freedomwifiau
Sierra Wireless AirCard 320U - LTE mode
Tue Oct 29, 2013 6:10 am
I have RB951Ui-2HnD with RouterOS 6.0rc14.
It says on the hardware page that this card is supported for LTE as per below:
"Sierra Wireless AirCard 320U [95] v6.0
Vendor/product id pair should be 0x0f3d/0x68AA and DirectIP firmware loaded on the modem"
I can't get mine to work in LTE mode, so I assume it has something to do with "DirectIP firmware loaded on the modem", but I can't for the life of me work out what this means in the context of this card and a routerboard. I've been to the Sierra site that talks about directIP and from what I can gather directIP is a driver that is loaded on to linux. There is no mention anyway (that I have found) in regards to an firmware update or directIP firmware version specifically to load on to the aircard itself.
So my question is, what exactly is meant by "and DirectIP firmware loaded on the modem", how do I check and how do I load it if it needs to be? I assume someone has had this card working on a routerboard otherwise it wouldn't be listed.
I have the modem working in PPP mode, but I would much prefer to use LTE. It would make bonding easier and just life in general.
Many thanks in advance
Paul
uldis
Re: Sierra Wireless AirCard 320U - LTE mode
Tue Oct 29, 2013 11:15 am
here are some firmware downloads for the Direct IP mode, but we can't guarrany that they will work:
http://downloadcenter.netgear.com/en/pr ... Telstra$29
Try to use that AC320U_Telstra-X03.05.23.09 firmware and maybe it will work fine.
RogerWilco
Wed Oct 30, 2013 12:58 am
I have wondered the same thing too. I don't know who updated the hardware support list, but I would like to know how they got the DirectIP method to work.
Netgear don't have release notes for the firmware upgrade.
It does work on Windows PCs with DirectIP so unless Windows has the DirectIP drivers it needs.
freedomwifiau
Thu Oct 31, 2013 3:08 am
thanks uldis,
haven't had a chance to try it yet, but will report back as soon as I do. I didn't even realise it was netgear, I searched high and low. Obviously not high and low enough hahaha
Thanks again
freedomwifiau
Thu Oct 31, 2013 5:07 am
OK so it's a bit further along. The device is now detected as an lte device and lte interface is present. But it's not working.
It's getting stuck on:
lte0: sent AT+CPIN?
lte0: rcvd ERROR
Which would indicate some sort of sim issue. Interestingly when I plugged it in to my laptop and used the telstra application to connect it came back with "account needs to be activated". Tried to activate it and didn't work. Rang telstra they said, you need to go in to diag mode in the app and set the device type to TMB (see screenshot). It is set to pre-paid by default and this is a business account. So I'm just wondering if this has something to do with stopping it at the command above.
I've got full logs from the telstra app below in case its useful for anyone who knows anything about AT commands and can see what might be causing the problem.
first up is the log from connecting with pre-paid mode (ie getting the need to activate issue). Below that is the connection in TMB mode.
any assistance is greatly appreciated
2013-10-31 11:01:36.822 Mobile Broadband Manager[873:10d03] IPv6 active
2013-10-31 11:01:36.822 Mobile Broadband Manager[873:aeab] IPv6 active
2013-10-31 11:01:36.822 Mobile Broadband Manager[873:19a0b] IPv6 active
2013-10-31 11:01:36.822 Mobile Broadband Manager[873:13013] IPv6 active
2013-10-31 11:01:36.822 Mobile Broadband Manager[873:f103] IPv6 active
2013-10-31 11:01:38.695 Mobile Broadband Manager[873:aeab] IPv6 active
2013-10-31 11:01:38.695 Mobile Broadband Manager[873:10d03] IPv6 active
2013-10-31 11:01:38.696 Mobile Broadband Manager[873:f103] IPv6 active
2013-10-31 11:01:38.696 Mobile Broadband Manager[873:13013] IPv6 active
2013-10-31 11:01:38.696 Mobile Broadband Manager[873:19a0b] IPv6 active
2013-10-31 11:01:40.884 Mobile Broadband Manager[873:1003] Modem Model <SierraSWOCModel: 0x577e50>
2013-10-31 11:01:40.886 Mobile Broadband Manager[873:1003] Modem address <SierraSWOCModel: 0x577e50>
2013-10-31 11:01:40.896 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:01:40.896 Mobile Broadband Manager[873:1003] Destroying modem object <NoModem: 0x5261b0>
2013-10-31 11:01:40.897 Mobile Broadband Manager[873:1003] Modem started
2013-10-31 11:01:40.901 Mobile Broadband Manager[873:1003] Received termination event for: IOUSBDevice
2013-10-31 11:01:40.901 Mobile Broadband Manager[873:1003] Modem removed
2013-10-31 11:01:40.901 Mobile Broadband Manager[873:1003] showAssistMeView: Unable to detect your Mobile Broadband device
2013-10-31 11:01:40.904 Mobile Broadband Manager[873:1003] Creating modemModel <NoModem: 0x22845e0>
2013-10-31 11:01:40.905 Mobile Broadband Manager[873:1003] Modem Model <NoModem: 0x22845e0>
2013-10-31 11:01:40.906 Mobile Broadband Manager[873:1003] Modem address <NoModem: 0x22845e0>
2013-10-31 11:01:40.908 Mobile Broadband Manager[873:1003] Modem disappeared
2013-10-31 11:01:40.909 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:01:40.910 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:01:40.942 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:01:40.965 Mobile Broadband Manager[873:1003] Received arrival event for: IOUSBDevice
2013-10-31 11:01:40.966 Mobile Broadband Manager[873:1003] Creating modemModel <SierraAC320U: 0xc5548b0>
2013-10-31 11:01:40.966 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:01:40.968 Mobile Broadband Manager[873:1003] Found Ethernet Interface:en7
2013-10-31 11:01:40.969 Mobile Broadband Manager[873:1003] Modem Model <SierraAC320U: 0xc5548b0>
2013-10-31 11:01:40.970 Mobile Broadband Manager[873:1003] Modem address <SierraAC320U: 0xc5548b0>
2013-10-31 11:01:40.974 Mobile Broadband Manager[873:1003] Removing assist me view
2013-10-31 11:01:40.975 Mobile Broadband Manager[873:1003] New status: Initialising...
