fbslim
Multiple WAN access to resources behind NAT, HOW-TO... do???
Tue Aug 20, 2013 12:19 pm
Hello everybody!
Have a problem... with two ISPs on my router.
I need to make accessible one resource behind NAT, than in my LAN. And i need to make it accessible from two ISPs simultaneously.
So - two different Internet IPs and one and the same server on it.
I can make accessible the router ports/services itself, such as 21, 22, 80, 8291 from two ISPs.
Looks like this:
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ISP1-pppoe routing-mark=ISP1 scope=30 target-scope=10
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=ISP2-pppoe routing-mark=ISP2 scope=30 target-scope=10
/ip firewall mangle
add chain=input action=mark-connection new-connection-mark=ISP1-input passthrough=no dst-address=1.1.1.1 in-interface=ISP1-pppoe
add chain=output action=mark-routing new-routing-mark=ISP1 passthrough=no connection-mark=ISP1-input
add chain=input action=mark-connection new-connection-mark=ISP2-input passthrough=no dst-address=2.2.2.2 in-interface=ISP2-pppoe
add chain=output action=mark-routing new-routing-mark=ISP2 passthrough=no connection-mark=ISP2-input
But I don't understand how to do the same to resources behind NAT.
Please, can somebody show the working examples, to understand???
Thanks in advance!
tomaskir
Trainer
Trainer
Re: Multiple WAN access to resources behind NAT, HOW-TO... d
Tue Aug 20, 2013 12:33 pm
Look at the first part of this video, it explains how to get dual WAN properly working.
Then just setup NAT like normal.
Ignore the load-balancing part if you are not interested in load-balancing.
http://tiktube.com/video/DofH3iFnjDJomG ... uKlEoLqHq=
Unimus - configuration management, automation and backup solution
Mass Config Push, network-wide RouterOS upgrades, and more!
fbslim
Tue Aug 20, 2013 2:58 pm
MAN!!! Thank you VERY much! Really working stuff!!!
navigowifi
Mon Sep 02, 2013 11:58 am
Hello, I am interested to see if MK can do what the Mushroom can do. Basically if I have two ISP with 10 megs each, when I download something can I have both connections join together to get 20 megs downloads? Thats all I need to ask.
tomaskir
Trainer
Trainer
Wed Sep 04, 2013 12:48 pm
It is impossible to have a single TCP or UDP connection split across multiple ISPs.
With a multi-connection download (ex. Torrents) you can have full speed.
pcunite
Wed Sep 04, 2013 5:10 pm
Look at the first part of this video ...
Is this on YouTube somewhere? I can never play anything form tiktube for some reason.
tomaskir
Trainer
Trainer
Wed Sep 04, 2013 7:09 pm
Use Chrome or Firefox and it should play.
MUM presentations are only on Tiktube, nowhere else that I know of.
Users browsing this forum: Baidu [Spider], LunaticRv, MSN [Bot], PhoeKhwar and 85 guests
