any success stories in that new v6.1 feature?
for me, Wireshark shows that client connects to api-ssl port, sends SSLv2 Hello, and server ACKs that packet and then keeps silence - no data from it at all
any comments, MT Support?..
SSL_CTX * ctx; SSL * ssl; ctx = SSL_CTX_new(TLSv1_client_method()); SSL_CTX_set_cipher_list(ctx, "ADH AES256 SHA "); ssl = SSL_new(ctx); bio = BIO_new_socket(sock, BIO_NOCLOSE); SSL_set_bio(ssl, bio, bio); SSL_connect(ssl);then you can use SSL_read/SSL_write to do your bidding. Just check if you have blocking or non-blocking socket (in example code variable "sock" that is initialized previously as TCP/IP socket fd)
# sslscan 192.168.200.48:443
_
___ ___| |___ ___ __ _ _ __
/ __/ __| / __|/ __/ _` | '_ \
\__ \__ \ \__ \ (_| (_| | | | |
|___/___/_|___/\___\__,_|_| |_|
Version 1.8.2
http://www.titania.co.uk
Copyright Ian Ventura-Whiting 2009
Testing SSL server 192.168.200.48 on port 443
Supported Server Cipher(s):
$ sslscan 192.168.88.1:8729 |grep Accepted
Accepted TLSv1 256 bits AES256-SHA
Accepted TLSv1 256 bits CAMELLIA256-SHA
Accepted TLSv1 168 bits DES-CBC3-SHA
Accepted TLSv1 128 bits AES128-SHA
Accepted TLSv1 128 bits SEED-SHA
Accepted TLSv1 128 bits CAMELLIA128-SHA
Accepted TLSv1 128 bits RC4-SHA
Accepted TLSv1 128 bits RC4-MD5
Accepted TLSv1 56 bits DES-CBC-SHA
Accepted TLSv1 256 bits ADH-AES256-SHA
Accepted TLSv1 256 bits ADH-CAMELLIA256-SHA
Accepted TLSv1 168 bits ADH-DES-CBC3-SHA
Accepted TLSv1 128 bits ADH-AES128-SHA
Accepted TLSv1 128 bits ADH-SEED-SHA
Accepted TLSv1 128 bits ADH-CAMELLIA128-SHA
Accepted TLSv1 128 bits ADH-RC4-MD5
Accepted TLSv1 56 bits ADH-DES-CBC-SHA
[root@info ~]# sslscan 192.168.200.48:8729
_
Version 1.8.2
Testing SSL server 192.168.200.48 on port 8729
Failed SSLv2 168 bits DES-CBC3-MD5
Failed SSLv2 128 bits IDEA-CBC-MD5
Failed SSLv2 128 bits RC2-CBC-MD5
Failed SSLv2 128 bits RC4-MD5
Failed SSLv2 56 bits DES-CBC-MD5
Failed SSLv2 40 bits EXP-RC2-CBC-MD5
Failed SSLv2 40 bits EXP-RC4-MD5
Failed SSLv3 256 bits DHE-DSS-AES256-GCM-SHA384
Failed SSLv3 256 bits DHE-RSA-AES256-GCM-SHA384
Failed SSLv3 256 bits DHE-RSA-AES256-SHA256
Failed SSLv3 256 bits DHE-DSS-AES256-SHA256
Failed SSLv3 256 bits DHE-RSA-CAMELLIA256-SHA
Failed SSLv3 256 bits DHE-DSS-CAMELLIA256-SHA
Failed SSLv3 256 bits ADH-AES256-GCM-SHA384
Failed SSLv3 256 bits ADH-AES256-SHA256