2013-10-31 11:01:40.975 Mobile Broadband Manager[873:1003] Device already open, closing
2013-10-31 11:01:40.975 Mobile Broadband Manager[873:1003] Error waiting for drain - Device not configured(6).
2013-10-31 11:01:40.975 Mobile Broadband Manager[873:1003] Error resetting tty attributes - Device not configured(6).
2013-10-31 11:01:40.976 Mobile Broadband Manager[873:1003] device closed
2013-10-31 11:01:40.979 Mobile Broadband Manager[873:1003] Modem started
2013-10-31 11:01:40.982 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:01:41.068 Mobile Broadband Manager[873:1c21f] Sent 7 bytes: ATE1V1<cr>
2013-10-31 11:01:41.074 Mobile Broadband Manager[873:13b4b] Received 7 bytes: ATE1V1<cr>
2013-10-31 11:01:41.075 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:42.988 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT+CMEE=2<cr>
2013-10-31 11:01:42.990 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT+CMEE=2<cr>
2013-10-31 11:01:42.991 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:43.089 Mobile Broadband Manager[873:1c21f] Sent 4 bytes: ATI<cr>
2013-10-31 11:01:43.097 Mobile Broadband Manager[873:13b4b] Received 4 bytes: ATI<cr>
2013-10-31 11:01:43.100 Mobile Broadband Manager[873:13b4b] Received 44 bytes: Manufacturer: Sierra Wireless, Incorporated<cr>
2013-10-31 11:01:43.102 Mobile Broadband Manager[873:13b4b] Received 20 bytes: Model: AirCard 320U<cr>
2013-10-31 11:01:43.102 Mobile Broadband Manager[873:13b4b] Received 74 bytes: Revision: SWI9200X_03.05.23.09ap r5836 carmd-en-10527 2013/06/17 18:01:23<cr>
2013-10-31 11:01:43.103 Mobile Broadband Manager[873:13b4b] Received 22 bytes: IMEI: 357272045321415<cr>
2013-10-31 11:01:43.104 Mobile Broadband Manager[873:13b4b] helpMenuItem is not removed
2013-10-31 11:01:43.107 Mobile Broadband Manager[873:13b4b] Received 12 bytes: IMEI SV: 17<cr>
2013-10-31 11:01:43.107 Mobile Broadband Manager[873:13b4b] Received 19 bytes: FSN: CC42393175110<cr>
2013-10-31 11:01:43.107 Mobile Broadband Manager[873:13b4b] Received 15 bytes: 3GPP Release 8<cr>
2013-10-31 11:01:43.108 Mobile Broadband Manager[873:13b4b] Received 13 bytes: +GCAP: +CGSM<cr>
2013-10-31 11:01:43.108 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:43.191 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+CFUN?<cr>
2013-10-31 11:01:43.194 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+CFUN?<cr>
2013-10-31 11:01:43.195 Mobile Broadband Manager[873:13b4b] Received 9 bytes: +CFUN: 1<cr>
2013-10-31 11:01:45.196 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:45.210 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT!BAND?<cr>
2013-10-31 11:01:45.216 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT!BAND?<cr>
2013-10-31 11:01:45.219 Mobile Broadband Manager[873:13b4b] Received 12 bytes: Index, Name<cr>
2013-10-31 11:01:45.888 Mobile Broadband Manager[873:16b3f] Destroying modem object <SierraSWOCModel: 0x577e50>
2013-10-31 11:01:45.907 Mobile Broadband Manager[873:17c13] Destroying modem object <NoModem: 0x22845e0>
2013-10-31 11:01:45.990 Mobile Broadband Manager[873:1a80b] Installed driver:1.1.5 loaded driver:1.1.5
2013-10-31 11:01:46.221 Mobile Broadband Manager[873:13b4b] Received 14 bytes: 00, All Bands<cr>
2013-10-31 11:01:46.221 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.322 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT!BAND=0<cr>
2013-10-31 11:01:46.330 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT!BAND=0<cr>
2013-10-31 11:01:46.342 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.424 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+CPIN?<cr>
2013-10-31 11:01:46.427 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+CPIN?<cr>
2013-10-31 11:01:46.428 Mobile Broadband Manager[873:13b4b] Received 13 bytes: +CPIN: READY<cr>
2013-10-31 11:01:46.428 Mobile Broadband Manager[873:13b4b] Sim ready
2013-10-31 11:01:46.429 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.525 Mobile Broadband Manager[873:1c21f] Sent 8 bytes: AT+CIMI<cr>
2013-10-31 11:01:46.527 Mobile Broadband Manager[873:13b4b] Received 8 bytes: AT+CIMI<cr>
2013-10-31 11:01:46.531 Mobile Broadband Manager[873:13b4b] Received 16 bytes: 505013450672114<cr>
2013-10-31 11:01:46.531 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.626 Mobile Broadband Manager[873:1c21f] Sent 15 bytes: AT+CLCK="SC",2<cr>
2013-10-31 11:01:46.631 Mobile Broadband Manager[873:13b4b] Received 15 bytes: AT+CLCK="SC",2<cr>
2013-10-31 11:01:46.633 Mobile Broadband Manager[873:13b4b] Received 9 bytes: +CLCK: 0<cr>
2013-10-31 11:01:46.633 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.728 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT+CPINC?<cr>
2013-10-31 11:01:46.736 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT+CPINC?<cr>
