MUM Europe 2020
realtime
ros 6.4 MPLS local bindings problem
Mon Sep 16, 2013 7:45 pm
Dear developers.
I get a problem when i running MPLS VPN setup
When i'm comparing the MPLS local bindings section in 5.22 and 6.4 versions I found that 6.4 version can't automaticaly create local bindings.
you can find it on attached picture.
Please tell me if this is a bug of 6.4v or i do something wrong
Thanks in advance!
Geeek
Re: ros 6.4 MPLS local bindings problem
Sat Sep 21, 2013 6:57 am
Estou com o mesmo problema e mesmo com a versao 5.26 nao esta estavel, funciona ate o router rebootar e entrar no modo bypass, meus routers sao todos RB 1100x2 AH.
Users browsing this forum: didipov, MSN [Bot], npero, svmk, vortex, wispmikrotik and 112 guests
