MUM Europe 2020
wheezy
RouterBoard 951-2n with USB Port
Fri Oct 11, 2013 11:19 am
Hello to all,
I wanted to share with you my edit :-) I added the USB port of a sxt damaged on my 951-2n and it works perfectly.
Frank Gabriele
www.balenowireless.it
ohara
Re: Odp: RouterBoard 951-2n with USB Port
Sat Oct 12, 2013 10:47 am
Did you do anything else to the routerboard, or did you simply solder the port? Have you used it with a pendrive or usb modem?
Ma5tEr
Trainer
Trainer
Re: RouterBoard 951-2n with USB Port
Sat Oct 12, 2013 11:08 am
What else elements you use for it?
wheezy
Mon Oct 14, 2013 12:06 pm
It works perfectly with 3g huawei, for it to work I simply soldered the usb port;)
Users browsing this forum: 0pl0pl, AlexL and 91 guests