2013-10-31 11:01:46.737 Mobile Broadband Manager[873:13b4b] Received 18 bytes: +CPINC: 3,3,10,10<cr>
2013-10-31 11:01:46.737 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.829 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+CREG?<cr>
2013-10-31 11:01:46.832 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+CREG?<cr>
2013-10-31 11:01:46.833 Mobile Broadband Manager[873:13b4b] Received 11 bytes: +CREG: 0,1<cr>
2013-10-31 11:01:46.833 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:46.930 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT+CREG=2<cr>
2013-10-31 11:01:46.932 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT+CREG=2<cr>
2013-10-31 11:01:46.932 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:47.032 Mobile Broadband Manager[873:1c21f] Sent 11 bytes: AT+CGREG=1<cr>
2013-10-31 11:01:47.037 Mobile Broadband Manager[873:13b4b] Received 11 bytes: AT+CGREG=1<cr>
2013-10-31 11:01:48.038 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:48.042 Mobile Broadband Manager[873:1c21f] Sent 11 bytes: AT!CUSTOM?<cr>
2013-10-31 11:01:48.050 Mobile Broadband Manager[873:13b4b] Received 11 bytes: AT!CUSTOM?<cr>
2013-10-31 11:01:48.053 Mobile Broadband Manager[873:13b4b] Received 10 bytes: !CUSTOM: <cr>
2013-10-31 11:01:48.053 Mobile Broadband Manager[873:13b4b] Received 27 bytes: PUKPRMPT 0x01<cr>
2013-10-31 11:01:48.053 Mobile Broadband Manager[873:13b4b] Received 26 bytes: MEPCODE 0x01<cr>
2013-10-31 11:01:48.053 Mobile Broadband Manager[873:13b4b] Received 27 bytes: ISVOICEN 0x02<cr>
2013-10-31 11:01:48.053 Mobile Broadband Manager[873:13b4b] Received 28 bytes: PRLREGION 0x03<cr>
2013-10-31 11:01:48.054 Mobile Broadband Manager[873:13b4b] Received 30 bytes: PCSCDISABLE 0x03<cr>
2013-10-31 11:01:48.054 Mobile Broadband Manager[873:13b4b] Received 33 bytes: AUTONETWORKMODE 0x02<cr>
2013-10-31 11:01:48.054 Mobile Broadband Manager[873:13b4b] Received 29 bytes: SWOCENABLE 0x03<cr>
2013-10-31 11:01:48.054 Mobile Broadband Manager[873:13b4b] Received 25 bytes: HSICON 0x01<cr>
2013-10-31 11:01:48.054 Mobile Broadband Manager[873:13b4b] Received 30 bytes: USBMSENABLE 0x01<cr>
2013-10-31 11:01:48.055 Mobile Broadband Manager[873:13b4b] Received 33 bytes: SINGLEAPNSWITCH 0x01<cr>
2013-10-31 11:01:48.055 Mobile Broadband Manager[873:13b4b] Received 25 bytes: LTESMS 0x01<cr>
2013-10-31 11:01:48.055 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:48.143 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT+CGREG?<cr>
2013-10-31 11:01:48.148 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT+CGREG?<cr>
2013-10-31 11:01:48.148 Mobile Broadband Manager[873:13b4b] Received 12 bytes: +CGREG: 1,1<cr>
2013-10-31 11:01:48.148 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:48.244 Mobile Broadband Manager[873:1c21f] Sent 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:01:48.246 Mobile Broadband Manager[873:13b4b] Received 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:01:48.248 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:49.153 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:49.155 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:49.156 Mobile Broadband Manager[873:13b4b] Received 23 bytes: +COPS: 1,0,"Telstra",7<cr>
2013-10-31 11:01:49.156 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:50.162 Mobile Broadband Manager[873:1c21f] Sent 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:01:50.171 Mobile Broadband Manager[873:13b4b] Received 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:01:50.171 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:51.171 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:51.173 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:51.174 Mobile Broadband Manager[873:13b4b] Received 21 bytes: +COPS: 1,2,"50501",7<cr>
2013-10-31 11:01:51.174 Mobile Broadband Manager[873:13b4b] Registered on network
2013-10-31 11:01:51.174 Mobile Broadband Manager[873:13b4b] Interface name is en7
2013-10-31 11:01:55.821 Mobile Broadband Manager[873:19a0b] IPv4 active
2013-10-31 11:01:55.821 Mobile Broadband Manager[873:13013] IPv4 active
2013-10-31 11:01:55.821 Mobile Broadband Manager[873:10d03] IPv4 active
2013-10-31 11:01:55.821 Mobile Broadband Manager[873:aeab] IPv4 active
2013-10-31 11:01:55.821 Mobile Broadband Manager[873:f103] IPv4 active
2013-10-31 11:01:56.177 Mobile Broadband Manager[873:13b4b] Not connected
2013-10-31 11:01:56.226 Mobile Broadband Manager[873:13b4b] New status: Not connected
2013-10-31 11:01:56.290 Mobile Broadband Manager[873:13b4b] showAssistMeView: The Pre-Paid service has not been activated
2013-10-31 11:01:56.309 Mobile Broadband Manager[873:13b4b] Removing assist me view
2013-10-31 11:01:56.310 Mobile Broadband Manager[873:13b4b] About to verify IMEI
2013-10-31 11:01:56.311 Mobile Broadband Manager[873:13b4b] Modem is not registered (activated).