Failed SSLv3 256 bits ADH-CAMELLIA256-SHA
Failed SSLv3 256 bits AES256-GCM-SHA384
Failed SSLv3 256 bits AES256-SHA256
Failed SSLv3 256 bits CAMELLIA256-SHA
Failed SSLv3 256 bits PSK-AES256-CBC-SHA
Failed SSLv3 168 bits EDH-RSA-DES-CBC3-SHA
Failed SSLv3 168 bits EDH-DSS-DES-CBC3-SHA
Failed SSLv3 168 bits ADH-DES-CBC3-SHA
Failed SSLv3 168 bits DES-CBC3-SHA
Failed SSLv3 168 bits PSK-3DES-EDE-CBC-SHA
Failed SSLv3 168 bits KRB5-DES-CBC3-SHA
Failed SSLv3 168 bits KRB5-DES-CBC3-MD5
Failed SSLv3 128 bits DHE-DSS-AES128-GCM-SHA256
Failed SSLv3 128 bits DHE-RSA-AES128-GCM-SHA256
Failed SSLv3 128 bits DHE-RSA-AES128-SHA256
Failed SSLv3 128 bits DHE-DSS-AES128-SHA256
Failed SSLv3 128 bits DHE-RSA-SEED-SHA
Failed SSLv3 128 bits DHE-DSS-SEED-SHA
Failed SSLv3 128 bits DHE-RSA-CAMELLIA128-SHA
Failed SSLv3 128 bits DHE-DSS-CAMELLIA128-SHA
Failed SSLv3 128 bits ADH-AES128-GCM-SHA256
Failed SSLv3 128 bits ADH-AES128-SHA256
Failed SSLv3 128 bits ADH-SEED-SHA
Failed SSLv3 128 bits ADH-CAMELLIA128-SHA
Failed SSLv3 128 bits AES128-GCM-SHA256
Failed SSLv3 128 bits AES128-SHA256
Failed SSLv3 128 bits SEED-SHA
Failed SSLv3 128 bits CAMELLIA128-SHA
Failed SSLv3 128 bits IDEA-CBC-SHA
Failed SSLv3 128 bits PSK-AES128-CBC-SHA
Failed SSLv3 128 bits KRB5-IDEA-CBC-SHA
Failed SSLv3 128 bits KRB5-IDEA-CBC-MD5
Failed SSLv3 128 bits ADH-RC4-MD5
Failed SSLv3 128 bits RC4-SHA
Failed SSLv3 128 bits RC4-MD5
Failed SSLv3 128 bits PSK-RC4-SHA
Failed SSLv3 128 bits KRB5-RC4-SHA
Failed SSLv3 128 bits KRB5-RC4-MD5
Failed SSLv3 56 bits EDH-RSA-DES-CBC-SHA
Failed SSLv3 56 bits EDH-DSS-DES-CBC-SHA
Failed SSLv3 56 bits ADH-DES-CBC-SHA
Failed SSLv3 56 bits DES-CBC-SHA
Failed SSLv3 56 bits KRB5-DES-CBC-SHA
Failed SSLv3 56 bits KRB5-DES-CBC-MD5
Failed SSLv3 40 bits EXP-EDH-RSA-DES-CBC-SHA
Failed SSLv3 40 bits EXP-EDH-DSS-DES-CBC-SHA
Failed SSLv3 40 bits EXP-ADH-DES-CBC-SHA
Failed SSLv3 40 bits EXP-DES-CBC-SHA
Failed SSLv3 40 bits EXP-RC2-CBC-MD5
Failed SSLv3 40 bits EXP-KRB5-RC2-CBC-SHA
Failed SSLv3 40 bits EXP-KRB5-DES-CBC-SHA
Failed SSLv3 40 bits EXP-KRB5-RC2-CBC-MD5
Failed SSLv3 40 bits EXP-KRB5-DES-CBC-MD5
Failed SSLv3 40 bits EXP-ADH-RC4-MD5
Failed SSLv3 40 bits EXP-RC4-MD5
Failed SSLv3 40 bits EXP-KRB5-RC4-SHA
Failed SSLv3 40 bits EXP-KRB5-RC4-MD5
Failed SSLv3 0 bits NULL-SHA256
Failed SSLv3 0 bits NULL-MD5
Failed TLSv1 256 bits DHE-DSS-AES256-GCM-SHA384
