robertpenz
Security: Random cypto generator broken in MIPS Kernel
Sun Sep 29, 2013 5:09 pm
Some weeks ago a bug in the random function get_cycles() of the Linux kernel for MIPS processors was discovered.
e.g. https://lists.openwrt.org/pipermail/ope ... 21318.html
And 10 days ago a fix was provided for this:
http://git.kernel.org/cgit/linux/kernel ... e2f54889ee
My questions are:
1. Is the RouterOS vulnerable? Which versions are?
2. Is the IPsec Implementation vulnerable?
3. When will you release a fix?
nawshad
Trainer
Trainer
Re: Random problem in MIPS Kernels
Sun Sep 29, 2013 6:17 pm
My questions are:
Good question!!!
MikroTik continuously improve Router OS, bestway to make your MikroTik router safe and secure, just check MikroTik site for latest Router OS version and upgrade your own router accordingly.
Good Luck
Nawshad Ahmed
MikroTik Certified Trainer & Consultant
MTCINE,MTCRE,MTCNA,MTCTCE,MTCWE,MTCUME
Cell:+17812610808
Massachusetts, U.S.A
Skype:ahmednawshad
robertpenz
Re: Security: Random problem in MIPS Kernels
Tue Oct 01, 2013 7:29 pm
No answer?
robertpenz
Fri Oct 25, 2013 5:21 pm
Still no answer? I've also sent a mail to the mikrotik support but also no answer there either ....do I need to consider the ipsec part to be brocken for the future?
Users browsing this forum: sindy and 120 guests