2013-10-31 11:01:56.311 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:01:56.312 Mobile Broadband Manager[873:13b4b] showAssistMeView: The Pre-Paid service has not been activated
2013-10-31 11:01:56.326 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:56.327 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:01:56.417 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+RSCP?<cr>
2013-10-31 11:01:56.426 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+RSCP?<cr>
2013-10-31 11:01:56.426 Mobile Broadband Manager[873:13b4b] Received 8 bytes: +RSCP: <cr>
2013-10-31 11:01:56.426 Mobile Broadband Manager[873:13b4b] Received 15 bytes: Car0 RSCP: 0 <cr>
2013-10-31 11:01:56.427 Mobile Broadband Manager[873:13b4b] Received 16 bytes: Car1 RSCP: n/a<cr>
2013-10-31 11:01:56.427 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:56.519 Mobile Broadband Manager[873:1c21f] Sent 11 bytes: AT!PCTEMP?<cr>
2013-10-31 11:01:56.524 Mobile Broadband Manager[873:13b4b] Received 11 bytes: AT!PCTEMP?<cr>
2013-10-31 11:01:56.524 Mobile Broadband Manager[873:13b4b] Received 19 bytes: Temp state: Normal<cr>
2013-10-31 11:01:56.525 Mobile Broadband Manager[873:13b4b] Received 21 bytes: Temperature: 35 degC<cr>
2013-10-31 11:01:56.525 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:56.621 Mobile Broadband Manager[873:1c21f] Sent 10 bytes: AT*CNTI=0<cr>
2013-10-31 11:01:56.629 Mobile Broadband Manager[873:13b4b] Received 10 bytes: AT*CNTI=0<cr>
2013-10-31 11:01:56.629 Mobile Broadband Manager[873:13b4b] Received 13 bytes: *CNTI: 0,LTE<cr>
2013-10-31 11:01:56.631 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:57.228 Mobile Broadband Manager[873:1c21f] Sent 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:01:57.229 Mobile Broadband Manager[873:13b4b] Received 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:01:57.230 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:58.238 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:58.239 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:01:58.240 Mobile Broadband Manager[873:13b4b] Received 23 bytes: +COPS: 1,0,"Telstra",7<cr>
2013-10-31 11:01:58.240 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:01:59.248 Mobile Broadband Manager[873:1c21f] Sent 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:01:59.251 Mobile Broadband Manager[873:13b4b] Received 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:01:59.251 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:02:00.259 Mobile Broadband Manager[873:1c21f] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:02:00.268 Mobile Broadband Manager[873:13b4b] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:02:00.268 Mobile Broadband Manager[873:13b4b] Received 21 bytes: +COPS: 1,2,"50501",7<cr>
2013-10-31 11:02:00.268 Mobile Broadband Manager[873:13b4b] Received 3 bytes: OK<cr>
2013-10-31 11:02:00.628 Mobile Broadband Manager[873:1003] Received termination event for: IOUSBDevice
2013-10-31 11:02:00.629 Mobile Broadband Manager[873:1003] Modem removed
Connection in TMB mode
2013-10-31 11:06:21.366 Mobile Broadband Manager[873:10d03] IPv6 active
2013-10-31 11:06:21.366 Mobile Broadband Manager[873:aeab] IPv6 active
2013-10-31 11:06:21.366 Mobile Broadband Manager[873:13013] IPv6 active
2013-10-31 11:06:21.367 Mobile Broadband Manager[873:f103] IPv6 active
2013-10-31 11:06:21.366 Mobile Broadband Manager[873:19a0b] IPv6 active
2013-10-31 11:06:22.590 Mobile Broadband Manager[873:1003] Modem Model <SierraSWOCModel: 0x8678ba0>
2013-10-31 11:06:22.594 Mobile Broadband Manager[873:1003] Modem address <SierraSWOCModel: 0x8678ba0>
2013-10-31 11:06:22.602 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:06:22.602 Mobile Broadband Manager[873:1003] Destroying modem object <NoModem: 0x8b9b520>
2013-10-31 11:06:22.602 Mobile Broadband Manager[873:1003] Modem started
2013-10-31 11:06:22.607 Mobile Broadband Manager[873:1003] Received termination event for: IOUSBDevice
2013-10-31 11:06:22.607 Mobile Broadband Manager[873:1003] Modem removed
2013-10-31 11:06:22.607 Mobile Broadband Manager[873:1003] showAssistMeView: Unable to detect your Mobile Broadband device
2013-10-31 11:06:22.611 Mobile Broadband Manager[873:1003] Creating modemModel <NoModem: 0xc558ef0>
2013-10-31 11:06:22.611 Mobile Broadband Manager[873:1003] Modem Model <NoModem: 0xc558ef0>
2013-10-31 11:06:22.612 Mobile Broadband Manager[873:1003] Modem address <NoModem: 0xc558ef0>
2013-10-31 11:06:22.619 Mobile Broadband Manager[873:1003] Modem disappeared
