MUM Europe 2020
mp3turbo2
n-streme v13 possible bug : not restricting to certain speed
Mon Aug 30, 2004 4:44 pm
hello,
I could be wrong... when I select supported-rates-a/g=6,9,12,18,24,36Mbps on BOTH sides of link, I expect there to be maximum 36Mbps and not more. 5km link, -62dB signal, in /interface wireless registration print interval=1 quite often jumps OVER (!) 36Mbps, both 48Mbps and 54Mbps are seen very frequently. I thought when I select maximum Supported (not basic) rate 36 and not more, there shouldn't be more than 36... right?
v2.8.13, n-streme v13. Standard driver not tested.
Anyone observed this ? Anyone could verify ?
thnx, mp3turbo.
dorijan
Mon Aug 30, 2004 5:11 pm
I did not test, but I would like to know how nst13 is performing? did you use turbo mode and how is it working?
also does when you select b/g mode, does b stations see it?
daniel
Mon Aug 30, 2004 6:15 pm
You should also set rate-set=configured
I found ot this option and indeed it helps get long distance links work better. I know the Atheros protocol is supposed to handle all the speed shifts etc, but it really does not perform well.
Daniel
mp3turbo2
Tue Aug 31, 2004 7:59 am
pretty well. It doesn't do miracles, but that's not expected :)
which one? Forget G-Turbo in urban areas, it requires completely clean environment, so... living room would do it :) A-Turbo is usable more... nobody knows until when.
I don't know, didn't try. But you definitely can't connect to nstreme AP without nstreme client, that leaves you only one choice: mikrotik. No standard B or G radio / CPE / etc. will be ever able to connect to nstreme mikrotik AP, that's obvious because Nstreme is proprietary protocol of MTik.
oh men, am I really dumb? Of course, I have default there, I will try this one today evening. But I have the feeling that -59dB signal is sufficient for 54Mbps operation and when I didn't have restriction to 36Mbps on client and AP, I ALWAYS had 54Mbps in monitor. Restricting to 36Mbps on both sides brought that down to 36, but not always - as I said, there are jumps above 36.
yeah, we don't live in world of miracles... :)
bye, mp3turbo.
daniel
Thu Sep 02, 2004 12:16 pm
Sorry, I meant the MikroTik driver is supposed to do the speed shifts.
I too had similar problem with strong signal level and poor performance at 54Mbps. Might be related to the higher bandwidth usage.
Users browsing this forum: No registered users and 98 guests
