weiquan571
Vlan and dhcp problems
Tue Jul 09, 2013 5:38 am
I want to assign two VLANS , vlan 100 and vlan 200. intereface ethernet 2 will have both vlans and it is for hotspot. interface ethernet 3 would have vlan 100 and interface ethernet 4 would have vlan 200. However after configuring the vlans , putting vlans on bridge , assigning dhcp servers on the bridges , the interfaces would not get the ip address from the dhcp server. What did i do wrong?
CelticComms
Re: Vlan and dhcp problems
Tue Jul 09, 2013 8:00 pm
Are the DHCP servers showing as valid status? Maybe upload your config - output from /export compact.
Interlynx | Networking and Information Security Consultants & Trainers | Email: routerlynx@gmail.com
BGP | EIGRP | OSPF | MPLS | Firewall | VPN | IPsec | Multicast | QOS | IPv4/6 | STP | VLAN | PON | AE | M2M | and more!
Rudios
Forum Veteran
Forum Veteran
Tue Jul 09, 2013 8:09 pm
If you mean that your ether interfaces do not get an address, that's obvious. If that is what you want you should setup DHCP client.
Testing setup with: 2 x RB750UP | 2 x RB750GL | 1 x RB951G-2HnD | 1 x RB2011UiAS-IN
weiquan571
Wed Jul 10, 2013 4:41 am
i added the interfaces to the bridges together with the vlan. Now the problem is the vlan is not working as i can ping from vlan 100 to vlan 200.
[admin@MikroTik] > /export compact
# jan/02/1970 00:09:00 by RouterOS 6.1
# software id = A3ZI-34IN
add l2mtu=1594 name=bridge1
add l2mtu=1594 name=bridge2
/interface vlan
add interface=ether2 l2mtu=1594 name="vlan 200i" vlan-id=200
add interface=ether3 l2mtu=1594 name=vlan100 vlan-id=100
add interface=ether4 l2mtu=1594 name=vlan200 vlan-id=200
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m \
mac-cookie-timeout=3d
add name=pool1 ranges=192.168.100.2-192.168.100.254
add name=pool2 ranges=192.168.200.2-192.168.200.254
add address-pool=pool1 disabled=no interface=bridge1 name=dhcp1
add address-pool=pool2 disabled=no interface=bridge2 name=dhcp2
/tool user-manager customer
add backup-allowed=yes disabled=no login=admin password="" \
paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no \
permissions=owner signup-allowed=no time-zone=-00:00
add backup-allowed=yes disabled=no login=MikroTik password=qwerty \
/tool user-manager profile
add name=hotspot name-for-users="" override-shared-users=off owner=MikroTik \
price=0 starts-at=logon validity=0s
/tool user-manager profile limitation
add address-list="" download-limit=0B group-name="" ip-pool="" name="1hr Limit" \
transfer-limit=0B upload-limit=0B uptime-limit=1h
add bridge=bridge1 interface=vlan100
add bridge=bridge2 interface=vlan200
add bridge=bridge2 interface=ether4
add bridge=bridge2 interface="vlan 200i"
add bridge=bridge2 interface=ether2
add address=192.168.100.1/24 interface=bridge1 network=192.168.100.0
add address=192.168.200.1/24 interface=bridge2 network=192.168.200.0
add address=192.168.100.0/24 dns-server=192.168.100.1 gateway=192.168.100.1
add address=192.168.200.0/24 dns-server=192.168.200.1 gateway=192.168.200.1
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set vlan200 disabled=yes display-time=5s
set vlan100 disabled=yes display-time=5s
set "vlan 200i" disabled=yes display-time=5s
set bridge1 disabled=yes display-time=5s
set bridge2 disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
/tool user-manager profile profile-limitation
add from-time=0s till-time=23h59m59s weekdays=\
sunday,monday,tuesday,wednesday,thursday,friday,saturday
add from-time=0s limitation="1hr Limit" profile=hotspot till-time=23h59m59s \
weekdays=sunday,monday,tuesday,wednesday,thursday,friday,saturday
/tool user-manager router
add coa-port=1700 customer=MikroTik disabled=no ip-address=127.0.0.1 log=\
auth-fail name=router1 shared-secret=123 use-coa=no
/tool user-manager user
add customer=MikroTik disabled=no name=guest password=guest shared-users=1 \
wireless-enc-algo=none wireless-enc-key="" wireless-psk="
kraker
Wed Jul 10, 2013 10:47 am
What kind of access point are you using? It should have ssıd mapping features with vlan...Also where is your hotspot stay? on vlan or eth2?
weiquan571
Wed Jul 10, 2013 12:36 pm
Help ! I need a full guide to configure VLAN with RB750 without an external switch.
CelticComms
Wed Jul 10, 2013 3:23 pm
Yes it will route between the VLANs because it is a router and by default it will route all connected networks. You can change that behaviour by adding filters in the forward chain in IP Firewall.
Users browsing this forum: No registered users and 63 guests
