maxcuban
RouterOs V 5.25. web proxy can't 'cache on disk'
Fri May 17, 2013 6:43 pm
I have installed RouterOs v5.25 and set up web proxy but when I select "Cache on Disk", it doesn't work yet when i deselect it, caching begins on the RAM.
My screen shot for configuration/setup and cache results are posted below.
Help needed please,
thanks in advance,
Max
maxcuban
Re: RouterOs V 5.25. web proxy can't 'cache on disk'
Fri May 17, 2013 6:46 pm
additional configuration screenshot
nishadul
Sat May 18, 2013 8:09 am
please enable "Serialize Connections" and "Always From Cache" from IP/WebProxy Settings/ General Tab, then try.
maxcuban
Tue May 21, 2013 3:03 pm
[quote="nishadul"
please enable "Serialize Connections" and "Always From Cache" from IP/WebProxy Settings/ General Tab, then try.[/quote]
I did but nothing happened. all this while i had sent a message to mikrotik support now they say i should upgrade to V6 but when i go to System --> Packages and check for updates it doesn't update it tells me my system is up to date.
I've downloaded the v6 both the update package aldd "All package" can you please tell me how i can update manually via winbox to v6 please? i don't want to do anything that willl ruin my license
thanks
tmorrison88
Thu Jun 06, 2013 11:27 pm
maxcuban you will need to go to mikrotik.com/download and grab the RouterOS v6 package from there for x86. You can choose all packages but I prefer to grab the official upgrade package plus anything additional ie your usermanager package.
When your file has downloaded to your computer, open your router via winbox. Pull up your files list. Drag and drop the RouterOS package from your computer into winbox. When the file has finished uploading reboot your device.
ekopde
Thu Aug 22, 2013 7:55 am
Hello, I have same problem like that ' web proxy can't cache on disk' and I just upgrade routerOS from 5.24 to 6.2 running well. But nothing happen with web proxy cache, still same like before. Anyone help me??? TB4
ekopde
Thu Aug 22, 2013 9:56 am
Hello, I have same problem like maxcuban. Web proxy cache running but cache on disk not run ( cache used=0). I use PC router and have update routerOS to 6.2 version but still same problem :( . Any sugestion ?
darvih
Sat Sep 21, 2013 10:41 am
stop web-proxy
1 - The first web-proxy clear cache button and then press the heml-rest
2 - go to the stores remove all web - proxy
3-add a new store With the following specifications:
name=webmaster
type=web-proxy
note=name store must same name cache admnistrator :?
cache admnistrator=name store :?
good luck :D
darvih
stop web-proxy
name=webmaster
type=web-proxy
good luck :D
darvih
Sat Sep 21, 2013 10:42 am
stop web-proxy
name=webmaster
type=web-proxy
cache admnistrator=name store :? :?
kgninfos
Fri Sep 27, 2013 4:15 pm
i am still not able to store cache on disk
i am using RB2011UAS RM and trying to store data on USB flash drive 8Gb capacity
EDIT: Repeating this process did worked fine
darvih
Wed Oct 09, 2013 3:59 am
format mikrosd and check drive in store menu,,and set all config in finish reboot routerboard
ekopde
Tue Nov 19, 2013 5:29 am
@ darvih, thanks in work :D
shovon
Tue Nov 26, 2013 12:21 pm
No need to format drive or update RouterOS. The key part is, cache administrator's name must have to be the same as Store name. And a reboot is necessary before re-enabling web-proxy.
Pls. follow these steps:
1. Disable proxy & clear cache. No need to reset HTML.
2. Go to: System>>Stores, click "+" sign, Type a new Store name (this must have to be the same as cache administrator's name). Select type as "web-proxy", check "Active". This will make old web-proxy store "backup". Remove the old one. Click apply and ok.
3. Here come's the most important part, that is, reboot your router before re-enabling web proxy.
4. Go to System>>Stores, here you'll see the new web-proxy store as "backup". Make sure there is no other "web-proxy" type store.
5. Go to IP>>Web Proxy. Type cache administrator's name, same as store name you have given. Check "cache on disk", and set Max. cache size as "unlimited". Now check web-proxy "Enabled", apply and ok.
6. Go to System>>Stores, you'll now see the "web-proxy" drive as "active".
7. Visit some web sites, click "cache contents" in web proxy settings to see it's working or not.
Users browsing this forum: Bing [Bot], Google [Bot] and 220 guests
