Smueller
Install external Linux Drivers ?
Tue Aug 20, 2013 11:11 am
i have a gps USB receiver but after connect i can´t find it under resources.
is it possible to install external Linux Driver for this device on the RB411 Boards ?
http://www.silabs.com/products/mcu/Page ... ivers.aspx
thanks
Stefan
normis
Re: Install external Linux Drivers ?
Tue Aug 20, 2013 11:12 am
You can't add drivers in RouterOS. If a device is not visible in the GPS settings, it is not supported. Are you running the latest v6.2? If yes, send a supout.rif file to support and we will see if we can fix it.
Smueller
Tue Aug 20, 2013 7:41 pm
Hi Normis,
thanks for the fast feedback
i have send the supout file to your support.
Yes i have installed 6.2 on my Board.
Stefan
Smueller
Tue Aug 27, 2013 12:50 pm
Hi Normis,
Stefan
Hi, now i have running the gps on my board :-) but i can see the gps data only over the monitor but i want output the coordinates to a gps.txt file
how can i do it.
i want later see the position on Google maps
i i have put the Converter script (http://wiki.mikrotik.com/wiki/GPS_text_ ... Earth/Maps)
but i cannot put the gps data to a file.
thanks
Stefan
Users browsing this forum: AndyGs, creatin, erlinden, mkx, sindy and 46 guests
