telling Remote Unknown when is tryinng to establish phase I
FOV
Sat Mar 18, 2006 2:35 am
Hi Guys, thenks you very mutch for your support and answer.
After upgraded to 2.9.13 misteriously, VPN start to work.
A minimal answer telling me: Man, wait to the upgrade was to be enogth.
TNX AGAIN
csickles
Tue Mar 21, 2006 7:52 pm
One Pice of FYI...
I had 3 routers deployed with VPN to all three "legs"..
I had to upgrade one from 2.9.9 (I think) to 2.9.17..
VPN crashed... Once all routers upgraded to 2.9.17 VPN came back online...
(Oh what fun) but stable since..
Craig
Things that make you go "Hmmmmmmmm"...
Craig
Users browsing this forum: Baidu [Spider], gioalbert, MSN [Bot], nemoforum, sjafka, Sob and 110 guests
