MUM Europe 2020
linked
pppoe isssue
Thu Aug 29, 2013 4:26 pm
hello,
on a RB951G-2HnD is set a pppoe connection.
from time to time (between a couple hours and days) the connection is droped.
here are some logs:
07:49:44 pppoe,debug,packet service-name=MITI
07:49:44 pppoe,debug,packet host-uniq=00 23 f8 95 26 18 2d 70 70 70 6f 65 30 00 00 00 00 00
07:49:44 pppoe,debug ether1-gateway: received PADI, with unsupported service, dropping
07:49:44 pppoe,debug,packet ether1-gateway: rcvd PADI from 94:44:52:7E:5A:45
07:49:44 pppoe,debug,packet session-id=0x0000
07:49:44 pppoe,debug ether1-gateway: dropping PADI: no service to offer
07:49:45 pppoe,debug,packet ether1-gateway: rcvd PADI from 00:A1:D1:55:A0:EA
07:49:45 pppoe,debug,packet session-id=0x0000
07:49:45 pppoe,debug,packet service-name=akta
07:49:45 pppoe,debug,packet host-uniq=0x1
07:49:45 pppoe,debug ether1-gateway: received PADI, with unsupported service, dropping
07:49:45 pppoe,debug,packet ether1-gateway: rcvd PADI from 94:44:52:7E:5A:45
07:49:45 pppoe,debug ether1-gateway: dropping PADI: no service to offer
07:49:45 pppoe,debug,packet ether1-gateway: rcvd PADI from 00:23:F8:95:26:18
07:49:45 pppoe,debug,packet service-name=MITI
07:49:45 pppoe,debug,packet host-uniq=00 23 f8 95 26 18 2d 70 70 70 6f 65 30 00 00 00 00 00
07:49:45 pppoe,debug,packet ether1-gateway: rcvd PADI from 00:14:D1:52:22:1A
it was set up with service-name="" before and for some time it worked, i tried now with service-name=" " and after a few attempts it was connected. and after 7 hours it was down again for 10 minutes.
the pppoe client is setup like this:
0 R name="wan" max-mtu=1480 max-mru=1480 mrru=disabled interface=ether1-gateway user="user" password="pass" profile=default service-name=" " ac-name=""
add-default-route=yes dial-on-demand=no use-peer-dns=yes allow=pap,chap,mschap1,mschap2
donnow if it from the isp, or from mk or from setup. the isp said they have no service name, it worked with blank and with space.
the last logs are like this:
15:54:44 pppoe,ppp,info wan: terminating... - disconnected
15:54:44 pppoe,ppp,info wan: disconnected
15:54:54 pppoe,ppp,info wan: initializing...
15:54:54 pppoe,ppp,info wan: dialing...
15:54:56 pppoe,ppp,info wan: terminating...
15:54:56 pppoe,ppp,info wan: disconnected
15:55:06 pppoe,ppp,info wan: initializing...
15:55:06 pppoe,ppp,info wan: dialing...
15:55:09 pppoe,ppp,info wan: terminating... - disconnected
15:55:09 pppoe,ppp,info wan: disconnected
15:55:19 pppoe,ppp,info wan: initializing...
15:55:19 pppoe,ppp,info wan: dialing...
15:55:19 pppoe,ppp,info wan: authenticated
15:55:19 pppoe,ppp,info wan: connected
ideas?
Dap
Re: pppoe isssue
Thu Jul 30, 2015 4:14 pm
Same problem. I need to connect clients with all service names, but i cant find how to ignore service name.
gammy69er
Re: pppoe isssue
Wed Feb 10, 2016 2:20 am
I Just Didn't put in a service name on Client Device - Worked for Me.
You could also use the same name as your pppoe serve service - that should work too.
Users browsing this forum: No registered users and 101 guests
