atu
【Bug】6.xx Queue tree Bug
Sat May 25, 2013 6:45 am
RouterOS version:6.5/6.4/6.3/6.2/6.1/6.0 /6.0 rc14
Hardware:CCR1016-12G/RB951-2n/
last tested at 10/27/2013 with new version 6.5,still bugged
I am using HTB+PCQ queue tree,it works fine in 3.xx~5,xx but not works at Version 6.xx.
1.as title, everytime i changed things in queue tree,queue tree don't response any more.
2.as attached file,Down2 Down3...Down8 can not work at same time.(queue tree don't work with parcket markets )
today i tried update my RB951-2n from version 5.25 to 6.1,found same bug. the queue tree is work fine with version 4.xx~5.xx,but not work with version 6.xx.
as u can see in the jpg file,i disabled the queue tree because it doesn't work .
niekiem
Re: 【Bug】6.xx Queue don't response when u change anything in
Wed May 29, 2013 8:39 am
Hi.
On 6.0, Winbox does not show queue trees after making a change, but the Terminal does. This was not an issue in the 6.0 RC11 version the CCR shipped with as far as i know.. Any advice on this?
BinaryCrash
Wed May 29, 2013 10:54 pm
Hi.
Same here.
I restarted and it showed back.
But now can't even stay with skype, keep disconnecting.
version 6.0 CCR-1016-12G
atu
Wed Jun 05, 2013 9:40 am
any suggestion??
help plz!
sathishsa
Sat Jun 08, 2013 12:46 pm
I bought the CCR-1036-12g-4s, it was shipped with 6RC11 and has some issues and i upgraded to 6.0 .
Queue are not working at alla and it was showing some times and sometimes not, please fix and release the next version
Thanks,
Sathish
belairtech
Mon Jun 10, 2013 5:11 am
Same Here... Queues are slo-mo.
Win The Sky!
sathishsa
Mon Jun 10, 2013 1:46 pm
Some thing fixed , but still some bugs in other sections , guys try it and let me know if it works for you
Download and install:
http://www.mikrotik.com/download/share/ ... le-6.1.npk
http://www.mikrotik.com/download/share/ ... es_6.1.zip
Sathish
atu
Tue Jun 11, 2013 4:18 am
is it beta version?
atu
Re: 【Bug】6.xx Queue tree Bug
Wed Jun 12, 2013 3:17 pm
Chupaka
Wed Jun 12, 2013 4:25 pm
what exactly is not working for you? please explain in details what you expect and what you see
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Stillhard
Wed Jun 12, 2013 5:11 pm
Just to make sure:
'global-in', 'global-out', or 'global-total' are replaced with 'global' in v6
atu
Thu Jun 13, 2013 5:47 am
Just to make sure:
im sure changed global-out to global man.
atu
Thu Jun 13, 2013 5:48 am
today i updated my CCR1016-12G to version6.1 . The bug is not fixed yet.
atu
Thu Jun 13, 2013 6:11 am
sry for my poor english.
2 WAN named:WAN_CNC and WAN_TEL
1 LAN named:ether6_LAN
in mangle, i marked conn for P2P,Games etc... then marked packets upload/download like game_down_cnc,game_up_cnc,small_down_tel.. etc
u can see the Bytes/Packets counters are working fine and numbers is changing in mangle, but in queue tree with packet mark, they don't work at same time (packet counter read 0),only 1 of quere trees has packets reading at same time in winbox .
i attached mangle and queue tree,plz hlp me . those setting is working good in version 3.xx~5.xx
Chupaka
Thu Jun 13, 2013 5:06 pm
all your queues in Queue Tree are disabled - is it normal?..
atu
Sat Jun 15, 2013 9:12 am
because they can not work,so i disabled them.
Chupaka
Sun Jun 16, 2013 7:26 pm
I don't understand... is it working better when they are disabled?.. because all screenshots and all configs you show do not expose anything unusual - when queues are disabled, they don't work
jahatkeh10
Sun Jun 16, 2013 8:24 pm
Funny question and perception. :lol:
What he means is he disabled it because it didn't work. If you want to try it, just simply copy the config and enabled it.
brrushi
Mon Jun 17, 2013 11:10 am
Almost same situation also for me.
CCR router, with v6.1, queue tree does not work well, with mangle.
I have some mangle rules in forward chain and queue tree with PCQ.
Some queues process packets slower than others, the buffer has more packets. If I change priority and give better priority to the problematic queue it works.
The problem is with the queue which has more traffic than others.
The router processes about 400Mbit of traffic and processor is 12%.
It is not a bandwidth problem, i have not put anything Limit-Max or Limit-At.
Maybe something is wrong with the priorities in queue tree.
atu
Wed Jun 26, 2013 1:52 am
this is what i mean "can not work at same time",in my case, only one bewteen(Down1~down8) have packets if u changed their priority or Limit at or something.
IPANetEngineer
Trainer
Trainer
Sat Jun 29, 2013 3:26 pm
Just experienced a crash on 6.1 x86 while disabling/re-enabling queue trees. When I re-enabled the queue tree, the router stopped forwarding traffic and ended up rebooting itself. It came back after about 5 minutes with no user intervention. This is on a MaxxWave MW-RM1300-i7 router.
I see a lot of forums posts about bugs in the queue trees in 6.1....what's the latest on this?