Failed TLSv1 256 bits DHE-RSA-AES256-GCM-SHA384
Failed TLSv1 256 bits DHE-RSA-AES256-SHA256
Failed TLSv1 256 bits DHE-DSS-AES256-SHA256
Failed TLSv1 256 bits DHE-RSA-CAMELLIA256-SHA
Failed TLSv1 256 bits DHE-DSS-CAMELLIA256-SHA
Failed TLSv1 256 bits ADH-AES256-GCM-SHA384
Failed TLSv1 256 bits ADH-AES256-SHA256
Failed TLSv1 256 bits ADH-CAMELLIA256-SHA
Failed TLSv1 256 bits AES256-GCM-SHA384
Failed TLSv1 256 bits AES256-SHA256
Failed TLSv1 256 bits CAMELLIA256-SHA
Failed TLSv1 256 bits PSK-AES256-CBC-SHA
Failed TLSv1 168 bits EDH-RSA-DES-CBC3-SHA
Failed TLSv1 168 bits EDH-DSS-DES-CBC3-SHA
Failed TLSv1 168 bits ADH-DES-CBC3-SHA
Failed TLSv1 168 bits DES-CBC3-SHA
Failed TLSv1 168 bits PSK-3DES-EDE-CBC-SHA
Failed TLSv1 168 bits KRB5-DES-CBC3-SHA
Failed TLSv1 168 bits KRB5-DES-CBC3-MD5
Failed TLSv1 128 bits DHE-DSS-AES128-GCM-SHA256
Failed TLSv1 128 bits DHE-RSA-AES128-GCM-SHA256
Failed TLSv1 128 bits DHE-RSA-AES128-SHA256
Failed TLSv1 128 bits DHE-DSS-AES128-SHA256
Failed TLSv1 128 bits DHE-RSA-SEED-SHA
Failed TLSv1 128 bits DHE-DSS-SEED-SHA
Failed TLSv1 128 bits DHE-RSA-CAMELLIA128-SHA
Failed TLSv1 128 bits DHE-DSS-CAMELLIA128-SHA
Failed TLSv1 128 bits ADH-AES128-GCM-SHA256
Failed TLSv1 128 bits ADH-AES128-SHA256
Failed TLSv1 128 bits ADH-SEED-SHA
Failed TLSv1 128 bits ADH-CAMELLIA128-SHA
Failed TLSv1 128 bits AES128-GCM-SHA256
Failed TLSv1 128 bits AES128-SHA256
Failed TLSv1 128 bits SEED-SHA
Failed TLSv1 128 bits CAMELLIA128-SHA
Failed TLSv1 128 bits IDEA-CBC-SHA
Failed TLSv1 128 bits PSK-AES128-CBC-SHA
Failed TLSv1 128 bits KRB5-IDEA-CBC-SHA
Failed TLSv1 128 bits KRB5-IDEA-CBC-MD5
Failed TLSv1 128 bits ADH-RC4-MD5
Failed TLSv1 128 bits RC4-SHA
Failed TLSv1 128 bits RC4-MD5
Failed TLSv1 128 bits PSK-RC4-SHA
Failed TLSv1 128 bits KRB5-RC4-SHA
Failed TLSv1 128 bits KRB5-RC4-MD5
Failed TLSv1 56 bits EDH-RSA-DES-CBC-SHA
Failed TLSv1 56 bits EDH-DSS-DES-CBC-SHA
Failed TLSv1 56 bits ADH-DES-CBC-SHA
Failed TLSv1 56 bits DES-CBC-SHA
Failed TLSv1 56 bits KRB5-DES-CBC-SHA
Failed TLSv1 56 bits KRB5-DES-CBC-MD5
Failed TLSv1 40 bits EXP-EDH-RSA-DES-CBC-SHA
Failed TLSv1 40 bits EXP-EDH-DSS-DES-CBC-SHA
Failed TLSv1 40 bits EXP-ADH-DES-CBC-SHA
Failed TLSv1 40 bits EXP-DES-CBC-SHA
Failed TLSv1 40 bits EXP-RC2-CBC-MD5
Failed TLSv1 40 bits EXP-KRB5-RC2-CBC-SHA
Failed TLSv1 40 bits EXP-KRB5-DES-CBC-SHA
