I am running routeros 5.21 and recently I found out I can't run the speedtest on this site. http://www.speedtest.com.hk/en/index.htm
The windows version will let you download a binary to test the speed. The Mac version is actually an app run on OSX. None of those would work when I connect thru routeros. The speed test program would just timeout. The speed test works when I directly connect without the router though.
I wonder what is the proper way to troubleshoot using logging in routeros for these type of problems? Thanks.
