morf
changelog ROS 6.5
Tue Oct 08, 2013 2:39 pm
Hello!
Where can I see a preliminary list of changes in ROS 6.5?
Tnahks!
pcunite
Re: changelog ROS 6.5
Tue Oct 08, 2013 3:40 pm
There is no such list unless you're a part of the closed beta.
Stillhard
Tue Oct 08, 2013 4:16 pm
It's not that hard... :D
What's new in 6.5 (2013-Oct-04 15:48):
*) lcd - backlight option is replaced with "/lcd backlight" command
*) dhcp server - added option to disable conflict-detection;
*) console - ':return' does not trigger 'on-error=' action of ':do' command;
*) route - fixed crash that could be triggered by change in nexthop
address resolution;
*) route - some imported VPNv4 routes were not using MPLS labels;
*) route - imported VPNv4 routes were not always updated or removed when
the original route changed;
*) winbox - fixed problem where all settings were read only on first open;
*) ovpn server - use only ciphers that are allowed not that client requested;
*) ssh client - fixed public key authentication;
*) ipsec - fix peer mathing with non byte aligned masks;
*) fix routerboot upgrading if RouterOS is partitioned;
*) add support for second serial port on CCR boards;
*) fix serial port baudrate selection on CCR boards;
*) ethernet interface stats that are behind switch chip
show real hw stats instead of just the traffic that goes through cpu;
pcunite
Tue Oct 08, 2013 6:29 pm
Where can I download v6.5? I don't see it listed on the main site. Is it out of beta?
Stillhard
Tue Oct 08, 2013 6:50 pm
Here: http://www.mikrotik.com/download/share/ ... es_6.5.zip
No, it's still in beta stage but you can test it and report the dev to help 'em :)
payday
Tue Oct 08, 2013 6:51 pm
Download ROS 6.5: http://www.mikrotik.com/download/share/ ... es_6.5.zip
It's strange. According to this link: http://demo2.mt.lv/webfig/#System:Packa ... or_Updates v6.5 is not rc1 anymore (from 2013-Oct-04 15:48) so it can be released but it is still not available for download officially. Maybe this time they are TESTING it before release?! :wink:
TonyJr
Wed Oct 09, 2013 1:57 am
Hmm maybe we will find out on Friday...
Sent from my BlackBerry 9900 using Tapatalk
Ulypka
Wed Oct 09, 2013 12:42 pm
So that's why I stopped working OVPN server and client :lol:
kometchtech
Wed Oct 09, 2013 3:15 pm
We applied the ROS6.5 for me, it was confirmed that phenomenon will not be able to connect with Winbox and Webfig.
However, I can connect with Mac Telnet or ssh. Moreover, there is a good connection routing, etc. in this state.
This unofficial? I wonder because ROS such?
Is there someone who has symptoms similar to others?
Ensure the environment:
2011UAS-2HnD
Routerboard Users Group JP
http://www.rb-ug.jp/
CCR1009-8G-1S-1S+, RB750Gr3, CRS226-24G-2S+, RB850Gx2, RB960PGS, CRS317-1G-16S+,
RB2011UAS, CRS125-24G-1S, RB962UiGS-5HacT2HnT, CRS212-1G-10S-1S+, RB3011UiAS
napismizpravu
Thu Oct 10, 2013 7:58 pm
What's new in 6.5 (2013-Oct-10 09:28):
*) certificates - merge '/certificate ca' into '/certificate', use set-ca-passphrase to maintain CA functionality;
    address resolution;
Works import certificates?
RouterOS 6.5 (2013-Oct-10 09:28) RB433UAH > action timed out - try again, if error continues contact MikroTik support and send a supout file (13)
kometchtech
Thu Oct 10, 2013 9:16 pm
I have not used.
Where you tried to use the file dated 10 October,
problems such as had come out in the file 4 October the time being,
not be confirmed so far.
We are going to look at the situation for the time being.
