Roy
ROS v. 6.3 problem
Thu Sep 05, 2013 4:16 am
Current ROS 6.3 problem.
1. Explore browser cannot login.
2. Telnet window shows “Mikrotik” Name (I use ‘brand maker’ wish to remove)
3. http://192.168.88.1/graphs/ is not showing Graph.
pcunite
Re: ROS v. 6.3 problem
Thu Sep 05, 2013 7:09 am
Did you update all packages?
Clear your broswer history and cookies.
normis
Thu Sep 05, 2013 10:20 am
Roy, that is the RouterOS "Identity" name, which is part of the configuration. If you want to change this, you must also upload the file "identity.auto.rsc" with the contents:
ros code
/system identity set name="yourbrand"
Roy
Mon Oct 14, 2013 7:10 am
ros code
Hello Nomis,
how to make "identity.auto.rsc" file?
when I start telent, it start with
Mikrotik v.6.3
Login:
This Mikrotik name is not changed.
Chupaka
Mon Oct 14, 2013 5:24 pm
disable Telnet :)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: EdPa, Majestic-12 [Bot], nithinkumar2000 and 93 guests
