MUM Europe 2020
arpadffy
IPv6 does not work after the upgrade
Mon Jun 24, 2013 3:33 pm
I have recently upgraded to 6.1 (from 6.1 beta something ) and I experienced the very same behaviour like earlier with IPv6 during earlier upgrades. I dare not to say from what version but for sure it existed during the 5.x versions.
The use case is the following:
- I use he.net ipv6 tunnel that is set up correctly and works perfect
/interface 6to4 add comment="Hurricane Electric IPv6 Tunnel Broker" disabled=no local-address=83.250.119.8 mtu=1280 name=sit1 remote-address=216.66.80.90
/ipv6 route add comment="" disabled=no distance=1 dst-address=2000::/3 gateway=2001:470:27:5b6::1 scope=30 target-scope=10
/ipv6 address add address=2001:470:27:5b6::2/64 advertise=yes disabled=no eui-64=no interface=sit1
- after the upgrade the sit interface shows outgoing traffic, but no incoming. The remote gw is not reachable. Disabling/enabling the interface does not help. The reboot does not help either.
- after several hours I make a reboot and suddenly the ipv6 traffic flows perfect like before the upgrade.
- This happens after every upgrade.
I do not run some core business on that he.net ipv6 tunnel, but i can imagine if somebody else does this is a critical issue.
Also it might happen with other sit interfaces too.
Could you please investigate.
Thank you.
Regards,
Z
khn
Re: IPv6 does not work after the upgrade
Mon Jul 01, 2013 12:55 pm
Same problem here, ran in to this after upgrading to 6.1 from 5.2. I haven't had the time to investigate it yet.
khn
Mon Jul 01, 2013 11:23 pm
Same problem here, but I haven't yet had the time to investigate it.
arpadffy
Sun Sep 15, 2013 7:29 pm
after 6.4 upgrade the sit1 tunnel does not work (even waiting for few hours)
arpadffy
Wed Sep 18, 2013 9:04 am
I think I find a pattern.
If there is no outbound traffic while the tunnel is negotiated during boot, it will work, but if there is a high IPv6 outgoing traffic while the tunnel is not established yet - for some reason the packets go out Tx>0 but Rx=0
I solved it on a simple way: Unplug the local-master port. Make a cold reboot of the RB and when everything is up and functional, plug back the local-master and voila it works.
I would appreciate if somebody could be fix this issue.
...as long the network is not IPv6 critical - it has a low prio, but more and more use IPv6 and I am missing also the "dancing kame".
Thank you.
Regards,
Z
Users browsing this forum: No registered users and 108 guests
