MUM Europe 2020
acim
DNS cache
Fri Mar 24, 2006 5:34 pm
I have two questions regarding /ip dns cache
1. Does it store data in memory or on hard disk (compact flash)? If it stores to CF, than this increases number of writes a lot.
2. How to turn off DNS cache? I set cache-max-ttl to 0s and then it stops caching, but I am not sure if this is the best way.
mag
Fri Mar 24, 2006 6:09 pm
AFAIK it stores in memory. I didn't see CF writes increasing while dig'ing my test MT-router.
wildbill442
Re: DNS cache
Fri Mar 24, 2006 6:57 pm
drop incoming request to udp port 53 ;)
or uncheck the box that says "allow remote requests" in the DNS settings. I think that would do it.
acim
Sat Mar 25, 2006 1:14 pm
@wildbill442
It is already unchecked in my settings, but still DNS cache fills up with data. Just if I put cache-max-ttl=0s it stops using cache and this should do the jos.
mag
Sat Mar 25, 2006 2:02 pm
where's the problem? simply turn remote-requests off, if dns on the MT should not be used.
otherwise it's perfectly normal for DNS to build up a RAM-cache (except TTL=0 entrys, which are used vor dynDNS or NATted DNS-payload)
Users browsing this forum: Google [Bot], macsrwe, MSN [Bot], zwarner and 92 guests
