MUM Europe 2020
fbslim
dst-nat one port to multiple NAT ip addresses, HOW-TO do???
Fri Oct 04, 2013 7:47 pm
Hello everybody! Again!
Another interesting problem.
For example, i have 2 web servers behind NAT with IPs 192.168.1.5 and 192.168.1.6
And I have only one WAN (extrernat internet IP) and only ONE... port - 80
I need, to... if first web server will out of rage, the second (reserve) will being accessible instead of the FIRST!
If it's looks like routes - there is no problem - distance=1 and distance=2. BUT... if it is 2 servers behind NAT... can they be exchangeable if first server will offline?
Here is a standard rule for internal web server, behind NAT... to bee accessible from the Internet:
add action=dst-nat chain=dstnat disabled=yes dst-address=31.31.31.31 dst-port=80 protocol=tcp to-addresses=192.168.1.5 to-ports=80
So... is it possible to access second NAT server if FIRST will be lay down?
HOW-TO... do what automatically, please HELP!!!
efaden
Re: dst-nat one port to multiple NAT ip addresses, HOW-TO do
Fri Oct 04, 2013 8:30 pm
You could write a script and use netwatch... when server 1 stops responding to pings then switch to server 2. I don't know of a built in way to do it.
fbslim
Fri Oct 04, 2013 9:42 pm
I very appreciative your affort for help, but... it's NOT a help. Sorry!
fbslim
Sun Oct 06, 2013 6:51 pm
Can somebody tell, if it possible to make route like rules with distance priority to change the route from current to reserve (like distance=1 and distance=2)? Is that possible to make such like rules for resources behind NAT??? AND HOW?????
Please somebody!!!
Sob
Sun Oct 06, 2013 9:45 pm
There's no "distance" for firewall rules and the first suggestion was right:
ros code
add chain=dstnat dst-address=31.31.31.31 protocol=tcp dst-port=80 \
    action=dst-nat to-addresses=192.168.1.5 comment=mainwww
    action=dst-nat to-addresses=192.168.1.6 comment=backupwww
/tool netwatch
add host=192.168.1.5 interval=1m timeout=1s \
    up-script="/ip firewall nat enable [find comment=\"mainwww\"]" \
    down-script="/ip firewall nat disable [find comment=\"mainwww\"]"
People who quote full posts should be spanked with ethernet cable. Some exceptions for multi-topic threads may apply.
fbslim
Mon Oct 07, 2013 8:25 am
ros code
/tool netwatch
Sob, thank you very very much for such explication!!!
It's really great device - Mikrotik, with great support :!:
garlicbulb
Mon Oct 07, 2013 9:00 am
The other way to do this is to have an "pseudo" IP address like 192.168.2.1 on both Web servers as an alias.
They you route 192.168.2.1 via 192.168.1.5 with distance 1 and via 192.168.1.6 with distance 2.
If 192.168.1.5 stops answering the ping, the route will go inactive and switch to the backup route.
You can also use a similar technique to roughly load balance the web server
cybercoder
Mon Oct 07, 2013 9:35 am
After i read your first post, it seems you need to balance the load of input web traffic and do failover.
The standard way is use DNS load balancing: Imagine google web servers, when you want to access google.com it may have different IP addresses in each request. This feature is called DNS load balancing.
But with routerOS i think there's only NetWatch and scripts as tools to implement this feature as mentioned by other guys in post 2 or 3.
Any sufficiently advanced technology is indistinguishable from magic. ( Arthur C Clarke )
Mikrotik certified consultant
Microsoft Certified Technology Specialist, Microsoft Certified IT Proffessional
http://www.netd.ir
Users browsing this forum: MSN [Bot] and 14 guests
