kgninfos
ROS v6.1 RB2011UAS-RM touch screen issue
Tue Jun 18, 2013 8:24 pm
Hi
after upgrade to V6.1 the lcd of touch screen is not working properly
i am not able to slide between interface graphs
can any one figure out the issue??
w0lt
Re: ROS v6.1 RB2011UAS-RM touch screen issue
Wed Jun 19, 2013 2:35 am
I have the same problem.. Moves a bit, then the screen locks up. Everything else seems ok, but have to power-down or reboot to start the process all over again. Weird...
-tp
MTCNA - 2011
" The Bitterness of Poor Quality Remains Long After the Sweetness of Low Price is Forgotten "
normis
Wed Jun 19, 2013 10:04 am
did you try "recalibrate"?
kgninfos
Wed Jun 19, 2013 10:10 am
yes i tried it twice
after each calibrate it works for some time then back to old state
normis
Wed Jun 19, 2013 11:25 am
can you make a "lcd screenshot" when the screen hangs and doesn't move?
can you also make a supout.rif file at the moment when you do this?
kgninfos
Wed Jun 19, 2013 3:21 pm
do i have to take an image of lcd with camera??
kgninfos
Wed Jun 19, 2013 5:13 pm
i did a full reset of the device and re configured and now it's working perfectly
but normis please have a look at ticket 2013061766000953 regarding packet marking
normis
Thu Jun 20, 2013 11:10 am
the LCD menu has a screenshot option
ros code
[admin@mikrotik] > lcd take-screenshot
kgninfos
Thu Jun 20, 2013 3:53 pm
as i told above after reset it's working fine
but i think the upload tx rate of WAN interface is showing wrong rate both on graph and in interface status
please refer to ticket 2013061866000997
kgninfos
Thu Jun 20, 2013 7:17 pm
admins please close the ticket above
i have found the problem
there was an ddos attack to my router
Users browsing this forum: No registered users and 94 guests
