MUM Europe 2020
spoiler
How to avoid dst-nat masquing origin IP address...
Wed Mar 15, 2006 1:11 pm
I have a dst-nat rule that redirects connections to the untrusted interface on port 21 to the internal ip where ftp server resides, obviously to port 21.
The problem is that logs in the ftp server use to reflect the internal IP address of the router as the ftp session origin.
Is there a way to avoid this and keep the remote IP address of the session as the origin to keep the logs useful?
RULES (some ommited):
[admin@IMPRINTSA] ip firewall nat> print
1 chain=srcnat src-address=10.154.24.0/24
dst-address=10.33.0.0/16 action=accept
2 chain=dstnat in-interface=ADSL protocol=udp
dst-port=20 action=dst-nat
to-addresses=10.154.24.117 to-ports=20
3 chain=dstnat in-interface=ADSL protocol=tcp
dst-port=21 action=dst-nat
to-addresses=10.154.24.117 to-ports=21
7 chain=dstnat in-interface=WIRELESS protocol=udp
8 chain=dstnat in-interface=WIRELESS protocol=tcp
13 chain=srcnat action=masquerade
Txs!
mag
Wed Mar 15, 2006 1:36 pm
AFAIK no, thats simply the way NAT works.
yancho
Wed Mar 15, 2006 4:26 pm
Change
to
chain=srcnat out-interface=ADSL action=masquerade
spoiler
Wed Mar 15, 2006 8:23 pm
I have used many other reverse nat devices (ci$co,netscreen,...) and they do not act this way...
About the post from yancho, I think that should not solve the problem as the rule you specify is the outgoing one. In fact, i need it that way because of an "auto-swapping" default route that swings from one external interface to the other.
eflanery
Wed Mar 15, 2006 9:28 pm
Your rule:
Will match everything.
Since you can't match on outgoing interface, due to your routing, just match on the IPs you want to MASQ:
chain=srcnat src-address=10.154.24.0/24 action=masquerade
--Eric
spoiler
Fri Mar 17, 2006 5:05 pm
Your rule:
--Eric
Txs alot, that really solved the problem!
Users browsing this forum: AdiTane, bobobobo, dubyab, Google [Bot], MSN [Bot], netserv, oskarsk and 131 guests