2013-10-31 11:06:22.619 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:06:22.620 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:06:22.623 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:06:22.632 Mobile Broadband Manager[873:1003] Received arrival event for: IOUSBDevice
2013-10-31 11:06:22.632 Mobile Broadband Manager[873:1003] Creating modemModel <SierraAC320U: 0x22b7420>
2013-10-31 11:06:22.632 Mobile Broadband Manager[873:1003] New status: No Next G™ device
2013-10-31 11:06:22.634 Mobile Broadband Manager[873:1003] Found Ethernet Interface:en7
2013-10-31 11:06:22.635 Mobile Broadband Manager[873:1003] Modem Model <SierraAC320U: 0x22b7420>
2013-10-31 11:06:22.636 Mobile Broadband Manager[873:1003] Modem address <SierraAC320U: 0x22b7420>
2013-10-31 11:06:22.653 Mobile Broadband Manager[873:1003] Removing assist me view
2013-10-31 11:06:22.654 Mobile Broadband Manager[873:1003] New status: Initialising...
2013-10-31 11:06:22.654 Mobile Broadband Manager[873:1003] Device already open, closing
2013-10-31 11:06:22.654 Mobile Broadband Manager[873:1003] Error waiting for drain - Device not configured(6).
2013-10-31 11:06:22.654 Mobile Broadband Manager[873:1003] Error resetting tty attributes - Device not configured(6).
2013-10-31 11:06:22.655 Mobile Broadband Manager[873:1003] device closed
2013-10-31 11:06:22.658 Mobile Broadband Manager[873:1003] Modem started
2013-10-31 11:06:22.659 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:06:22.735 Mobile Broadband Manager[873:1c233] Sent 7 bytes: ATE1V1<cr>
2013-10-31 11:06:22.744 Mobile Broadband Manager[873:1e903] Received 7 bytes: ATE1V1<cr>
2013-10-31 11:06:22.757 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:23.165 Mobile Broadband Manager[873:19a0b] IPv6 active
2013-10-31 11:06:23.165 Mobile Broadband Manager[873:10d03] IPv6 active
2013-10-31 11:06:23.166 Mobile Broadband Manager[873:13013] IPv6 active
2013-10-31 11:06:23.166 Mobile Broadband Manager[873:f103] IPv6 active
2013-10-31 11:06:23.166 Mobile Broadband Manager[873:aeab] IPv6 active
2013-10-31 11:06:24.755 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT+CMEE=2<cr>
2013-10-31 11:06:24.764 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT+CMEE=2<cr>
2013-10-31 11:06:24.764 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:24.856 Mobile Broadband Manager[873:1c233] Sent 4 bytes: ATI<cr>
2013-10-31 11:06:24.859 Mobile Broadband Manager[873:1e903] Received 4 bytes: ATI<cr>
2013-10-31 11:06:24.862 Mobile Broadband Manager[873:1e903] Received 44 bytes: Manufacturer: Sierra Wireless, Incorporated<cr>
2013-10-31 11:06:24.863 Mobile Broadband Manager[873:1e903] Received 20 bytes: Model: AirCard 320U<cr>
2013-10-31 11:06:24.863 Mobile Broadband Manager[873:1e903] Received 74 bytes: Revision: SWI9200X_03.05.23.09ap r5836 carmd-en-10527 2013/06/17 18:01:23<cr>
2013-10-31 11:06:24.864 Mobile Broadband Manager[873:1e903] Received 22 bytes: IMEI: 357272045321415<cr>
2013-10-31 11:06:24.865 Mobile Broadband Manager[873:1e903] helpMenuItem is not removed
2013-10-31 11:06:24.867 Mobile Broadband Manager[873:1e903] Received 12 bytes: IMEI SV: 17<cr>
2013-10-31 11:06:24.868 Mobile Broadband Manager[873:1e903] Received 19 bytes: FSN: CC42393175110<cr>
2013-10-31 11:06:24.868 Mobile Broadband Manager[873:1e903] Received 15 bytes: 3GPP Release 8<cr>
2013-10-31 11:06:24.868 Mobile Broadband Manager[873:1e903] Received 13 bytes: +GCAP: +CGSM<cr>
2013-10-31 11:06:24.868 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:24.958 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+CFUN?<cr>
2013-10-31 11:06:24.963 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+CFUN?<cr>
2013-10-31 11:06:24.963 Mobile Broadband Manager[873:1e903] Received 9 bytes: +CFUN: 1<cr>
2013-10-31 11:06:26.965 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:26.976 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT!BAND?<cr>
2013-10-31 11:06:26.979 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT!BAND?<cr>
2013-10-31 11:06:26.982 Mobile Broadband Manager[873:1e903] Received 12 bytes: Index, Name<cr>
2013-10-31 11:06:27.595 Mobile Broadband Manager[873:1da13] Destroying modem object <SierraSWOCModel: 0x8678ba0>
2013-10-31 11:06:27.614 Mobile Broadband Manager[873:1df23] Destroying modem object <NoModem: 0xc558ef0>
2013-10-31 11:06:27.658 Mobile Broadband Manager[873:1e407] Installed driver:1.1.5 loaded driver:1.1.5
2013-10-31 11:06:27.984 Mobile Broadband Manager[873:1e903] Received 14 bytes: 00, All Bands<cr>
2013-10-31 11:06:27.984 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:27.986 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT!BAND=0<cr>
2013-10-31 11:06:27.988 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT!BAND=0<cr>