Global - MikroTik Support & Consulting - English | Francais | Español | Portuguese +1 855-645-7684
https://iparchitechs.com/services/mikro ... l-support/ mikrotiksupport@iparchitechs.com
atu
Mon Jul 22, 2013 2:07 am
any suggestion or help???
kyob
Fri Aug 02, 2013 10:20 am
I have the same problem.
My queue just stop receiving data from mangle and for example yesterday works fine but today all queues show 0 "zero".
Log does not report any error.
When I edit something in options in queue tree for specific mangle then it's start to work.
Would it be fixed in 6.2?
Puffer
Fri Aug 09, 2013 8:30 am
Any feedback on this ?
I upgraded my RB450G to 6.2 yesterday and the 46 queue trees are not visible in Winbox.
If I go to new terminal console they are all there and working.
Nothing shows in the queue tree window in Winbox, even if I add a new queue tree in V6.2.
Have tried disabling them all and re-enabling them in console and rebooted several times, no luck.
Puffer
atu
Sat Oct 05, 2013 3:30 am
still bugged in version 6.4 !
Bi11
Sat Oct 12, 2013 6:20 pm
Ditto happened to me.
After I upgraded routeros to 6.4 from 5.2, the queue tree shows all zeros and is not working at all.
I guess the bug is happened when calculating the max-limit for each queue.
parent max-limit=5m
+- child max-limit not set
is not working. may be it was treated the max-limit to 0.
So I set the max-limit
parent max-limit=5m
+- child max-limit=10m
It works, so I added another
parent max-limit=5m
+- child max-limit=10m priority=4
+- child max-limit=10m priority=3
It still works, but when I added one more
parent max-limit=5m
+- child max-limit=10m priority=2
It falls to zeros, was not working any more.
So I disabled the last one that I've added
parent max-limit=5m
X +- child max-limit=10m priority=2
The tree still not working.
So I disabled all children, and re-enable the first one
It works.
It seem that something wrong while calculating the max-limit for each queue.
If an error occurred, the whole tree dies.
After I tried many times to reset configuration, add queue one by one, disable and enable the queue tree, the RouterOS hangs.
The router was no response. Maybe a kernel failure?
So I downgrade to 5.2 immediately, it is not stable for 6.4 .
But I really need the new Queue model in v6. In v6 we can mark in input chain and have no worries on queuing a packet twice.
Hope it will be fixed soon.
Bi11
Mon Oct 14, 2013 6:10 pm
I can't upgrade the main gateway again for the screen shot.
So I installed a x86 version and the bug can be easily reproduced.
/queue tree
add max-limit=5M name=queue1 packet-mark=A,B parent=global queue=default
add name=queue2 packet-mark=A parent=queue1 queue=default
add name=queue3 packet-mark=B parent=queue1 queue=default
/ip firewall mangle
add action=mark-packet chain=prerouting new-packet-mark=A
I connect the router with ip winbox, so you can see the packet in the mangle rule are increasing time by time.
s1. It works fine with one child queue.
s2. The queue counter stopped when I enabled the second child queue
s3. It is not working even when I disabled the second child.
Bi11
Mon Oct 14, 2013 6:23 pm
s4, It back to normal when I disabled all the children
s5, Enable one child is OK
s6, Again, the counter stopped when I enabled the second
Bi11
Mon Oct 14, 2013 6:29 pm
s7, Really, the packet in mangle increased but the queue counter were froze.
This a temporary test router so here is the supout.
supout.zip
Chupaka
Tue Oct 15, 2013 12:14 am
Bi11, please write to support@mikrotik.com (at least with a link to your posts)
Bi11
Tue Oct 15, 2013 7:26 pm
I've already sent the email when I finished detailed post here.
The support says
Thanks, problem repeated, we are working on a fix.
Should be included in release of v6.5
Thanks.
atu
Sun Oct 27, 2013 4:45 pm
still bugged in version 6.5
macgaiver
Thu Oct 31, 2013 4:20 pm
You are doing something wrong. Bug reported by Bi11 is fixed long time ago.
my queue tree is working fine and i can't see anyone else complaining lately, so jump to conclusions yourself
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
bmeiojas
Fri Nov 01, 2013 7:58 pm
Ok, If ATU do something wrong, I do it the same wrong because i have the same problem and can't find a solution.
Simply... simple queue does not work
Bernardo Meiojas
bernardo@bwnet.com.ar
engineertote
Fri Nov 01, 2013 10:45 pm
atu , you can go for simple queue with V6 .
Regards
Ahmed
Ahmed
MTCNA , MTCTCE , MTCRE , MTCINE
Bi11
Tue Nov 05, 2013 9:59 am
My queue tree is working too since ROS 6.5
Bi11
Tue Nov 05, 2013 10:12 am
You can add/enable queue tree rules one by one, and watch the counters.
Once the counters frozen, the rule just added has the most suspicious to cause it.
Clean/disable all queues and try again, and try to find the minimal rules that can reproduce the issue.
Print the rules here and MK team can fix it very efficiently once they can reproduce it too.
I'm a software engineer so I'm sure this is a efficient way to fix a uncommon bug.
djdrastic
Wed Nov 06, 2013 9:13 am
While we've had a multitude of issues with 6 , qtree's luckily haven't been one of them . Most of our 5.xx rules with a little bit of tweaking (no global in , global out) import and run successfully.
Asket
Mon Dec 16, 2013 2:37 pm
Can you show your queue tree settings?
Users browsing this forum: erlinden, HakanE, omnet and 114 guests