Failed TLSv1 40 bits EXP-KRB5-RC2-CBC-MD5
Failed TLSv1 40 bits EXP-KRB5-DES-CBC-MD5
Failed TLSv1 40 bits EXP-ADH-RC4-MD5
Failed TLSv1 40 bits EXP-RC4-MD5
Failed TLSv1 40 bits EXP-KRB5-RC4-SHA
Failed TLSv1 40 bits EXP-KRB5-RC4-MD5
Failed TLSv1 0 bits NULL-SHA256
Failed TLSv1 0 bits NULL-MD5
Prefered Server Cipher(s):
[root@info ~]#
_
Version 1.8.2
_
Version 1.8.2
Testing SSL server 192.168.88.1 on port 8729
Failed SSLv3 256 bits ECDHE-RSA-AES256-GCM-SHA384
Failed SSLv3 256 bits ECDHE-ECDSA-AES256-GCM-SHA384
Failed SSLv3 256 bits ECDHE-RSA-AES256-SHA384
Failed SSLv3 256 bits ECDHE-ECDSA-AES256-SHA384
Rejected SSLv3 256 bits ECDHE-RSA-AES256-SHA
Rejected SSLv3 256 bits ECDHE-ECDSA-AES256-SHA
Rejected SSLv3 256 bits SRP-DSS-AES-256-CBC-SHA
Rejected SSLv3 256 bits SRP-RSA-AES-256-CBC-SHA
Rejected SSLv3 256 bits DHE-RSA-AES256-SHA
Rejected SSLv3 256 bits DHE-DSS-AES256-SHA
Rejected SSLv3 256 bits DHE-RSA-CAMELLIA256-SHA
Rejected SSLv3 256 bits DHE-DSS-CAMELLIA256-SHA
Rejected SSLv3 256 bits AECDH-AES256-SHA
Rejected SSLv3 256 bits SRP-AES-256-CBC-SHA
Rejected SSLv3 256 bits ADH-AES256-SHA
Rejected SSLv3 256 bits ADH-CAMELLIA256-SHA
Failed SSLv3 256 bits ECDH-RSA-AES256-GCM-SHA384
Failed SSLv3 256 bits ECDH-ECDSA-AES256-GCM-SHA384
Failed SSLv3 256 bits ECDH-RSA-AES256-SHA384
Failed SSLv3 256 bits ECDH-ECDSA-AES256-SHA384
Rejected SSLv3 256 bits ECDH-RSA-AES256-SHA
Rejected SSLv3 256 bits ECDH-ECDSA-AES256-SHA
Rejected SSLv3 256 bits AES256-SHA
Rejected SSLv3 256 bits CAMELLIA256-SHA
Rejected SSLv3 168 bits ECDHE-RSA-DES-CBC3-SHA
Rejected SSLv3 168 bits ECDHE-ECDSA-DES-CBC3-SHA
Rejected SSLv3 168 bits SRP-DSS-3DES-EDE-CBC-SHA
Rejected SSLv3 168 bits SRP-RSA-3DES-EDE-CBC-SHA
Rejected SSLv3 168 bits EDH-RSA-DES-CBC3-SHA
Rejected SSLv3 168 bits EDH-DSS-DES-CBC3-SHA
Rejected SSLv3 168 bits AECDH-DES-CBC3-SHA
Rejected SSLv3 168 bits SRP-3DES-EDE-CBC-SHA
Rejected SSLv3 168 bits ADH-DES-CBC3-SHA
Rejected SSLv3 168 bits ECDH-RSA-DES-CBC3-SHA
Rejected SSLv3 168 bits ECDH-ECDSA-DES-CBC3-SHA
Rejected SSLv3 168 bits DES-CBC3-SHA
Failed SSLv3 128 bits ECDHE-RSA-AES128-GCM-SHA256
Failed SSLv3 128 bits ECDHE-ECDSA-AES128-GCM-SHA256
Failed SSLv3 128 bits ECDHE-RSA-AES128-SHA256
Failed SSLv3 128 bits ECDHE-ECDSA-AES128-SHA256
Rejected SSLv3 128 bits ECDHE-RSA-AES128-SHA
Rejected SSLv3 128 bits ECDHE-ECDSA-AES128-SHA
