Ehman
Load Balancing over Multiple Gateways Issue
Tue Sep 10, 2013 1:03 am
Hi
This guide I've been trying to follow refuses to work with a hotspot enabled on the router, I'm trying to mark routing so that a certain IP range get a certain gateway, but no luck at all, if I disable the hotspot, it works! . :shock:
Guide
http://wiki.mikrotik.com/wiki/Load_Bala ... e_Gateways
c0d3rSh3ll
Long time Member
Long time Member
Re: Load Balancing over Multiple Gateways Issue
Tue Sep 10, 2013 4:58 am
Set the routing mark with hotspot=auth and try...
nothing
Ehman
Tue Sep 10, 2013 11:48 am
Nope, does not work at all, I've tried that before I post this thread
ERROR: Not found
While trying to retrieve the URL http://www.google.com
Network is unreachable
You cache administrator is webmaster
Generated blablabla (Mikrotik HttpProxy)
I'm running v6.3, can this be another bug in a old broken feature (past experience also), the word on the street is that mikrotik release new versions and broke old features so that they can make more versions so that people will have to get new licenses soon if they want to keep upgrading their older units :shock:
c0d3rSh3ll
Long time Member
Long time Member
Tue Sep 10, 2013 10:39 pm
In the profile hotspot for user set "transparent proxy" no
nothing
Ehman
Wed Sep 11, 2013 2:27 pm
*mangle rule is set to hotspot: auth
*"under user hotspot profile" transparent proxy is unticked
result: doesn't work :(
bigzein
Thu Dec 03, 2015 7:01 am
Both solusion does work for me.
But you need to try relogin if you are using hotspot.
Thank you very much.
Users browsing this forum: MSN [Bot] and 107 guests