2013-10-31 11:06:28.002 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.088 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+CPIN?<cr>
2013-10-31 11:06:28.095 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+CPIN?<cr>
2013-10-31 11:06:28.095 Mobile Broadband Manager[873:1e903] Received 13 bytes: +CPIN: READY<cr>
2013-10-31 11:06:28.096 Mobile Broadband Manager[873:1e903] Sim ready
2013-10-31 11:06:28.096 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.189 Mobile Broadband Manager[873:1c233] Sent 8 bytes: AT+CIMI<cr>
2013-10-31 11:06:28.191 Mobile Broadband Manager[873:1e903] Received 8 bytes: AT+CIMI<cr>
2013-10-31 11:06:28.371 Mobile Broadband Manager[873:1e903] Received 16 bytes: 505013450672114<cr>
2013-10-31 11:06:28.371 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.391 Mobile Broadband Manager[873:1c233] Sent 15 bytes: AT+CLCK="SC",2<cr>
2013-10-31 11:06:28.395 Mobile Broadband Manager[873:1e903] Received 15 bytes: AT+CLCK="SC",2<cr>
2013-10-31 11:06:28.539 Mobile Broadband Manager[873:1e903] Received 9 bytes: +CLCK: 0<cr>
2013-10-31 11:06:28.539 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.594 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT+CPINC?<cr>
2013-10-31 11:06:28.600 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT+CPINC?<cr>
2013-10-31 11:06:28.640 Mobile Broadband Manager[873:1e903] Received 18 bytes: +CPINC: 3,3,10,10<cr>
2013-10-31 11:06:28.641 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.695 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+CREG?<cr>
2013-10-31 11:06:28.697 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+CREG?<cr>
2013-10-31 11:06:28.697 Mobile Broadband Manager[873:1e903] Received 11 bytes: +CREG: 0,1<cr>
2013-10-31 11:06:28.697 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.796 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT+CREG=2<cr>
2013-10-31 11:06:28.803 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT+CREG=2<cr>
2013-10-31 11:06:28.803 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:28.898 Mobile Broadband Manager[873:1c233] Sent 11 bytes: AT+CGREG=1<cr>
2013-10-31 11:06:28.902 Mobile Broadband Manager[873:1e903] Received 11 bytes: AT+CGREG=1<cr>
2013-10-31 11:06:29.903 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:29.908 Mobile Broadband Manager[873:1c233] Sent 11 bytes: AT!CUSTOM?<cr>
2013-10-31 11:06:29.911 Mobile Broadband Manager[873:1e903] Received 11 bytes: AT!CUSTOM?<cr>
2013-10-31 11:06:29.914 Mobile Broadband Manager[873:1e903] Received 10 bytes: !CUSTOM: <cr>
2013-10-31 11:06:29.914 Mobile Broadband Manager[873:1e903] Received 27 bytes: PUKPRMPT 0x01<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 26 bytes: MEPCODE 0x01<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 27 bytes: ISVOICEN 0x02<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 28 bytes: PRLREGION 0x03<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 30 bytes: PCSCDISABLE 0x03<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 33 bytes: AUTONETWORKMODE 0x02<cr>
2013-10-31 11:06:29.915 Mobile Broadband Manager[873:1e903] Received 29 bytes: SWOCENABLE 0x03<cr>
2013-10-31 11:06:29.916 Mobile Broadband Manager[873:1e903] Received 25 bytes: HSICON 0x01<cr>
2013-10-31 11:06:29.916 Mobile Broadband Manager[873:1e903] Received 30 bytes: USBMSENABLE 0x01<cr>
2013-10-31 11:06:29.916 Mobile Broadband Manager[873:1e903] Received 33 bytes: SINGLEAPNSWITCH 0x01<cr>
2013-10-31 11:06:29.916 Mobile Broadband Manager[873:1e903] Received 25 bytes: LTESMS 0x01<cr>
2013-10-31 11:06:29.916 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:30.009 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT+CGREG?<cr>
2013-10-31 11:06:30.016 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT+CGREG?<cr>
2013-10-31 11:06:30.017 Mobile Broadband Manager[873:1e903] Received 12 bytes: +CGREG: 1,1<cr>
2013-10-31 11:06:30.017 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:30.111 Mobile Broadband Manager[873:1c233] Sent 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:06:30.112 Mobile Broadband Manager[873:1e903] Received 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:06:30.114 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:31.018 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:31.026 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:31.027 Mobile Broadband Manager[873:1e903] Received 23 bytes: +COPS: 1,0,"Telstra",7<cr>