Rejected SSLv3 128 bits SRP-DSS-AES-128-CBC-SHA
Rejected SSLv3 128 bits SRP-RSA-AES-128-CBC-SHA
Rejected SSLv3 128 bits DHE-RSA-AES128-SHA
Rejected SSLv3 128 bits DHE-DSS-AES128-SHA
Rejected SSLv3 128 bits DHE-RSA-SEED-SHA
Rejected SSLv3 128 bits DHE-DSS-SEED-SHA
Rejected SSLv3 128 bits DHE-RSA-CAMELLIA128-SHA
Rejected SSLv3 128 bits DHE-DSS-CAMELLIA128-SHA
Rejected SSLv3 128 bits AECDH-AES128-SHA
Rejected SSLv3 128 bits SRP-AES-128-CBC-SHA
Rejected SSLv3 128 bits ADH-AES128-SHA
Rejected SSLv3 128 bits ADH-SEED-SHA
Rejected SSLv3 128 bits ADH-CAMELLIA128-SHA
Failed SSLv3 128 bits ECDH-RSA-AES128-GCM-SHA256
Failed SSLv3 128 bits ECDH-ECDSA-AES128-GCM-SHA256
Failed SSLv3 128 bits ECDH-RSA-AES128-SHA256
Failed SSLv3 128 bits ECDH-ECDSA-AES128-SHA256
Rejected SSLv3 128 bits ECDH-RSA-AES128-SHA
Rejected SSLv3 128 bits ECDH-ECDSA-AES128-SHA
Rejected SSLv3 128 bits AES128-SHA
Rejected SSLv3 128 bits SEED-SHA
Rejected SSLv3 128 bits CAMELLIA128-SHA
Rejected SSLv3 128 bits ECDHE-RSA-RC4-SHA
Rejected SSLv3 128 bits ECDHE-ECDSA-RC4-SHA
Rejected SSLv3 128 bits AECDH-RC4-SHA
Rejected SSLv3 128 bits ADH-RC4-MD5
Rejected SSLv3 128 bits ECDH-RSA-RC4-SHA
Rejected SSLv3 128 bits ECDH-ECDSA-RC4-SHA
Rejected SSLv3 128 bits RC4-SHA
Rejected SSLv3 128 bits RC4-MD5
Rejected SSLv3 56 bits EDH-RSA-DES-CBC-SHA
Rejected SSLv3 56 bits EDH-DSS-DES-CBC-SHA
Rejected SSLv3 56 bits ADH-DES-CBC-SHA
Rejected SSLv3 56 bits DES-CBC-SHA
Rejected SSLv3 40 bits EXP-EDH-RSA-DES-CBC-SHA
Rejected SSLv3 40 bits EXP-EDH-DSS-DES-CBC-SHA
Rejected SSLv3 40 bits EXP-ADH-DES-CBC-SHA
Rejected SSLv3 40 bits EXP-DES-CBC-SHA
Rejected SSLv3 40 bits EXP-RC2-CBC-MD5
Rejected SSLv3 40 bits EXP-ADH-RC4-MD5
Rejected SSLv3 40 bits EXP-RC4-MD5
Rejected SSLv3 0 bits ECDHE-RSA-NULL-SHA
Rejected SSLv3 0 bits ECDHE-ECDSA-NULL-SHA
Rejected SSLv3 0 bits AECDH-NULL-SHA
Rejected SSLv3 0 bits ECDH-RSA-NULL-SHA
Rejected SSLv3 0 bits ECDH-ECDSA-NULL-SHA
Rejected SSLv3 0 bits NULL-SHA
Rejected SSLv3 0 bits NULL-MD5
Failed TLSv1 256 bits ECDHE-RSA-AES256-GCM-SHA384
Failed TLSv1 256 bits ECDHE-ECDSA-AES256-GCM-SHA384
Failed TLSv1 256 bits ECDHE-RSA-AES256-SHA384
Failed TLSv1 256 bits ECDHE-ECDSA-AES256-SHA384
Rejected TLSv1 256 bits ECDHE-RSA-AES256-SHA
Rejected TLSv1 256 bits ECDHE-ECDSA-AES256-SHA
Rejected TLSv1 256 bits SRP-DSS-AES-256-CBC-SHA
Rejected TLSv1 256 bits SRP-RSA-AES-256-CBC-SHA
