ejansson
"TX Drop" error on Vlan interface
Wed Sep 04, 2013 4:45 pm
On one of our routers we have several VLAN's on a single ethernet port that have "TX Drop" accumulating. There are no errors showing else where on the Ethernet port or on a remote switch that un taggs the vlan's. Other ports and vlan configs on the same router are OK. Any suggestion on why the accumulation on tx drops.
rpingar
Long time Member
Long time Member
Re: "TX Drop" error on Vlan interface
Thu Sep 12, 2013 6:54 pm
we have a rb1200 (running 6.3) with low level of cpu usage (around 20%) that has the same high level ov tx-drop on the vlans
any help is appreciated
regards
Ros
rpingar
Long time Member
Long time Member
Thu Sep 12, 2013 8:00 pm
I fixed it changing the queue to ethernet-default
regards
Ros
pcunite
Thu Sep 12, 2013 9:59 pm
Thank you for letting us know.
ejansson
Fri Sep 27, 2013 6:06 pm
Any way to clear the TX Drop counters on the vlans?
rpingar
Long time Member
Long time Member
Fri Sep 27, 2013 6:18 pm
the only way is to reboot the router.
regards
ros
ejansson
Fri Sep 27, 2013 6:21 pm
Thanks, hoping i had missed something as I can't do that to a core router with out some planning!
niamul
Wed Feb 11, 2015 1:06 pm
how do you manage to change the queue type on a vlan? please help because i'm getting the same problem
- waiting for that last laugh
Users browsing this forum: arisk and 74 guests
