rado3105
Building secure firewall
Fri Aug 23, 2013 5:53 pm
Here is my firewall, I am still working on it. I would like to share it and hear your opinions, what to change, what is missing...ether1 is internet....
0 ;;; Drop invalid connections
chain=input action=drop connection-state=invalid
1 ;;; Port scanners to list
chain=input action=add-src-to-address-list protocol=tcp psd=21,3s,3,1
address-list=port scanners address-list-timeout=2w
2 ;;; NMAP FIN Stealth scan
tcp-flags=fin,!syn,!rst,!psh,!ack,!urg protocol=tcp
3 ;;; SYN/FIN scan
chain=input action=add-src-to-address-list tcp-flags=fin,syn protocol=tcp
4 ;;; SYN/RST scan
chain=input action=add-src-to-address-list tcp-flags=syn,rst protocol=tcp
5 ;;; FIN/PSH/URG scan
tcp-flags=fin,psh,urg,!syn,!rst,!ack protocol=tcp
6 ;;; ALL/ALL scan
tcp-flags=fin,syn,rst,psh,ack,urg protocol=tcp address-list=port scanners
7 ;;; NMAP NULL scan
tcp-flags=!fin,!syn,!rst,!psh,!ack,!urg protocol=tcp
8 ;;; dropping port scanners
chain=input action=drop src-address-list=port scanners
9 ;;; suppress DoS attack
chain=input action=tarpit protocol=tcp src-address-list=black_list
connection-limit=3,32
10 ;;; detect DoS
chain=input act
address-list=black_list address-list-timeout=1d in-interface=ether1
connection-limit=10,32
11 ;;; DOS attack protection(50 connections/ip)
address-list=black_list address-list-timeout=1d connection-limit=50,32
12 ;;; drop ssh brute forcers
chain=input action=drop protocol=tcp src-address-list=ssh_blacklist
dst-port=22
13 chain=input action=add-src-to-address-list connection-state=new protocol=tc>
src-address-list=ssh_stage3 address-list=ssh_blacklist
address-list-timeout=1w3d dst-port=22
14 chain=input action=add-src-to-address-list connection-state=new protocol
src-address-list=ssh_stage2 address-list=ssh_stage3
address-list-timeout=1m dst-port=22
15 chain=input action=add-src-to-address-list connection-state=new protocol
src-address-list=ssh_stage1 address-list=ssh_stage2
16 chain=input action=add-src-to-address-list connection-state=new protocol
address-list=ssh_stage1 address-list-timeout=1m dst-port=22
17 ;;; drop ssh brute downstream
chain=forward action=drop protocol=tcp src-address-list=ssh_blacklist
dst-port=22
18 ;;; Allow Broadcast Traffic
chain=input action=accept dst-address-type=broadcast
19 ;;; smtp(e-mail)
chain=input action=accept protocol=tcp in-interface=ether1 src-port=25
20 ;;; vpn(gre)
chain=input action=accept protocol=gre in-interface=ether1
21 ;;; ping
chain=input action=accept protocol=icmp in-interface=ether1
22 ;;; tcp ports
dst-port=22,25,53,1723,2000,7780,8291
23 ;;; udp ports
chain=input action=accept protocol=udp in-interface=ether1 dst-port=53
24 ;;; drop everything else
chain=input action=drop in-interface=ether1
rado3105
Re: Building secure firewall
Thu Aug 29, 2013 1:10 am
 3   ;;; SYN/FIN scan
 4   ;;; SYN/RST scan
     tcp-flags=fin,psh,urg,!syn,!rst,!ack pr address-list=port scanners address-list-timeout=2w
 6   ;;; ALL/ALL scan
10   ;;; detect DoS attack(10 connections/ip from internet)
     dst-port=22
14   chain=input action=add-src-to-address-list connection-state=new protocol=tc>
15   chain=input action=add-src-to-address-list connection-state=new protocol=tc>
16   chain=input action=add-src-to-address-list connection-state=new protocol=tc>
     dst-port=22
19   ;;; smtp(e-mail)
     chain=input action=accept protocol=tcp src-port=25
20   ;;; vpn(gre)
21   ;;; ping
22   ;;; tcp ports
     chain=input action=accept protocol=tcp dst-port=22,25,1723,2000,7780,8291
23   ;;; allow estabilished connections
     chain=input action=accept connection-state=established
What do you think, is that secure enough?
AlArenal
Thu Aug 29, 2013 10:12 am
Security isn't an absolute thing - as long as you don't power off every network device and computer.
