MUM Europe 2020
onnoossendrijver
Huawei E352 3G dongle works on 6rc14!
Sun May 19, 2013 7:17 pm
Maybe this is the wrong place for this.. I got the Huawei E352 USB 3G dongle working. According to the Wiki page it is not supported. http://wiki.mikrotik.com/wiki/Supported ... e#3G_cards
I only had to remove the PIN and change the Data-channel to '2'. Info-channel is '0'.
[admin@MikroTik] /interface ppp-client> info 0
modem-status: ready
pin-status: no password required
functionality: full
manufacturer: huawei
model: E352
revision: 21.106.01.00.55
serial-number: 354234044235916
current-operator: T-Mobile NL
access-technology: 3G
signal-strengh: -95 dBm
frame-error-rate: n/a
[admin@MikroTik] > ping interface=ppp-out1  www.nu.nl
HOST                                     SIZE TTL TIME  STATUS
62.69.166.18                               56 240 304ms
62.69.166.18                               56 240 264ms
    sent=3 received=3 packet-loss=0% min-rtt=264ms avg-rtt=277ms max-rtt=304ms
I know.. the signalstrength is crap :)
Linux/network engineer: ITIL, LPI1, CCNA R+S, CCNP R+S, JNCIA, JNCIS-SEC
Iliasla
Re: Huawei E352 3G dongle works on 6rc14!
Tue Jan 07, 2014 12:02 pm
I confirm. I tried to run Huawei E352b (by russian 3G provider Megafon) on the x86 system (s775 Core E8200 & Intel P43) under ROS 6.7 and it work properly with the settings info & data channels = 0. On my RB493G, unfortunately, I was unable to test the modem due to the lack of regular power on the USB port and USB POE injector and stable 5V power supply was not at hand.
[admin@MikroTik_x86] > interface ppp-client print
0 name="ppp-megafon" max-mtu=1500 max-mru=1500 mrru=disabled port=usb4 data-channel=0 info-channel=0
modem-status: ready
functionality: full
model: E352b
revision: 21.158.23.00.209
serial-number: 8601100xxxxxxxx
current-operator: MegaFon (cellid 7e57)
signal-strengh: -93 dBm
RogerWilco
Wed Jan 08, 2014 12:30 am
The Wiki is community edited. You can edit the page yourself and fill in the details if you like to help others.
normis
Wed Jan 08, 2014 11:23 am
Thanks, I have updated the wiki with this info.
RogerWilco
Thu Jan 09, 2014 1:09 am
While you're at it Normis, you could remove the fibs that other fellow added about the 320U working with the LTE interface providing the modem has the drivers on it ;)
normis
Thu Jan 09, 2014 9:20 am
hmm, could you please clarify what should be removed and why? I don't think I saw that post.
RogerWilco
Fri Jan 24, 2014 4:50 am
Here: http://wiki.mikrotik.com/wiki/Supported ... _LTE_cards
Some fellow has said that the Sierra Wireless 320U works with the LTE interface
Vendor/product id pair should be 0x0f3d/0x68AA and DirectIP firmware loaded on the modem.
This is totally incorrect. Yes, it is detected as an LTE device but it does not work - only with the PPP interface.
uldis
Fri Jan 24, 2014 10:04 am
what exactly doesn;t work with that sierra 320u using lte interface?
Maybe you need to use newer firmware.
Also there is always an option to load the ppp mode by setting the ignore-direct-ip-firmware setting under port firmware menu.
RogerWilco
Sat Jan 25, 2014 3:45 am
In the log, using the LTE interface, the modem gets stuck trying to send AT+CPIN?. Discussed here: http://forum.mikrotik.com/viewtopic.php ... hilit=320u
Newest firmware for both the modem and the router don't make a difference. PPP mode is fine but you can't access the full modem speed.
Iliasla
Thu Mar 06, 2014 8:14 pm
Quite a lot of information about this modem has a forum
http://4pda.ru/forum/index.php?showtopic=315938
(russian language)
Users browsing this forum: No registered users and 134 guests