2013-10-31 11:06:31.027 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:32.028 Mobile Broadband Manager[873:1c233] Sent 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:06:32.036 Mobile Broadband Manager[873:1e903] Received 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:06:32.036 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:33.038 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:33.041 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:33.042 Mobile Broadband Manager[873:1e903] Received 21 bytes: +COPS: 1,2,"50501",7<cr>
2013-10-31 11:06:33.042 Mobile Broadband Manager[873:1e903] Registered on network
2013-10-31 11:06:33.042 Mobile Broadband Manager[873:1e903] Interface name is en7
2013-10-31 11:06:38.045 Mobile Broadband Manager[873:1e903] Not connected
2013-10-31 11:06:38.104 Mobile Broadband Manager[873:1e903] New status: Not connected
2013-10-31 11:06:38.117 Mobile Broadband Manager[873:1e903] showAssistMeView: The Pre-Paid service has not been activated
2013-10-31 11:06:38.119 Mobile Broadband Manager[873:1e903] Removing assist me view
2013-10-31 11:06:38.119 Mobile Broadband Manager[873:1e903] About to verify IMEI
2013-10-31 11:06:38.120 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:06:38.121 Mobile Broadband Manager[873:1e903] Modem is not registered (activated).
2013-10-31 11:06:38.121 Mobile Broadband Manager[873:1e903] showAssistMeView: The Pre-Paid service has not been activated
2013-10-31 11:06:38.122 Mobile Broadband Manager[873:1003] Stopping the view animation
2013-10-31 11:06:38.137 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:38.185 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+RSCP?<cr>
2013-10-31 11:06:38.187 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+RSCP?<cr>
2013-10-31 11:06:38.187 Mobile Broadband Manager[873:1e903] Received 8 bytes: +RSCP: <cr>
2013-10-31 11:06:38.188 Mobile Broadband Manager[873:1e903] Received 15 bytes: Car0 RSCP: 0 <cr>
2013-10-31 11:06:38.189 Mobile Broadband Manager[873:1e903] Received 16 bytes: Car1 RSCP: n/a<cr>
2013-10-31 11:06:38.189 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:38.286 Mobile Broadband Manager[873:1c233] Sent 11 bytes: AT!PCTEMP?<cr>
2013-10-31 11:06:38.292 Mobile Broadband Manager[873:1e903] Received 11 bytes: AT!PCTEMP?<cr>
2013-10-31 11:06:38.293 Mobile Broadband Manager[873:1e903] Received 19 bytes: Temp state: Normal<cr>
2013-10-31 11:06:38.293 Mobile Broadband Manager[873:1e903] Received 21 bytes: Temperature: 32 degC<cr>
2013-10-31 11:06:38.293 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:38.387 Mobile Broadband Manager[873:1c233] Sent 10 bytes: AT*CNTI=0<cr>
2013-10-31 11:06:38.392 Mobile Broadband Manager[873:1e903] Received 10 bytes: AT*CNTI=0<cr>
2013-10-31 11:06:38.393 Mobile Broadband Manager[873:1e903] Received 13 bytes: *CNTI: 0,LTE<cr>
2013-10-31 11:06:38.395 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:39.093 Mobile Broadband Manager[873:1c233] Sent 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:06:39.101 Mobile Broadband Manager[873:1e903] Received 12 bytes: AT+COPS=3,0<cr>
2013-10-31 11:06:39.101 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:39.453 Mobile Broadband Manager[873:19a0b] IPv4 active
2013-10-31 11:06:39.454 Mobile Broadband Manager[873:13013] IPv4 active
2013-10-31 11:06:39.454 Mobile Broadband Manager[873:f103] IPv4 active
2013-10-31 11:06:39.454 Mobile Broadband Manager[873:aeab] IPv4 active
2013-10-31 11:06:39.455 Mobile Broadband Manager[873:10d03] IPv4 active
2013-10-31 11:06:40.103 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:40.104 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:40.104 Mobile Broadband Manager[873:1e903] Received 23 bytes: +COPS: 1,0,"Telstra",7<cr>
2013-10-31 11:06:40.104 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:41.114 Mobile Broadband Manager[873:1c233] Sent 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:06:41.118 Mobile Broadband Manager[873:1e903] Received 12 bytes: AT+COPS=3,2<cr>
2013-10-31 11:06:41.118 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:42.125 Mobile Broadband Manager[873:1c233] Sent 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:42.126 Mobile Broadband Manager[873:1e903] Received 9 bytes: AT+COPS?<cr>
2013-10-31 11:06:42.127 Mobile Broadband Manager[873:1e903] Received 21 bytes: +COPS: 1,2,"50501",7<cr>
2013-10-31 11:06:42.127 Mobile Broadband Manager[873:1e903] Received 3 bytes: OK<cr>
2013-10-31 11:06:43.660 Mobile Broadband Manager[873:1003] Received termination event for: IOUSBDevice
2013-10-31 11:06:43.660 Mobile Broadband Manager[873:1003] Modem removed
uldis
Thu Oct 31, 2013 9:28 am
in your windows logs the modem answers to the CPIN so not sure why it doesn't respond in the RouterOS.
