zizobaddy
How to forward public IP to Clients
Sun Aug 04, 2013 1:10 am
Dear All
I wish to forward a block of public IP to a client on my network and my Enkompass server.
Below are the things i have done
1. Net Map works perfectly for clients who require public ips and doesnt mind me forwarding it
2. IP routing 41.XXX.YY.Z/27 (Public Interface) 41.XXX.YY.Z/30 (local interface) proxy arp enabled on public and local interfaces
the issue here is that if you check the whatismyip.com it shows my routers ip and not the one i subneted
3. scr-nat and dst-nat works but just for forwarding ip
4. bridging it works but clients on dhcp and lan stops working
Im lost because i have a client who need a static ip /29 given to him so that he can use it on his GW and that it show show his ip when he check whatismyip
My enkompass server also requires same before it can activate
Please Help!!!!
Azeez
waver
Re: How to forward public IP to Clients
Sun Aug 04, 2013 5:37 pm
You need rule NAT:
First is pass the publi IP to your client. For this, configure
chain: dstnat
Source address: 0.0.0.0/0
Destination addres: your client public IP
Input interface: your interface from internet
Action:
dst-nat
To address: your client IP address (no public, for example 192.168.200.2/30)
"you need configure the internal IP in one Mikrotik interface, for example 192.168.200.1/30"
The secon rule configure to exit
Chain: dstnat
source address: 192.168.200.0/30
output interface: your interface to internet
Action:
dst-nat
To address: Public IP
If you configure this two rules, when your client check your public IP, can see the real public IP.
I have this configuration on a client and works fine!
Carlos Martínez Ramiro
MTCNA, MTCRE
zizobaddy
Sun Aug 04, 2013 5:56 pm
Thanks alot waver
However kindly help me check your second rule again because i keep getting error "outgoing input does not match input and prerouting chains (6)"
Thank you
waver
Sun Aug 04, 2013 6:02 pm
You need rule NAT:
chain: dstnat
Action:
dst-nat
Chain: srcnat
Action:
src-nat
To address: Your client public IP
Excuseme, the secon rule is SOURCE NAT.
:D
MTCNA, MTCRE
zizobaddy
Sun Aug 04, 2013 6:08 pm
Thanks once again
Pls find below the red inks
You need rule NAT:
chain: dstnat
Input interface: your interface from internet (DO YOU MEAN PUBLIC INTERFACE)
Action:
dst-nat
Chain: srcnat
output interface: your interface to internet (DO YOU MEAN LOCAL INTERFACE)
Action:
src-nat
:D
waver
Sun Aug 04, 2013 6:17 pm
If you would like pass the public IP to your client, significate the Mikrotik is conected to internet. Have a interface for connect to internet (Is this interface you have to set in this option, same input and output) and other interface for connect to your client (in this interface configure a little network "192.168.200.0/30" to connect with hardware client).
I hope you solve the problem!
MTCNA, MTCRE
zizobaddy
Sun Aug 04, 2013 6:24 pm
What i have here is 1 interface connected to the internet and the other to all my clients (/16)
for the config you shared with me i used just the ip of my server as a case study using the Internet intrface as both in and out interfaces in the 2 nat rules
However i still get my routers ip and not the other one
My mode of connection is not by ppoe just normal lan with dhcp
waver
Sun Aug 04, 2013 6:37 pm
Ok, if you have a lot of clients, you need repeat this rules for all.
You need creat a little networks for each clients, for example:
192.168.200.0/30 for first client
192.168.201.0/30 to second
If you configure the hardware client with this network and this rules on Mikrotik, finally the client will have a public IP, sure. Because all input packets to client public IP is redirected to 192.168.20X.2/30 (the IP in you client hadrware) first rule. When you go to internet, the rule send the packets with the client public IP. Second rule.
Remember the "masquerade".
MTCNA, MTCRE
zizobaddy
Sun Aug 04, 2013 8:43 pm
Thanks for your help
However it didn't work :(
I created a /30 network and assigned it
I also did the dstnat and srcnat rule
however anytime i check what is my ip it still shows my routers ip
zizobaddy
Sun Aug 04, 2013 8:53 pm
Thanks waver
it works i forgot to add the Public IP to my address list
:D
Please has anyone figure out how to assign public ip without nat
matiaszon
Thu Mar 09, 2017 8:35 pm
Will this work the same, if applied to the below config:
[INTERNET] ----- [any MikroTik with LTE card <-> ether1] ----- [ether1=WAN RB750Gr3 router ether2-5=LAN]
What I am interested is to get the public IP from ISP assigned to ether1 of RB750Gr3. Will that work? Which LTE card will support it, if any?
zizobaddy
Sun May 21, 2017 2:25 pm
Yes use netmap or dstnat
Users browsing this forum: No registered users and 118 guests