Rejected TLSv1 256 bits DHE-RSA-AES256-SHA
Rejected TLSv1 256 bits DHE-DSS-AES256-SHA
Rejected TLSv1 256 bits DHE-RSA-CAMELLIA256-SHA
Rejected TLSv1 256 bits DHE-DSS-CAMELLIA256-SHA
Rejected TLSv1 256 bits AECDH-AES256-SHA
Rejected TLSv1 256 bits SRP-AES-256-CBC-SHA
Failed TLSv1 256 bits ECDH-RSA-AES256-GCM-SHA384
Failed TLSv1 256 bits ECDH-ECDSA-AES256-GCM-SHA384
Failed TLSv1 256 bits ECDH-RSA-AES256-SHA384
Failed TLSv1 256 bits ECDH-ECDSA-AES256-SHA384
Rejected TLSv1 256 bits ECDH-RSA-AES256-SHA
Rejected TLSv1 256 bits ECDH-ECDSA-AES256-SHA
Rejected TLSv1 256 bits AES256-SHA
Rejected TLSv1 256 bits CAMELLIA256-SHA
Rejected TLSv1 168 bits ECDHE-RSA-DES-CBC3-SHA
Rejected TLSv1 168 bits ECDHE-ECDSA-DES-CBC3-SHA
Rejected TLSv1 168 bits SRP-DSS-3DES-EDE-CBC-SHA
Rejected TLSv1 168 bits SRP-RSA-3DES-EDE-CBC-SHA
Rejected TLSv1 168 bits EDH-RSA-DES-CBC3-SHA
Rejected TLSv1 168 bits EDH-DSS-DES-CBC3-SHA
Rejected TLSv1 168 bits AECDH-DES-CBC3-SHA
Rejected TLSv1 168 bits SRP-3DES-EDE-CBC-SHA
Rejected TLSv1 168 bits ECDH-RSA-DES-CBC3-SHA
Rejected TLSv1 168 bits ECDH-ECDSA-DES-CBC3-SHA
Rejected TLSv1 168 bits DES-CBC3-SHA
Failed TLSv1 128 bits ECDHE-RSA-AES128-GCM-SHA256
Failed TLSv1 128 bits ECDHE-ECDSA-AES128-GCM-SHA256
Failed TLSv1 128 bits ECDHE-RSA-AES128-SHA256
Failed TLSv1 128 bits ECDHE-ECDSA-AES128-SHA256
Rejected TLSv1 128 bits ECDHE-RSA-AES128-SHA
Rejected TLSv1 128 bits ECDHE-ECDSA-AES128-SHA
Rejected TLSv1 128 bits SRP-DSS-AES-128-CBC-SHA
Rejected TLSv1 128 bits SRP-RSA-AES-128-CBC-SHA
Rejected TLSv1 128 bits DHE-RSA-AES128-SHA
Rejected TLSv1 128 bits DHE-DSS-AES128-SHA
Rejected TLSv1 128 bits DHE-RSA-SEED-SHA
Rejected TLSv1 128 bits DHE-DSS-SEED-SHA
Rejected TLSv1 128 bits DHE-RSA-CAMELLIA128-SHA
Rejected TLSv1 128 bits DHE-DSS-CAMELLIA128-SHA
Rejected TLSv1 128 bits AECDH-AES128-SHA
Rejected TLSv1 128 bits SRP-AES-128-CBC-SHA
Failed TLSv1 128 bits ECDH-RSA-AES128-GCM-SHA256
Failed TLSv1 128 bits ECDH-ECDSA-AES128-GCM-SHA256
Failed TLSv1 128 bits ECDH-RSA-AES128-SHA256
Failed TLSv1 128 bits ECDH-ECDSA-AES128-SHA256
Rejected TLSv1 128 bits ECDH-RSA-AES128-SHA
Rejected TLSv1 128 bits ECDH-ECDSA-AES128-SHA
Rejected TLSv1 128 bits AES128-SHA
Rejected TLSv1 128 bits SEED-SHA
Rejected TLSv1 128 bits CAMELLIA128-SHA
Rejected TLSv1 128 bits ECDHE-RSA-RC4-SHA
Rejected TLSv1 128 bits ECDHE-ECDSA-RC4-SHA
