orcinus
Can't flush static DNS entries
Wed Aug 21, 2013 4:23 am
If you create static DNS entries, then disable them, then flush the DNS cache, the static entries remain cached until the next reboot. There does not seem to be a way to flush them besides rebooting.
I understand this isn't quite a big problem for 99.99% of people, but it's a major pain in the ass for me in my home network, when testing servers (i.e. swapping back and forth between "true" DNS entries and temporarily swapped IP addresses for the test servers).
This is on 6.2, RB2011, by the way.
reverged
Re: Can't flush static DNS entries
Wed Aug 21, 2013 7:13 am
5.25 has the same issue.
The previous dns entries remain in cache and you get them returned in order.
Only reboot solves this.
jarda
Mon Sep 02, 2013 10:33 pm
On v. 5.25:
I disable static records and they disappear from DNS cache immediatelly. Then I remove them and they are gone forever.
No need for restart...
IGHOR
Tue Oct 21, 2014 12:39 am
I have exactly same issue on 6.20 now.
Except rebooting is not helps.
janisk
Wed Oct 22, 2014 3:04 pm
do you have any clue what request caused this? Is this crowded dns-cache?
blazej44800
Tue May 05, 2015 5:56 pm
Exactly the same problem. Deleted static DNS record is still in cache. ROS 6.27, RB2011.
CCNA R&S
thc123
Trainer
Trainer
Sat Aug 29, 2015 10:31 am
It happens only when there are lot of items in DNS cache.
[SOLUTION] You can use this steps until the fix arrives..
Before deleting Static DNS entries:
1. first flush dns cache
2. delete static entries.
If there are leftover entries:
2. recreate static entries with the same hostname / IP combination.
3. delete the same static entries.
Hope this helps.
Thomas Kaurić, MCT #328
blazej44800
Sat Aug 29, 2015 11:17 am
I already sent suppout and video, how it happend. It hapens when you rename static entry. Then the previous one trapp in cache.
CCNA R&S
blazej44800
Sat Sep 05, 2015 12:15 pm
The situation when it happen: https://www.youtube.com/watch?v=CF6RvVPpxGM
CCNA R&S
ricreis394
Sun Sep 20, 2015 1:19 pm
Hope this helps.
Thanks, it works
blazej44800
Sun Sep 20, 2015 1:31 pm
Only if there is a lot of items? I exactly found, the reason when it happend. See my video above.
CCNA R&S
Users browsing this forum: No registered users and 103 guests