"Secure enough" depends solely on your specific requirements - which we cannot know. You may have to rethink your ruleset at least when the first user complains about something not working right. And there may always be someone more clever than you who knows how to get around your restrictions to achieve things you intended to block.
VARELA
Thu Aug 29, 2013 10:27 am
Do you understand differences in chains (input,forward)?
There are many unnecessary rules. 19? 20? 21? 22?
Maybe better accept access for ssh or icmp or another services from trusted network?
Try to disable unused services in "/ip service".
AlArenal
Thu Aug 29, 2013 10:37 am
That's an example why I said we can't judge because we don't know the requirements. Is the box always administered locally via console port he won't need ssh and telnet. Otherwise he's pretty much locking himself out if he ever has to remotely work on the shell.
rado3105
Fri Aug 30, 2013 9:44 pm
I connect to local network using vpn in this gateway. I ping this router from internet to check if it is online...and when is down send sms....from other device in network...
25 is needed to send emails from this device....
I was just curious if order is good, and also if there is something other to do it more secure...
pcunite
Sun Sep 01, 2013 5:11 am
If you have one port for WAN and another for LAN (or logical) it is not too hard to work out a secure solution. Like an onion we will start with a layer and add or remove features as we move through the layers. Note that I prefer to use interfaces instead of IP addressing because those can be spoofed.
Option 1: Router and internal network protection
Goals:
. Disallow anything originating from the WAN (ether1).
. Allow anything originating from the LAN (ether2) to setup and receive packets coming back to it.
. Allow ICMP (ping) from the WAN.
Notes:
This is a standard secure setup. However, it does not allow for internal servers. It also trusts internal clients to be nice and to not be in a hacked state. Suitable for a SOHO network.
ros code
#Router and internal network protection, no internal servers, LAN is friendly
add chain=input   action=drop   connection-state=invalid                      comment="Disallow weird packets"
add chain=input   action=accept connection-state=new         in-interface=LAN comment="Allow LAN access to router and Internet"
add chain=input   action=accept connection-state=established                  comment="Allow connections that originated from LAN"
add chain=input   action=accept connection-state=related                      comment="Allow connections that originated from LAN"
add chain=input   action=accept protocol=icmp                                 comment="Allow ping ICMP from anywhere"
add chain=input   action=drop                                                 comment="Disallow anything from anywhere on any interface"
add chain=forward action=drop   connection-state=invalid                      comment="Disallow weird packets"
add chain=forward action=accept connection-state=new         in-interface=LAN comment="Allow LAN access to router and Internet"
add chain=forward action=accept connection-state=established                  comment="Allow connections that originated from LAN"
add chain=forward action=accept connection-state=related                      comment="Allow connections that originated from LAN"
add chain=forward action=drop                                                 comment="Disallow anything from anywhere on any interface"
Option 2: Allowing for internal servers
Goals:
. Masquerade and allow for internal servers.
Notes:
Uses "Port mapping" technique.
ros code
# Port Forward (map) to an internal LAN server. Note that you'll need to move the
# last line via the GUI to be above DROP rules. If you're using the one above
# place it above the last line: "add chain=forward action=drop"
/ip address         add address=1.2.3.4/24 interface=WAN                                                    comment="Set public IP of router to a public interface"
/ip firewall nat    add chain=srcnat  action=masquerade out-interface=WAN                                   comment="Turn on masquerading"
/ip firewall nat    add chain=dstnat  action=dst-nat protocol=tcp to-address=1.2.3.4 dst-port=80 to-port=80 comment="Create an incoming port map rule"
/ip firewall filter add chain=forward action=accept  protocol=tcp dst-port=80                               comment="Add a filter exception for port mapped server"
Option 3: Stop bad outgoing traffic
Goals:
. Filter certain connections, ports, and packet types from leaving the LAN to the WAN.
Notes:
When I get time.
Option 4: Stop trusting the internal network
Goals:
. While still allowing for router supplied services (DHCP, DNS, etc.). Disallow anything else.
. Only allow LAN access to the router console from a single trusted client. Disallow all others.
. Segment the LAN clients from each other. They're all crazy anyway.
Notes:
When I get time.
jaytcsd
Mon Sep 02, 2013 2:46 am
I used the rules on the demo router as a start.
demo2.mt.lv
I added chain=input action=drop protocol=tcp dst-port=0-65535 port=""
to avoid port scans.
Users browsing this forum: Bing [Bot], simtj and 156 guests