Rejected TLSv1 128 bits AECDH-RC4-SHA
Rejected TLSv1 128 bits ECDH-RSA-RC4-SHA
Rejected TLSv1 128 bits ECDH-ECDSA-RC4-SHA
Rejected TLSv1 128 bits RC4-SHA
Rejected TLSv1 128 bits RC4-MD5
Rejected TLSv1 56 bits EDH-RSA-DES-CBC-SHA
Rejected TLSv1 56 bits EDH-DSS-DES-CBC-SHA
Rejected TLSv1 56 bits DES-CBC-SHA
Rejected TLSv1 40 bits EXP-EDH-RSA-DES-CBC-SHA
Rejected TLSv1 40 bits EXP-EDH-DSS-DES-CBC-SHA
Rejected TLSv1 40 bits EXP-ADH-DES-CBC-SHA
Rejected TLSv1 40 bits EXP-DES-CBC-SHA
Rejected TLSv1 40 bits EXP-RC2-CBC-MD5
Rejected TLSv1 40 bits EXP-ADH-RC4-MD5
Rejected TLSv1 40 bits EXP-RC4-MD5
Rejected TLSv1 0 bits ECDHE-RSA-NULL-SHA
Rejected TLSv1 0 bits ECDHE-ECDSA-NULL-SHA
Rejected TLSv1 0 bits AECDH-NULL-SHA
Rejected TLSv1 0 bits ECDH-RSA-NULL-SHA
Rejected TLSv1 0 bits ECDH-ECDSA-NULL-SHA
Rejected TLSv1 0 bits NULL-SHA
Rejected TLSv1 0 bits NULL-MD5
SSL Certificate:
admin@MikroTik] > sy routerboard print
routerboard: yes
model: 951-2n
serial-number: DDDDDDDDDDDD
current-firmware: 3.02
upgrade-firmware: 3.08
[admin@MikroTik] > sy resource print
uptime: 2m52s
version: 6.1rc1
build-time: May/30/2013 09:54:26
free-memory: 9.9MiB
total-memory: 32.0MiB
cpu: MIPS 24Kc V7.4
cpu-count: 1
cpu-frequency: 350MHz
cpu-load: 1%
free-hdd-space: 108.6MiB
total-hdd-space: 128.0MiB
write-sect-since-reboot: 1092
write-sect-total: 115888
bad-blocks: 0.1%
architecture-name: mipsbe
board-name: RB951-2n
platform: MikroTik
$ sslscan 192.168.88.1:443 |grep Accepted
yep, it would be niceif you can make this accessible over the network, i could try to connect to it or any other router.
openssl s_client -host 192.168.88.1 -port 8729 -cipher ADH-AES256-SHA
10:21:09 system,info,account user admin logged in from 1000::b8b4:aa7f:f966:7877:c87a:c08 via api
10:21:09 system,info address added by admin
10:21:09 system,info address removed by admin
10:21:09 system,info,account user admin logged out from 1000::b8b4:aa7f:f966:7877:c87a:c08 via api
10:22:59 system,info filter rule added by admin
10:23:13 system,info,account user admin logged in from 1000::b8b4:aa7f:f966:7877:e85b:1308 via api
10:23:13 system,info address added by admin
10:23:13 system,info address removed by admin
10:23:13 system,info,account user admin logged out from 1000::b8b4:aa7f:f966:7877:e85b:1308 via api
bash-3.2# sslscan --tls1 10.0.1.3:8729 | grep Accepted
