fredgr
Error connecting Mikrotik PPTP VPN Client to a Linux VPN Svr
Sat Sep 21, 2013 8:25 pm
I have configured my Mikrotik router as a PPTP VPN Client that connects to a PPTP VPN Server running on a Centos 6.2 (configured as NAT so that VPN clients get internet access via the Centos server)
My different devices (iPhone, Mac, PC, ...) can connect seamlessly onto the VPN and surf the web.
But my Mikrotik Client fails to connect, and this is the log on the server related to the connection attempt :
pptpd[10678]: CTRL: Client XX.XX.XX.XX control connection started
pptpd[10678]: CTRL: Starting call (launching pppd, opening GRE)
pppd[10679]: Warning: can't open options file /root/.ppprc: Permission denied
pppd[10679]: Plugin /usr/lib64/pptpd/pptpd-logwtmp.so loaded.
pppd[10679]: pppd 2.4.5 started by root, uid 0
pppd[10679]: Using interface ppp1
pppd[10679]: Connect: ppp1 <--> /dev/pts/2
pptpd[10678]: GRE: Bad checksum from pppd.
pppd[10679]: LCP: timeout sending Config-Requests
pppd[10679]: Connection terminated.
pppd[10679]: Modem hangup
pppd[10679]: Exit.
pptpd[10678]: GRE: read(fd=6,buffer=611860,len=8196) from PTY failed: status = -1 error = Input/output error, usually caused by unexpected termination of pppd, check option syntax and pppd logs
pptpd[10678]: CTRL: PTY read or GRE write failed (pty,gre)=(6,7)
I cannot find anything on the different forums for solving this.
Can someone help ?
Amirkhatam
Re: Error connecting Mikrotik PPTP VPN Client to a Linux VPN
Sun Sep 22, 2013 2:24 am
check your security profile that you set on router , and double check for encryption and authentication method !! i think your problem is because of it
Every Thing Possible With MikroTik
fredgr
Sun Sep 22, 2013 12:21 pm
I have even used the noauth option, but same problem.
I have reinstalled the PPTP server on latest Ubuntu server, but same problem.
smarag
Mon Nov 04, 2013 4:13 pm
check on /ip firewall service-port print
On name pptp without port
i am with this is running.
Maragoudakis Stavros
MTCNA - MTCWE - MTCTCE - MTCUME - MTCRE
Master Distributor in Greece
MikroTik Certified Consultant
ucs75
Sat May 03, 2014 3:51 am
What's up with the:
It looks like the process has no permissions to read it's own config file.
Users browsing this forum: MSN [Bot] and 100 guests
