MUM Europe 2020
badangels
Dhcp Issue
Fri Aug 09, 2013 5:00 pm
hi all i have an issue with one client i dont know what is the issue with dhcp server or client pc
wire is perfect tested on Ethernet Tester on that wire another pc is working fine no idea that is that problem with client windows or windows services i attached the snap.
If i helped you, please thank me by Giving Karma.
faaw
Re: Dhcp Issue
Sun Aug 11, 2013 6:51 am
try to change his ethernet card or change his mac this mac software
SurferTim
Re: Dhcp Issue
Sun Aug 11, 2013 9:20 am
I don't know if it will help, but you should enable debug logging for dhcp.
/system logging
add topics=dhcp,debug action=memory
Then watch the log for that client to renew the lease.
/log
print follow where topics~"dhcp"
What RouterOS version are you using?
badangels
Re: Dhcp Issue
Fri Aug 16, 2013 10:36 pm
Router Board RB750
Version 4.14
and problem is sloved as i changed the Ethernet card :)
Users browsing this forum: Bing [Bot], troubleshooter and 37 guests
