HaPe
The most unblockable tunneling protocol?
Sun May 19, 2013 11:24 pm
Which from tunneling protocol supported by Mikrotik Routeros is the most difficult to block using firewalls?
Gre, openvpn, pptp, sstp, l2tp/ipsec, gre, vpls?
In anticipation on new The Dude release.
tomaskir
Trainer
Trainer
Re: The most unblockable tunneling protocol?
Mon May 20, 2013 12:02 am
SSTP, since it works on TCP 443, same as HTTPS.
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
Ivoshiee
Tue May 21, 2013 10:29 am
Are you kidding? If you tie your ability to detect a protocol merely to a port then you are gravely mistaken.
tomaskir
Trainer
Trainer
Tue May 21, 2013 10:49 am
If you block TCP 443, then you block every internet website that uses HTTPS.
Also, every tunneling protocol has a default port that it uses, if you dont like that, change it.
Also, you will find that most restrictive networks block ALL protocols and ports, other then well known ones.
Users browsing this forum: No registered users and 67 guests