Best regards.
honzam
Fri Oct 11, 2013 12:27 pm
In 6.5 is still missing POE out menu in winbox. In terminal it works on 2011iL
LAN, FTTx, Wireless. ISP operator
janisk
Fri Oct 11, 2013 12:57 pm
what is not working, what certificate you are trying to import?
napismizpravu
Fri Oct 11, 2013 2:52 pm
I made for testing:
I deleted previously imported cerificates (WinBox / certificate / delete all certificates)> WinBox new terminal / re-import (wiki-MikroTik) certificate error > WinBox system cerificates import error
create new certificates in Linux / import RouterOS error
Restoring from a backup RouterOS (Loading a previously imported cerificates)
(Google translator)
hapi
Sat Oct 12, 2013 11:12 am
hi
You can add support for the NIC Intel i354? i350 is supported but i354 not.
thx
hapi
Sat Oct 12, 2013 10:51 pm
and intel i210 and all new ethernet chip from intel?
New mainboard from supermicro includes this new chips.
thx mikrotik.
5nik
Sun Oct 13, 2013 1:02 am
Hmm, in 6.5 (2013-Oct-10 09:28) still can't access to SMB share from Android (4.x). Unable open share and Mikrotik generates autosupout.rif. From linux (Ubuntu) and Windows SMB works correctly.
Generally, I apologise for my weak english.
frankc
Sun Oct 13, 2013 6:09 pm
nice but it's all packages, which one you send first ?
system.npk ? or you push all of them and reboot ?
im used to the routeros-mipsbe.npk files but 6.5 has only packages in all files
brianlewis
Sun Oct 13, 2013 9:12 pm
frankc
Mon Oct 14, 2013 3:43 pm
ggetting the cannot find valid proposal on ipsec still on 6.5
tried both with and without tunnel
Stillhard
Wed Oct 16, 2013 6:19 pm
Now the demo box already uptodated with 6.5 version... let's all waiting for the official release... :D
jandafields
Thu Oct 17, 2013 5:37 am
6.5 is still in pre-release. Changes are still being made to it daily. The lack of "RC" on the name doesn't really mean anything, as there have been many updates to it since they removed the RC from it.
It won't be in it's final form until it is released on the mikrotik download page.
Stillhard
Thu Oct 17, 2013 2:07 pm
For real... :lol:
frankc
Thu Oct 17, 2013 3:42 pm
any news on this issue ? it's still happening on 6.5
both peers are equal configed, both have same default prop, and policies are right... just hangs on phase1 exits with no valid prop.
anyway i can trace further and see why ?
jfdumont
Re Works import certificates?
Fri Oct 18, 2013 1:21 pm
Same for me,
i test on RB1100
i use to make a backup conf
to upload on another router
before https activation i remove all certs
and then i upload my
server.cert server.key
but with 6.5
certificate import file-name=server.crt passphrase=xxxx do not works
certificate import file-name=server.key passphrase=xxxx do works
and i can not connect to ssh.
I downgrade to 6.3 i do the same
import works
ssh work !
JF
jfdumont
Fri Oct 18, 2013 1:23 pm
I forget to say if i upgrade 6.3 to 6.5 with certificats imported i can connect with ssh and https.
regards
JF
wahiedi
Sun Oct 20, 2013 9:21 am
Same here on RB750GL
machitza
Mon Oct 21, 2013 2:09 pm
same here:
[admin@MikroTik xxxx > /certificate import file-name=ca.crt
passphrase: xxxxx
[admin@MikroTik ] >
Klinkov
Tue Oct 22, 2013 9:11 am
The same issue with certificate import. Does not work in 6.5. The last version (6.4) everything was OK.
rmrf
Tue Oct 22, 2013 9:47 am
In addition, after trying to import certificates, i had unclassified process full loading CPU. (RB951Ui-2HnD).
jezyk
Tue Oct 22, 2013 1:41 pm
Hi there.
Yesterday I've tested 6.5 os version. I came across the same problem with certificate imports and timeout.
Maybe anyone knows if this issue has been submitted where we should do this.
TechKiwi
Mon Nov 04, 2013 6:14 am
Yeah there is definitely an issue with 6.5 and importing certificates.
For anyone wanting a work around this is what I used.
http://techkiwi.wordpress.com/2013/11/0 ... ort-issue/
rmrf
Tue Nov 12, 2013 5:13 pm
Fixed in 6.6 :)
Users browsing this forum: Lizzardd, matxanh, radu990, shimal and 113 guests