freedomwifiau
Thu Oct 31, 2013 3:44 pm
yeah I know, that's why I posted the question. Any ideas?
RogerWilco
Sun Nov 03, 2013 5:44 am
Try sending a support file to MK and they'll probably want remote access to the router to have a look.
RogerWilco
Sat Feb 22, 2014 2:00 am
@freedomwifiau: any luck yet?
freedomwifiau
Thu Feb 27, 2014 7:36 am
Sorry I haven't bothered to follow it up. Was too hard at the time and had a lot of other things on list with higher priority.
RogerWilco
Fri Feb 28, 2014 3:32 am
Thanks for the reply anyway.
davefinster
Thu Mar 05, 2015 5:50 am
Hi All,
I realise that this thread is a bit old but its right on topic. I'm not sure how to action this, but I believe that this person has identified a potential cause for the LTE mode being inoperable for the Sierra 320U:
http://whrl.pl/RdrGwn
It seems that the 320U does not support the "AT+CPIN?" command arriving on its data port when operating in Direct IP mode. This is the command that appears in the RouterOS logs when the device is in LTE mode, so perhaps RouterOS is simply not switching channels when the device is in LTE mode?
Happy to provide a test case.
Thanks,
Dave
aoakeley
Thu Mar 05, 2015 9:28 am
Hi All,
Thanks,
Dave
I came to the same conclusion (LTE Not Supported) and just settled for PPP mode instead.
Happy to hear specifics if anyone has got it going in LTE mode
RogerWilco
Fri Mar 06, 2015 12:11 am
John on Whirlpool is somewhat of a modem expert! I can't see it taking MikroTik long to test this...
@MikroTik: don't suppose you would like to test this out?
RogerWilco
Tue Apr 21, 2015 4:26 am
Thanks MikroTik, with 6.28 DirectIP now works with the Sierra Wireless 320U.
Slight issue though: you get 50% less speed than PPP.
xeno
Wed Apr 22, 2015 3:45 pm
Hey There,
I'm struggling incredibly hard to actually get this to work.
How did you manage to get direct IP functionality working with the 320u?
I'm using firmware 6.29rc9
Cheers!
nz_monkey
Wed Apr 22, 2015 8:32 pm
We spent quite a bit of time working with Mikrotik to get this fixed for 6.28
We don't see the 50% reduction in pperformance in lte mode though....
it is important to have up to date firmware on the 320U
this can be updated with the windows utility.
RogerWilco
Thu Apr 23, 2015 3:11 am
Hey There,
Cheers!
I just downloaded 6.28 and then made sure the router firmware was up to date. That was it. Once it connected, I added a DHCP client to the LTE interface and away I went.
We spent quite a bit of time working with Mikrotik to get this fixed for 6.28We don't see the 50% reduction in pperformance in lte mode though....it is important to have up to date firmware on the 320Uthis can be updated with the windows utility.
I'll test again on the weekend. The firmware in the modem is up to date. There is another thing too, the LTE interface writes to the log every 2 seconds.
RogerWilco
Fri Apr 24, 2015 10:37 am
Did another test and it's all working fine now. Not sure what the problem was.
eriitguy
Tue Oct 10, 2017 6:10 pm
Hello, everyone!
We are planning to buy a Sierra Wireless AirCard 320U LTE modem in order to be able to get Public IP on the Mikrotik.
Also it may be usefully to use it in LTE Passthrough mode.
As we read on this thread, this may be done but some questions remain:
1. May we buy it on Ebay without any issue?
2. Where may we get latest version of firmware in order to get it working with Mikrotik in Direct IP mode?
3. This modem is not listed in the wiki page: https://wiki.mikrotik.com/wiki/Supporte ... and_modems
4. This modem is not listed in the wiki page: https://wiki.mikrotik.com/wiki/Manual:Peripherals
5. May we get it working in LTE Passtrough mode?
Thank you!
eriitguy
Wed Oct 18, 2017 9:37 am
Reply from Mikrotik support:
the modem might work in the RouterOS
Sierra drivers doesn't support passthrough option.
eriitguy
Thu Nov 23, 2017 9:43 am
Mikrotik RouterOS - Sierra Wireless Netgear AirCard 320U 4G LTE Modem support
Thank you!
Users browsing this forum: Bing [Bot], Google [Bot], jaisal, pav5, sindy, vagrik and 202 guests
