Ivoshiee
How to make OpenVPN to push for more routes to the client?
Sun May 12, 2013 11:51 pm
I've managed to get an OpenVPN (ovpn) tunnel going between Fedora 17 and ROS v5.24, but the ROS is pushing only one route to the client side. I wonder how someone shall get the whole routing table to propagate over that tunnel? Currently I just add those routes by hand after the tunnel is up and running, but surely there is more elegant ways to accomplish that.
Sun May 12 23:32:55 2013 [A-VPN] Peer Connection Initiated with 1.2.3.4:1194
Sun May 12 23:32:58 2013 SENT CONTROL [A-VPN]: 'PUSH_REQUEST' (status=1)
Sun May 12 23:33:03 2013 SENT CONTROL [A-VPN]: 'PUSH_REQUEST' (status=1)
Sun May 12 23:33:09 2013 SENT CONTROL [A-VPN]: 'PUSH_REQUEST' (status=1)
Sun May 12 23:33:09 2013 PUSH: Received control message: 'PUSH_REPLY,route 192.168.255.0 255.255.255.248,ifconfig 192.168.255.4 192.168.255.1'
Sun May 12 23:33:09 2013 OPTIONS IMPORT: --ifconfig/up options modified
Sun May 12 23:33:09 2013 OPTIONS IMPORT: route options modified
Sun May 12 23:33:09 2013 ROUTE default_gateway=192.168.100.1
Sun May 12 23:33:09 2013 TUN/TAP device tun0 opened
Sun May 12 23:33:09 2013 TUN/TAP TX queue length set to 100
Sun May 12 23:33:09 2013 /sbin/ip link set dev tun0 up mtu 1500
Sun May 12 23:33:09 2013 /sbin/ip addr add dev tun0 local 192.168.255.4 peer 192.168.255.1
Sun May 12 23:33:09 2013 /sbin/ip route add 192.168.255.0/29 via 192.168.255.1
Sun May 12 23:33:09 2013 Initialization Sequence Completed
Ideally that route pushing should be routing table based, but I am fine by getting it to push over an arbitrary routes.
Ivoshiee
Re: How to make OpenVPN to push for more routes to the clien
Tue Jun 11, 2013 6:39 pm
Obviously that functionality is not implemented and the ROS OpenVPN support is limited by design. I've yet to read any reason why.
Users browsing this forum: No registered users and 80 guests
