MUM Europe 2020
DarkMind
2GB limit
Fri Mar 24, 2006 12:18 pm
I'm trying to upload a single file with over 2GB file size via FTP to MT. It starts to upload but when reaches 2GB the router disconnects me. I have more than 10GB free space. MT version is 2.9.18. What is the problem.
cmit
Fri Mar 24, 2006 1:16 pm
Why the heck would you want to upload such a large file TO a router (!) ??? :shock:
Best regards,
Christian Meis
DarkMind
Fri Mar 24, 2006 5:16 pm
I'm using routerOS installed on a computer for the internet. That computer is working 24/7 and it is the best place to add a HDD for files. MT supports FTP and I want to use it. 2GB is not such a large file. If it was 20GB and above you can say a large file.
mag
Fri Mar 24, 2006 6:12 pm
Probably the Coffee Machine Control Software ;-)
(no, i don't want to know actually)
changeip
Fri Mar 24, 2006 7:23 pm
I'm guessing the file system used in MT has a limit of 2gb ... most machines up until a few years ago had this limitation. Some are 4gb limits still.
Sam
DarkMind
Fri Mar 24, 2006 8:42 pm
I read some websites and the problem with the limit comes from the Kernel. MT's kernel just don't support big files. Maybe it is not compiled with the new options. I don't know. That's why I'm asking.
cmit
Mon Mar 27, 2006 11:30 am
Filesystem or kernel limits come to mind as the culprits, yes.
But you will have to ask MikroTik directly to get any confirmation on this: support@mikrotik.com.
Best regards,
Christian Meis
normis
Mon Mar 27, 2006 11:50 am
yes it does have some limits on file size. maybe this will change in 2.10. actually RouterOS is not meant as a file server, so this is not exacly a bug, more an inconvenience
Users browsing this forum: No registered users and 121 guests
