matr2x2
Creating certificate problem
Mon Oct 21, 2013 9:20 pm
hi all
I worked this explanation
http://wiki.mikrotik.com/wiki/User_Mana ... ertificate
You receive an error in the browsers in the certificate as in these images
ie
Chrome
this
/certificate print
I'm sure the date and time correctly
I want a solution because the participants do not work with them sites https and show them a certificate error
thank you
matr2x2
Re: Creating certificate problem
Tue Oct 22, 2013 1:44 pm
I'm waiting for you
matr2x2
Tue Oct 22, 2013 11:42 pm
Please, I want to Solution the fitter
THG
Wed Oct 23, 2013 3:36 am
Do not be so sure about that, it does not look right.
invalid-before=oct/21/2013 11:36:29
invalid-after=dec/31/1969 23:59:59
jandafields
Wed Oct 23, 2013 6:32 am
You have to PURCHASE a certificate if you want to remove the error messages.
If you create your own certificate, you WILL have error messages!
For security reasons, computer browsers by default will ONLY trust certificates that have been purchased from a trusted certificate authority (like GeoTrust or Comodo)
normis
Wed Oct 23, 2013 10:48 am
Jandafields is right. The error simply tells you, that the certificate was not issued by an authority, but was self generated, which is true.
matr2x2
Wed Oct 23, 2013 11:26 am
invalid-after
How do I correct this error in the OpenSSH comes the end of history 2036 in mikrotik be 1969
How do I correct this error you need to do something in mikrotik?
matr2x2
Wed Oct 23, 2013 11:31 am
I do not want to buy because I do not have payment methods
But here in the members work with fake certificates
Thank you
matr2x2
Wed Oct 23, 2013 11:32 am
What is the solution?
THG
Wed Oct 23, 2013 6:08 pm
invalid-after
It works for me and I also used openssl to generate my self-signed certificate.
To generate a key:
bash code
openssl genrsa -out 192.168.88.1.key 2048
To generate the certificate:
bash code
openssl req -new -x509 -key 192.168.88.1.key -out 192.168.88.1.cert -days 3650 -subj /CN=192.168.88.1
nurmia
Wed Oct 23, 2013 7:03 pm
Thanks for your valuable update. Very useful information.
Users browsing this forum: aguerraitd, anav, Bing [Bot], Lifz, sindy and 61 guests
